Helias_Tancred Posted November 28, 2021 Share Posted November 28, 2021 Hey all. I'm curious if you use Seraphim Sepia on the armor (as the GW app suggests) or Agrax Earthshade? I also have a bottle of Army Painter's Mid Brown shade, which seems to be a middle of the road between the two GW shades? Thanks. Link to comment https://bolterandchainsword.com/topic/372475-painting-deathwing-question/ Share on other sites More sharing options...
Lord Marshal Posted November 29, 2021 Share Posted November 29, 2021 WarhammerTV advises Seraphim Sepia. You could just Agrax if you wanted a darker, browner tone. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/372475-painting-deathwing-question/#findComment-5768020 Share on other sites More sharing options...
Helias_Tancred Posted November 29, 2021 Author Share Posted November 29, 2021 Aargh, now I'm more confused, Duncan presented an entirely new recipe and method ... lolololol. I based all of mine in Zandri Dust. I was going to use Seraphim Sepia (most likely), then Screaming Skull, whereas he uses Pallid Which Flesh! I may use PWF as edge highlighting as he did but over the Screaming Skull? /too many choices Link to comment https://bolterandchainsword.com/topic/372475-painting-deathwing-question/#findComment-5768023 Share on other sites More sharing options...
Grotsmasha Posted November 29, 2021 Share Posted November 29, 2021 It really depends on the level of contrast you're after, personally I use 50/50 Sepia/Lahmian in several layers. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/372475-painting-deathwing-question/#findComment-5768026 Share on other sites More sharing options...
Helias_Tancred Posted November 29, 2021 Author Share Posted November 29, 2021 They also say that the final highlight for the green chest piece and the chapter icon on the forehead are done with a final highlight of Moot Green. lolol that is no Moot Green on them. It looks like some sort of light white-gray color on the edges like Ulthuan, or Administratum Grey? Link to comment https://bolterandchainsword.com/topic/372475-painting-deathwing-question/#findComment-5768061 Share on other sites More sharing options...
Cpt. Bannockburn Posted November 29, 2021 Share Posted November 29, 2021 Or, for a completely different approach: Thinned Skeleton Horde (Contrast) 1:1 with Contrast Medium over Grey Seer or Wraithbone (for a warmer end result). Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/372475-painting-deathwing-question/#findComment-5768091 Share on other sites More sharing options...
Raychu Posted November 29, 2021 Share Posted November 29, 2021 i go with agrax earthshade over a undercoated of skeletton bone from Army painter. from there I repaint everything with ushabti bone. very thin layers. like 4 or 5 thinned down layers actually. here is before / after photo and what it give at the end Chaplain Raeven, Brother Immolator, shabbadoo and 5 others 8 Back to top Link to comment https://bolterandchainsword.com/topic/372475-painting-deathwing-question/#findComment-5768094 Share on other sites More sharing options...
Interrogator Stobz Posted November 29, 2021 Share Posted November 29, 2021 (edited) I go Agrax over white. But I also use a darker brown ink for in the recesses, contrast is king. Edited November 30, 2021 by Interrogator Stobz Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/372475-painting-deathwing-question/#findComment-5768111 Share on other sites More sharing options...
Bryan Blaire Posted November 29, 2021 Share Posted November 29, 2021 I start with Mournfang Brown, and use Agrax Earthshade over that, then blend up from there - my Deathwalkers don’t have full bone armor like Deathwing though, just bone support struts and helms. It all really depends on what look you want to get - I prefer high contrast with a pretty dark starting point for the recesses, which I don’t feel is what the GW method gets you with Seraphim Sepia. You could also do a three layer shade blend, where you do a broad Seraphim Sepia shade first, then a more controlled 1:1 blend of Agrax:Seraphim, and then a final shade only in the extreme recesses with pure Agrax Earthshade, and then blend up from there. I also like blending up from Mournfang Brown -> 1:1 Mournfang:Zandri -> Zandri Dust -> Morghast Bone -> Ushtabi Bone -> Screaming Skull -> Wraithbone ->. 1:1 Wraithbone:White. I may remove/slim down the layers depending on the size of the item I’m painting in this fashion - larger surfaces may actually get more layers with blended colors between these even. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/372475-painting-deathwing-question/#findComment-5768192 Share on other sites More sharing options...
WrathOfTheLion Posted November 29, 2021 Share Posted November 29, 2021 I use a basecoat of ushabti bone, the recess wash of seraphim sepia and then a highlight of screaming skull. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/372475-painting-deathwing-question/#findComment-5768212 Share on other sites More sharing options...
shabbadoo Posted November 30, 2021 Share Posted November 30, 2021 Agrax Earthshade here too, as I prefer a bit more contrast. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/372475-painting-deathwing-question/#findComment-5768382 Share on other sites More sharing options...
Flinch Posted December 15, 2021 Share Posted December 15, 2021 I still have and use flesh wash... whats that, 20 years old? Over any pale basecoat (from bleached bone to deneb stone to whatever bone/blonde at hand) then lighten it up with the same base coat. What brings it together in the end is white edge highlights and the detail of the weapons and decals. And the base. When you base them consistently all the minor differences of base coat blend in to make them not noticeable. Link to comment https://bolterandchainsword.com/topic/372475-painting-deathwing-question/#findComment-5772961 Share on other sites More sharing options...
Chaplain Raeven Posted December 15, 2021 Share Posted December 15, 2021 (edited) Well, as you can see there are many ways to get the bone armour. The difference between each result is not that obvious. I go Sepia if I want a bright scheme, usually on cream cloakes and the like. While I use Agrax for aged bone, like skulls and stained cloth. Recently I've mixed up a couple of pots of Agrax and Sepia in a 50:50 ratio to get a nice middle ground for any future projects, because I couldn't get Army Painter's Mid brown in my local store. So if that is the colour that you have, by all means use it! Edit: If we're talking recipes, I go Rakarth Flesh - Shade of your choice - Ushabti bone - Screaming skull - Ulthuan grey. If I want a more subtle blend, then I do the shade after the Ushabti instead of before, and tidy it up afterwards with a couple of thinned layers. Edited December 15, 2021 by Chaplain Grey Raven Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/372475-painting-deathwing-question/#findComment-5772976 Share on other sites More sharing options...
Helias_Tancred Posted December 16, 2021 Author Share Posted December 16, 2021 Well, as you can see there are many ways to get the bone armour. The difference between each result is not that obvious. I go Sepia if I want a bright scheme, usually on cream cloakes and the like. While I use Agrax for aged bone, like skulls and stained cloth. Recently I've mixed up a couple of pots of Agrax and Sepia in a 50:50 ratio to get a nice middle ground for any future projects, because I couldn't get Army Painter's Mid brown in my local store. So if that is the colour that you have, by all means use it! Edit: If we're talking recipes, I go Rakarth Flesh - Shade of your choice - Ushabti bone - Screaming skull - Ulthuan grey. If I want a more subtle blend, then I do the shade after the Ushabti instead of before, and tidy it up afterwards with a couple of thinned layers. I' ve got some AP Mid Brown. So you're saying that's good on Deathwing? I'll be using Ushabti and Screaming Skull. Link to comment https://bolterandchainsword.com/topic/372475-painting-deathwing-question/#findComment-5773247 Share on other sites More sharing options...
JeffJedi Posted December 16, 2021 Share Posted December 16, 2021 Has anyone used Morghast Bone yet? its a base paint and pretty new. Link to comment https://bolterandchainsword.com/topic/372475-painting-deathwing-question/#findComment-5773268 Share on other sites More sharing options...
Chaplain Raeven Posted December 16, 2021 Share Posted December 16, 2021 I' ve got some AP Mid Brown. So you're saying that's good on Deathwing? I'll be using Ushabti and Screaming Skull. You can't go wrong with any of the Sepia/brown washes. I mixed up my shades to get a close match to AP Mid Brown for a nice middle ground. So yeah, your wash would be great for Deathwing. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/372475-painting-deathwing-question/#findComment-5773276 Share on other sites More sharing options...
Bryan Blaire Posted December 16, 2021 Share Posted December 16, 2021 Has anyone used Morghast Bone yet? its a base paint and pretty new. Yes, but I don’t use it as a base color - I thin it out and use it as a layer between Zandri Dust and Ushtabi Bone, mostly only on larger bone elements. Link to comment https://bolterandchainsword.com/topic/372475-painting-deathwing-question/#findComment-5773337 Share on other sites More sharing options...
Brother Immolator Posted December 18, 2021 Share Posted December 18, 2021 I personally prefer my terminators to be a little more....dirty? That vibrant bonewhite is a bit too much. Pics are not that good (I suck at it). Its a bit of a hurdle to go there and I use the mecha army colours and washes. What I am trying to say is, that a couple sephia layers will give them that skeleton look but still it will be too bright. I would prefer the earthshade look as well, had I wanted something lighter. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/372475-painting-deathwing-question/#findComment-5773801 Share on other sites More sharing options...
