Cruor Vault Posted December 7, 2021 Share Posted December 7, 2021 ++ Patrol Detachment -2CP (Necrons) [79 PL, 8CP, 1,550pts] ++ + Configuration + Battle Size [12CP]: 3. Strike Force (101-200 Total PL / 1001-2000 Points) Detachment Command Cost [-2CP] Dynasty Choice: Dynasty: Novokh + HQ + Chronomancer [4 PL, -2CP, 80pts]: Aeonstave, Dynastic Heirlooms, Rarefied Nobility, Relic: Veil of Darkness, Warlord Trait (Codex 5): Implacable Conqueror (Aura) + Troops + Necron Warriors [12 PL, 260pts] . 20x Necron Warrior (Gauss Reaper): 20x Gauss Reaper + Elites + Skorpekh Destroyers [10 PL, 210pts] . 2x Skorpekh Destroyer (Reap-Blade): 2x Hyperphase Reap-Blade . 4x Skorpekh Destroyer (Thresher): 4x Hyperphase Threshers Skorpekh Destroyers [10 PL, 210pts] . 2x Skorpekh Destroyer (Reap-Blade): 2x Hyperphase Reap-Blade . 4x Skorpekh Destroyer (Thresher): 4x Hyperphase Threshers + Fast Attack + Canoptek Wraiths [10 PL, 210pts] . 6x Canoptek Wraith (Claws): 6x Vicious Claws Canoptek Wraiths [10 PL, 210pts] . 6x Canoptek Wraith (Claws): 6x Vicious Claws + Heavy Support + Lokhust Destroyers [15 PL, 250pts] . 5x Lokhust Destroyer: 5x Gauss Cannon Lokhust Heavy Destroyers [8 PL, 120pts] . 2x Lokhust Heavy Destroyer (Gauss Destructor): 2x Gauss Destructor ++ Supreme Command Detachment +2CP (Necrons) [23 PL, 5CP, 450pts] ++ + Configuration + Detachment Command Cost [2CP] Dynasty Choice: Dynasty: Szarekhan + Primarch | Daemon Primarch | Supreme Commander + The Silent King [23 PL, 3CP, 450pts] . 2x Triarchal Menhir: 2x Annihilator Beam ++ Total: [102 PL, 13CP, 2,000pts] ++ Trying to make the most out of the CORE update to Necrons whilst also maximizing the buffs provided by TSK now that his abilities work on most of the more desirable units in the codex. I'm looking for ideas on what secondaries would be ideal to match to this list. 'Codes of Combat' and 'Engage on all fronts' are easy ones in most games. 'No prisoners' or 'Bring them down' depending on opponent matchups. Lacking many infantry or small units I think 'Raise banners' 'stranglehold' and 'ROD' are out of the question. Link to comment https://bolterandchainsword.com/topic/372557-aggressive-melee-necrons-w-tsk/ Share on other sites More sharing options...
Tawnis Posted December 7, 2021 Share Posted December 7, 2021 I really like the list, though I would tweak it a little. I'd cut your skorpeks and Wraits down to 5 man teams to avoid the Blast issue. Then with that 140 points, I'd take a Chronomancer to buff/revive the Wraiths, and with the leftover 45, you could use 30 for a Fail Safe Overcharger to give your Wraiths +1 A. That does sadly leave you with 15 points twisting in the wind though. Perpahs cutting two warriors and taking 2 CryptoThralls to protect the Chronomancer? Novokh is good and all, but I personally have found more success with the custom traits Relentlessly Expansionist and Rad Wreathed for melee Necrons. Codes of Combat is a slam dunk for sure. Engage seems pretty good if you can keep your Warrior Blob and Destroyers in the right spots. Hmm, you could go for Purge the Vermin if you can keep them bottled up on their half of the table. Link to comment https://bolterandchainsword.com/topic/372557-aggressive-melee-necrons-w-tsk/#findComment-5770474 Share on other sites More sharing options...
