9x19 Parabellum Posted October 21, 2021 Share Posted October 21, 2021 I don't know about that; I'm with Charlo. I think a 5++ is exactly what a Repulsor needs to be in the game. Have you tried it or played it Medj? I think it can do some work. But the question as always is, what could something else do instead? Many better (admittedly non-transport) options lack a native invul save as well, so they're still the better pick with the buff. It is simply too expensive. -150 points would be ridiculous, but -50 would be the bare minimum, really. For the barebones cost of 295 points I'd rather take even two Vindicators with siege shields for 2+ 5++ T8 goodness. Might not transport Sword Brethren or anything else with them, but even so. Personally I'll just try to Impulsor with MM and see how it goes. I might rather put SB in there than BGV if fielding both at the same time, since the latter are more expensive and thus a bigger loss if the transport blows up with them still in it. Generally likely to lose at least one model from a squad of 5-6 after all, and with my rolls at least three. There is no other unit or 300 pts that can do what the Repulsor does, which is namely, offer limited immunity to your 5 Eradicators as they fire-and-fade (Devout Push). Additionally, it has a :cuss-ton of dakka. Link to comment Share on other sites More sharing options...
tvih Posted October 21, 2021 Share Posted October 21, 2021 There is no other unit or 300 pts that can do what the Repulsor does, which is namely, offer limited immunity to your 5 Eradicators as they fire-and-fade (Devout Push). Additionally, it has a -ton of dakka. Limited being the operative word - chances are you lose the Repulsor AND an Eradicator as the thing blows up, instead of just taking more Eradicators or whatever. Plus they can peek from behind obscuring terrain even without a transport. And there's better sources for the dakka, like Redemptors. Of course I'm not saying it can't be used and even do well on occasion - but 5++ or not, it's not good for the cost. Link to comment Share on other sites More sharing options...
9x19 Parabellum Posted October 21, 2021 Share Posted October 21, 2021 There is no other unit or 300 pts that can do what the Repulsor does, which is namely, offer limited immunity to your 5 Eradicators as they fire-and-fade (Devout Push). Additionally, it has a -ton of dakka. Limited being the operative word - chances are you lose the Repulsor AND an Eradicator as the thing blows up, instead of just taking more Eradicators or whatever. Plus they can peek from behind obscuring terrain even without a transport. And there's better sources for the dakka, like Redemptors. Of course I'm not saying it can't be used and even do well on occasion - but 5++ or not, it's not good for the cost. Well I intend to put it to the test. I find it hard to believe that T8, 16 wounds, -1 to hit (smoke) and 5++ is going to evaporate in 1 round of shooting if you're even remotely skilled at deployment. Link to comment Share on other sites More sharing options...
tvih Posted October 21, 2021 Share Posted October 21, 2021 Well I intend to put it to the test. I find it hard to believe that T8, 16 wounds, -1 to hit (smoke) and 5++ is going to evaporate in 1 round of shooting if you're even remotely skilled at deployment. Depends on the terrain of course - but it doesn't really matter if it's one turn or two if the passengers are inside in terms of collateral damage. The unit itself being hidden from the enemy on the long term means you can't put that awsumsauce dakka to use. A 300-point model shouldn't really have to just cower in hiding, but current meta is what it is. And regardless of all that, to reiterate: if it's not good without 5++ (and it isn't) and there are good units without 5++, the good units will still be better even if it does become decent. It's just that simple. But by all means do try it, I'm not saying not to - it doesn't have to be the best to use it if you have the model anyway. I wouldn't run to the store to buy one just because of 5++, though. Link to comment Share on other sites More sharing options...
9x19 Parabellum Posted October 21, 2021 Share Posted October 21, 2021 (edited) There are other ways to mitigate the amount of incoming fire without "hiding" it . Paying attention to shooting lanes, angles, and threat ranges (ie, deploying on flank) are all choices you can make to limit the shooting it receives. If you're supporting with a Techmarine (which I will be), you can always move it back for healing if it takes a pounding, and devout push your eradicators using other terrain for LoS. The key (for your opponent) with a unit like this is to pop it in 1 turn, before it can withdraw and/or heal and/or allow his own anti-tank to be taken out in a retaliatory strike. if he fails to do that, you've baited him out and he's in trouble. Edited October 21, 2021 by 9x19 Parabellum Link to comment Share on other sites More sharing options...
BLACK BLŒ FLY Posted October 21, 2021 Share Posted October 21, 2021 So can our Impulsors take MM now? Link to comment Share on other sites More sharing options...
T14 Posted October 21, 2021 Share Posted October 21, 2021 So can our Impulsors take MM now? affirmative! BLACK BLŒ FLY 1 Back to top Link to comment Share on other sites More sharing options...
jaxom Posted October 21, 2021 Share Posted October 21, 2021 Well I intend to put it to the test. I find it hard to believe that T8, 16 wounds, -1 to hit (smoke) and 5++ is going to evaporate in 1 round of shooting if you're even remotely skilled at deployment. Depends on the terrain of course - but it doesn't really matter if it's one turn or two if the passengers are inside in terms of collateral damage. The unit itself being hidden from the enemy on the long term means you can't put that awsumsauce dakka to use. A 300-point model shouldn't really have to just cower in hiding, but current meta is what it is. And regardless of all that, to reiterate: if it's not good without 5++ (and it isn't) and there are good units without 5++, the good units will still be better even if it does become decent. It's just that simple. But by all means do try it, I'm not saying not to - it doesn't have to be the best to use it if you have the model anyway. I wouldn't run to the store to buy one just because of 5++, though. Plus there’s the flip side: what else is in the list that’s surviving because unit X took such-and-such damage? The points hamper options there, but I think it should still be part of the discussion. Link to comment Share on other sites More sharing options...
tvih Posted October 21, 2021 Share Posted October 21, 2021 Plus there’s the flip side: what else is in the list that’s surviving because unit X took such-and-such damage? The points hamper options there, but I think it should still be part of the discussion. Sure - but indeed you pay so much for the transport ability. And T8 or not, it's a lot of points per wound for the Repulsor itself. At any rate the same points can be made over and over for each side ad nauseum, so best leave it for the table I reckon. Always a lot of variables, so in some cases it'll work out and in others it doesn't. jaxom 1 Back to top Link to comment Share on other sites More sharing options...
Maritn Posted November 20, 2021 Share Posted November 20, 2021 (edited) And regardless of all that, to reiterate: if it's not good without 5++ (and it isn't) and there are good units without 5++, the good units will still be better even if it does become decent. It's just that simple.I'm not completely sure about that point. A 5++ for a T8 vehicle is worth more than a 5++ for an infantry model I'd say. The best anti marine weapons are D2 with medium AP, so you'll probably not even benefit from the 5++ most of the time. The weapons used to fight a T8 vehicle on the other hand have AP -3 to -5, so the 5++ is always worth it. Edit: Of course Dreadnoughts are probably the best target for a 5++, but you won't run only Dreadnoughts. Add in a Repuslor, and it will be a difficult choice for your opponent. Edited November 20, 2021 by Maritn Link to comment Share on other sites More sharing options...
KnightofSigismund Posted December 10, 2021 Share Posted December 10, 2021 I just got ahold of 2 boxes of our sword bros, what’s the consensus on optimal loadout for these awesome guys? Thanks! Link to comment Share on other sites More sharing options...
BLACK BLŒ FLY Posted December 11, 2021 Share Posted December 11, 2021 If you’re gonna run two squads of ten then: 2x thunderhammer 2x lightning claws (pairs) 6x power sword Combat squad them as follows: Thunderhammer, Lightning Claws, 3x Power Sword templargdt and redmapa 2 Back to top Link to comment Share on other sites More sharing options...
Brother Kraskor Posted December 11, 2021 Share Posted December 11, 2021 Depends what job you want them to do! Arming them up with power weapons is one way. Another way is to keep them cheap as possible and go max Lightning Claws (so 1 pair for 5-man, 2 pairs for 10-man) and the rest Chainswords, supported by Helbrecht so they're all S5. Tiger9gamer 1 Back to top Link to comment Share on other sites More sharing options...
Marshal Mittens Posted December 11, 2021 Share Posted December 11, 2021 I think they missed the chance to let Templars upgrade their SGTs in other squads to sword bros with weapon options. Personally I think I will do 5, 2x Power Sword, Power Maul, Thunder Hammer, and Lighting Claws as a thematic unit for fun games. BLACK BLŒ FLY and Hadda 2 Back to top Link to comment Share on other sites More sharing options...
