MDops Posted December 21, 2021 Share Posted December 21, 2021 Hey all, This is aimed more at the people that have built the new sculpt Chaos Space Marines and the Terminators, would someone be able to confirm if the Power Axe hand on the marines is about the same size as the Terminator hand. Been trying to compare off Pics from the GW websize but i'm not feeling 100% about it before I plan to replace the Terminator fists with an Axe from a custom Bits site. Cheers Link to comment https://bolterandchainsword.com/topic/372686-terminator-power-axe-fist-size/ Share on other sites More sharing options...
Xenith Posted December 21, 2021 Share Posted December 21, 2021 Terminator hands are a bit bigger than regular marine hands, so the TDA axe hand will be larger than a regular marine hand. If the bitz axe you get is a bit for a normal marine, the hand will be smaller than the TDA one. Though people will hardly notice unless they look really closely. 1 Back to top Link to comment https://bolterandchainsword.com/topic/372686-terminator-power-axe-fist-size/#findComment-5774562 Share on other sites More sharing options...
MDops Posted December 21, 2021 Author Share Posted December 21, 2021 Cheers for that Been looking at the Pop Goes the Monkey stuff to fix the gaps in the GW offering (Combi Plasma and Power/Chain Axe options) Link to comment https://bolterandchainsword.com/topic/372686-terminator-power-axe-fist-size/#findComment-5774568 Share on other sites More sharing options...
Special Officer Doofy Posted December 21, 2021 Share Posted December 21, 2021 I'm curious if the regular chaos marine terminators will be limited to the wargear in the box like the DG terminators are in their new codex. Link to comment https://bolterandchainsword.com/topic/372686-terminator-power-axe-fist-size/#findComment-5774609 Share on other sites More sharing options...
Xenith Posted December 21, 2021 Share Posted December 21, 2021 I'm curious if the regular chaos marine terminators will be limited to the wargear in the box like the DG terminators are in their new codex. May be best to look at other armies released in the meantime? Thousand Sons, despite not having many options at all, were not. But that's pretty much just plasma pistols on sorcerers. Grey knights weren't - their purgation squads can still take 4 of a specific weapon. What about Orks? 1 Back to top Link to comment https://bolterandchainsword.com/topic/372686-terminator-power-axe-fist-size/#findComment-5774622 Share on other sites More sharing options...
Halandaar Posted December 21, 2021 Share Posted December 21, 2021 May be best to look at other armies released in the meantime? Thousand Sons, despite not having many options at all, were not. But that's pretty much just plasma pistols on sorcerers. Grey knights weren't - their purgation squads can still take 4 of a specific weapon. What about Orks? Can't speak to Orks but for Drukhari, Kabalite Warriors can still take double Blasters or Shredders despite only having one of each in the kit and Scourges can still take four of each weapon when the kit only contains one of everything except Shardcarbines. My suspicion is the loadout rules for CSM Terminators won't change because they've been around in a bunch of iterations for a very long time, and restricting loadouts to the current kit will invalidate a LOT of people's units. By comparison, the Blightlords kit has only ever contained those options and is only a single edition old, and really the only major reduction in the loadout rules from 8th to 9th is from "any model may taken any combi-weapon" to "only 3 models may take a combi-weapon and they all have to be different ones". They also actually gained an option; in 8th you had to choose between Blight Launcher, Autocannon and Plague Spewer. In 9th you can take the Spewer AND a Blight Launcher or Autocannon. 1 Back to top Link to comment https://bolterandchainsword.com/topic/372686-terminator-power-axe-fist-size/#findComment-5774629 Share on other sites More sharing options...
MDops Posted December 21, 2021 Author Share Posted December 21, 2021 May be best to look at other armies released in the meantime? Thousand Sons, despite not having many options at all, were not. But that's pretty much just plasma pistols on sorcerers. Grey knights weren't - their purgation squads can still take 4 of a specific weapon. What about Orks? Can't speak to Orks but for Drukhari, Kabalite Warriors can still take double Blasters or Shredders despite only having one of each in the kit and Scourges can still take four of each weapon when the kit only contains one of everything except Shardcarbines. My suspicion is the loadout rules for CSM Terminators won't change because they've been around in a bunch of iterations for a very long time, and restricting loadouts to the current kit will invalidate a LOT of people's units. By comparison, the Blightlords kit has only ever contained those options and is only a single edition old, and really the only major reduction in the loadout rules from 8th to 9th is from "any model may taken any combi-weapon" to "only 3 models may take a combi-weapon and they all have to be different ones". They also actually gained an option; in 8th you had to choose between Blight Launcher, Autocannon and Plague Spewer. In 9th you can take the Spewer AND a Blight Launcher or Autocannon. Maybe not the best comparison but from what I understand the Vanguard Vets have a limited selection on the sprue but the data sheet has the option to equip them with a full suite of Power Axes, while the Deathwatch Terminators really only have the options from the Terminator kits without kit-bashing and that's from a 9th ed books. getting away from the speculation, has anyone seen other good sites for terminator parts rather than bits sellers? Link to comment https://bolterandchainsword.com/topic/372686-terminator-power-axe-fist-size/#findComment-5774779 Share on other sites More sharing options...
Tallarn Commander Posted December 22, 2021 Share Posted December 22, 2021 I just got some nice combi-bolters from Pop Goes the Monkey. They have oodles of bitz that might fit Chaos Termies. https://popgoesthemonkey.com/collections/chaos Link to comment https://bolterandchainsword.com/topic/372686-terminator-power-axe-fist-size/#findComment-5775050 Share on other sites More sharing options...
