BLACK BLŒ FLY Posted December 26, 2021 Share Posted December 26, 2021 There are some units which can select an enemy unit to fight last at the start of the fight phase. If said unit uses heroic intervention to move in range to select an enemy unit which is performed at the start of the fight phase, this works ? I ask because previously elsewhere I was told no but have come to learn it’s common at least several GTs. Link to comment https://bolterandchainsword.com/topic/372730-heroic-intervention-and-fights-last/ Share on other sites More sharing options...
Khulu Posted December 26, 2021 Share Posted December 26, 2021 Heroic Intervention happens in the charge phase, so they'd be in combat at the start of the fight phase. That means they can use abilities that trigger at the start of the fight phase. Unless a rule specifies it can only be used if you charged or were charged, or has some other restriction, there's no reason it wouldn't work. BLACK BLŒ FLY 1 Back to top Link to comment https://bolterandchainsword.com/topic/372730-heroic-intervention-and-fights-last/#findComment-5776073 Share on other sites More sharing options...
Xenith Posted January 24, 2022 Share Posted January 24, 2022 (edited) Mortarion charges tactical squad and ends up within 3" of a judiciar After the charge phase is the Heroic intervention phase. Judiciar piles in 3" into combat with morty Start of fight phase, judiciar picks morty to be picked last All other chargers fight Tac squad/judiciar fight simultaneously Morty fights after all other eligible units have done so. I guess the confusion is that "The Heroic Intervention phase" is it's own thing, between the charge and fight phases. Edited January 24, 2022 by Xenith BLACK BLŒ FLY 1 Back to top Link to comment https://bolterandchainsword.com/topic/372730-heroic-intervention-and-fights-last/#findComment-5788199 Share on other sites More sharing options...
