Lord Blackwood Posted December 30, 2021 Share Posted December 30, 2021 I like the design strategy of the weapon , its very powerful. Hits Far, Inbuilt re roll , Wounds T7 on 2s , punches through INVUL SAVES , d3+6 damage In comparison the Repulsor Executioner is pretty lacking. I feel like the heavy laser destroyer probably needs a little bit of a tweak. Karhedron and Closet Skeleton 2 Back to top Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/ Share on other sites More sharing options...
Orange Knight Posted December 30, 2021 Share Posted December 30, 2021 Hah, it needs to be completely re-written, unfortunately. Let's hope we don't have to wait too long for a new codex. Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5777543 Share on other sites More sharing options...
Cpt_Reaper Posted December 30, 2021 Share Posted December 30, 2021 The Railgun is actually D3+9 Damage. Don't forget, successfully wounding the target does 3 mortal wounds. Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5777570 Share on other sites More sharing options...
Cruor Vault Posted December 30, 2021 Share Posted December 30, 2021 (edited) It's grossly bad for the health of the game. The extreme escalation of damage outputs is going to make 9th into an only slightly less toxic version of 7th edition's rocket tag (at least everything isn't invisible with a 2++ lol). Frankly the gun would still be fantastic if it lost the ignores INV saves. Getting 3 free MW just for wounding the target is extremely good. Ignoring INV saves makes a huge number of large profile models like Primarchs, TSK, and Knights all into highly risky prospects (IE unplayable). The only way back from this is for GW to proliferate the "Can only take X wounds per/phase" abilities that Ctan and Gaz have. The Executioner's main weapon is fantastic. The problem isn't with the weapon, it's with the platform and 9th's absurdly high damage units. Before things D3+3 weapons or Meltas with +4 damage a T8 W16 tank would have been decently resilient. GW needs to dial back the damage, not keep upping it. Edited December 30, 2021 by Cruor Vault Helias_Tancred, Bjorn Firewalker, dice4thedicegod and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5777571 Share on other sites More sharing options...
Orange Knight Posted December 30, 2021 Share Posted December 30, 2021 I made thus comment on the other topic also: This weapon really does remind me of the D weapons from 6th and 7th. I don't like how it's equally effective at destroying the most elite infantry. If you score a wound roll, you immediately remove 2 Custodes from the table. No saves, no invuls, no interaction. It will also deal a minimum of 10 wounds to a vehicle, on average 11, meaning that units like a Relic Contemptor Dreadnought are simply removed from the table on a roll of 2+ brother_b, Helias_Tancred and Cruor Vault 3 Back to top Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5777590 Share on other sites More sharing options...
Skywrath Posted December 30, 2021 Share Posted December 30, 2021 I think we might have found the daddy of the Repulsor Executioner, folks. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5777625 Share on other sites More sharing options...
Helias_Tancred Posted December 30, 2021 Share Posted December 30, 2021 Things like this, and previous golly gees have soured me on 9th beginning a while back. I still play, but I've got some beefs lol. One of the major themes here, dial back damage output, I agree with completely. Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5777629 Share on other sites More sharing options...
Karhedron Posted December 30, 2021 Share Posted December 30, 2021 One thing to remember about these high damage weapons is that GW seems to balance stuff for use on tables that have fairly dense terrain. I think the idea is that players should be able to avoid exposing valuable units to such firepower if they wish, meaning it then becomes a tactical decision as to whether to risk the firepower for the reward of doing more damage to the enemy. This is what GW thinks 9th edition boards should look like. If you consider this, there are huge swathes of board where you can hide even a big model like a Daemon Primarch. Those larger terrain pieces are over 12" across. brother_b, Lord Blackwood, Dracos and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5777631 Share on other sites More sharing options...
Lord_Ikka Posted December 30, 2021 Share Posted December 30, 2021 Not a big fan of the mortal wounds- if anything they should proc on 6+ to Wound and be d3 rather than fully auto. Invuln removal would be much better if the AP was -3 or 4 rather than -6, because then you at least have a possibility of a save. The base damage is good, but not overwhelming- d3 + 6 is higher that almost every other single shot weapon, but truly a real anti-tank weapon. The points and the rest of the codex will determine if the railgun Hammerhead will change the meta; they still don't have Obsec and can only kill a max of 1 light tank/4 infantry per turn (unless they use the strat on a big unit) and 9th is all about holding objectives rather than killing off your enemy. Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5777632 Share on other sites More sharing options...
Closet Skeleton Posted December 30, 2021 Share Posted December 30, 2021 (edited) The Executioner's main weapon is fantastic. The problem isn't with the weapon, it's with the platform and 9th's absurdly high damage units. The Executioner's main weapon is garbage compared with the melta units in the same book. Nobody used lascannons or Railguns in 8th. Fixing internal balance is not power creep. The Hammerhead is just its main gun, the Executioner is a moving fortress of weapons. If the Hammerhead misses with its gun then the whole unit is a dud for a turn which the Executioner can miss with its main gun and still kill whole squads of guardsmen. The Gladiator Lancer is a better comparison that unfortunately is tied to the same kind of gun as the Executioner. Both need to be 3+d6 to make them not a complete joke compared to melta and wouldn't be unbalanced at 6+d3. Its too early to say if the Tau codex will be bad or good for game balance but this kind of drastic experimentation in damage output is just necessary to balance vehicles that rely on a single shot main gun. If you score a wound roll, you immediately remove 2 Custodes from the table. No saves, no invuls, no interaction. I must have missed the warhammer community article or leak that told us arcane bio-alchemy (or whatever transhuman physiology is called for custodes) was gone because that stratagem can still heavily neuter this gun. Edited December 30, 2021 by Closet Skeleton Lord Blackwood 1 Back to top Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5777643 Share on other sites More sharing options...
Brother Kraskor Posted December 30, 2021 Share Posted December 30, 2021 I wonder how many points the Hammerhead will cost. I expect there will be rage if it costs much less than 200pts. Mortal Wounds, eh. chuckles in Templar Karhedron and BLACK BLŒ FLY 2 Back to top Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5777644 Share on other sites More sharing options...
Sergeant Centurion Posted December 30, 2021 Share Posted December 30, 2021 Nah, dont worry, they will patch it in a few months or bring another weapon more powerfull. Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5777667 Share on other sites More sharing options...
Captain Idaho Posted December 30, 2021 Share Posted December 30, 2021 The problem with having to patch it (and other stuff) so early is twofold: 1) The ever evolving changing of rules we have to keep up with. 2) It shows a lack of playtesting and incompetence or it's deliberately done to sell models. Don't get me wrong, I'm up for GW patching problems but so far they've only really changed points rather than stats and printed special rules. I fear the worst here. Now how will we deal with this? Less vehicles will be seen on the table, which are already in low numbers. But perhaps more lighter vehicles would work? Kill 1 of 3 Land Speeders and I still have 2 Rhinos and a pair of Dreads. SillyDreadnought and Cruor Vault 2 Back to top Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5777672 Share on other sites More sharing options...
KnightofSigismund Posted December 30, 2021 Share Posted December 30, 2021 I just don’t understand why the repulsor costs so much, I never looked at the price until this morning and nearly spit out my damn coffee. 9x19 Parabellum 1 Back to top Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5777686 Share on other sites More sharing options...
Lord Blackwood Posted December 30, 2021 Author Share Posted December 30, 2021 I just don’t understand why the repulsor costs so much, I never looked at the price until this morning and nearly spit out my damn coffee. I think its just cursed with trying to be too much. 6 slot transport is really redundant you are better off taking an impulsor , Gun Fortress sure but were talking 2 main guns and then a plethora of just weight of fire dakka. Dont get me wrong I love all the primaris grav tanks , I just feel like they need gentle adjustments and a sense of direction. There is a reason why people dont put Spartans and Land Raiders on the board and why you certainly dont fill them with things you need to get from point a to point b Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5777699 Share on other sites More sharing options...
phandaal Posted December 30, 2021 Share Posted December 30, 2021 The problem with having to patch it (and other stuff) so early is twofold: 1) The ever evolving changing of rules we have to keep up with. 2) It shows a lack of playtesting and incompetence or it's deliberately done to sell models. Don't get me wrong, I'm up for GW patching problems but so far they've only really changed points rather than stats and printed special rules. I fear the worst here. Now how will we deal with this? Less vehicles will be seen on the table, which are already in low numbers. But perhaps more lighter vehicles would work? Kill 1 of 3 Land Speeders and I still have 2 Rhinos and a pair of Dreads. It is certainly done to sell models. Everything they do is done to sell models in some way or another. Although if you could somehow ask the person who made this rule they would probably say something like "we just wanted to give people something cool." Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5777736 Share on other sites More sharing options...
Brother Kraskor Posted December 30, 2021 Share Posted December 30, 2021 Watch one of their HQs give a shoot twice ability to a unit within 6". phandaal 1 Back to top Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5777821 Share on other sites More sharing options...
tychobi Posted December 31, 2021 Share Posted December 31, 2021 I like it. A weapon to fear to be sure. Wonder how many points a hammerhead will cost now? Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5778010 Share on other sites More sharing options...
Malakithe Posted December 31, 2021 Share Posted December 31, 2021 Man i feel sorry for Necron players lol WrathOfTheLion, Karhedron and BLACK BLŒ FLY 3 Back to top Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5778042 Share on other sites More sharing options...
phandaal Posted December 31, 2021 Share Posted December 31, 2021 Well Valrak just said he heard Space Marines are getting a new non-LoS rocket unit. The arms race continues! Malakithe 1 Back to top Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5778163 Share on other sites More sharing options...
Malakithe Posted December 31, 2021 Share Posted December 31, 2021 Good ol escalation Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5778170 Share on other sites More sharing options...
BLACK BLŒ FLY Posted December 31, 2021 Share Posted December 31, 2021 Quantum shielding will help Necrons. Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5778333 Share on other sites More sharing options...
Lord_Ikka Posted January 1, 2022 Share Posted January 1, 2022 Quantum shielding will help Necrons. Except for the Monolith... Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5778346 Share on other sites More sharing options...
Malakithe Posted January 1, 2022 Share Posted January 1, 2022 The issue with Necrons is all their that are supposed to be super strong are all based on d6 which is trash. Everyone else out there has something like d3+x or d6+x Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5778406 Share on other sites More sharing options...
BloodyB Posted January 1, 2022 Share Posted January 1, 2022 I think that I'll be taking on my local T'au player with a little more caution from now on. I feel like while the changes are a sign of power creep, it isn't as bad as I thought it would be. My only quibble with this unit now is the ignores Invuls bit, it just seems like they were trying to make these things viable, and leaned too hard into it. On the other hand, from now on I will be taking a unit of cheap deepstrike models, probably assault marines, just to tie things like this up. A melta, eviscerator and maybe a power weapon on the Sgt and they shouldn't have any trouble bracketing the thing at least, backed up by Suppressors and they should do that job well. Link to comment https://bolterandchainsword.com/topic/372764-tau-hammerheads-main-gun-vs-repulsor-exeuctioner-main-gun/#findComment-5778451 Share on other sites More sharing options...
