hermanista Posted December 31, 2021 Share Posted December 31, 2021 (edited) How do, So, following up on my Pre-Unification questions of late in other groups, something a bit more visual to follow it up. For a long time I've really liked the work of certain creators in biggerising Marines, especially when making Heresy models, Doghouse and Apologist were huge inspirations with their truescale/Artscale marines. Now a few folks have started an Age of Unification project on Twitter and people have jumped in with both feet working on Techno-Barbarians and Thunder Warriors. However, wanting to be a bit different, I've decided to go with some first generation Astartes of the First Legion. Only biggerised! Now I realise there's a whole conversation about how much interaction marines had in the Unification Wars, but I guess it makes it interesting - there's some artistic leeway I'm sure. So these are some of those first models I've put together, that with get a ceremite grey colour scheme when I get to add paint to them. Theres few pics show them alongside a Primaris marine to show off some scale, as well as a couple of pictures if something I started working on yesterday. FYI the marines are a combo of 120/130% size, the rhino is 140% but likely to be reprinted a bit bigger again to make it a bit more realistic. Hopefully you enjoy Cheers Edited December 31, 2021 by hermanista Ryltar Thamior, CypherThe1stFallen, Doghouse and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/372777-age-of-unification-astartes-artscale-marines/ Share on other sites More sharing options...
Guest Triszin Posted December 31, 2021 Share Posted December 31, 2021 Nice modeling Link to comment https://bolterandchainsword.com/topic/372777-age-of-unification-astartes-artscale-marines/#findComment-5778208 Share on other sites More sharing options...
Wulf Vengis Posted December 31, 2021 Share Posted December 31, 2021 Did you 3d print all that yourself? Those look amazing and really fit the head canon look for pre/early crusade. That rhino/razor/predator looks fantastic and a slightly larger size would look even better. Good work regardless. Keep that up. You can pm the answer if it might break board rules. Link to comment https://bolterandchainsword.com/topic/372777-age-of-unification-astartes-artscale-marines/#findComment-5778272 Share on other sites More sharing options...
Pearson73 Posted January 1, 2022 Share Posted January 1, 2022 These chaps look great, I particularly like the helmet design and the Predator. Link to comment https://bolterandchainsword.com/topic/372777-age-of-unification-astartes-artscale-marines/#findComment-5778458 Share on other sites More sharing options...
Doghouse Posted January 1, 2022 Share Posted January 1, 2022 I think you are off to a very good start and I am in the middle of something similar funnily enough but set much later mid-heresy. There are actual FW measurements floating about for vehicles and whatnot but I have found that what works best is if you scale the Rhino so that a marine can stand with his head slightly ducked down in the door ways on the side. Mine are set at 65mm from the base of the track to the top of the hull and they are very big but look amazing. The actual lore Rhino height is 3.6 metres with a marine standing at around 2.2-2.3 metres for some idea of actual size, but the beauty of the Heresy and Unification eras is that it can be viewed through a rose tinted lens rather than be factual which is why I kickstarted the truescale movement in the first place in Pre-Heresy. In truth though go with what looks best to you, regardless of what anyone else says and I'll be watching with interest. :tu: Link to comment https://bolterandchainsword.com/topic/372777-age-of-unification-astartes-artscale-marines/#findComment-5778471 Share on other sites More sharing options...
