Hannibal Posted January 2, 2022 Share Posted January 2, 2022 Hi all, I just wonder how the Demons of the Ruinstorm's deployment rules interact with Zone Mortalis. Is is the exact same way ie you place your rift markers and start from there? Do the Demons also have to use on of the ZM special army organization charts? Thanks in advance! Link to comment https://bolterandchainsword.com/topic/372801-demons-of-the-ruinstorm-and-zone-mortalis/ Share on other sites More sharing options...
Spagunk Posted January 2, 2022 Share Posted January 2, 2022 Ruinstorm deamons indeed deploy via rift marker mechanic generally. But the rift markers don't lend to good ZM boards. If possible, I'd try to get your group to allow small blasts instead of the rifts as it may be unlikely that you can get anything on the board using the standard rift size. In other words: RAW, they don't work unless you have a big open area. Most missions require a Org Chart, even if its not specifically the ZM ones. However you're likely going to be stuck with the 3 main ones in a typical ZM match: Attacker Force Org, Defender Force Org or the standard one. Brofist 1 Back to top Link to comment https://bolterandchainsword.com/topic/372801-demons-of-the-ruinstorm-and-zone-mortalis/#findComment-5779052 Share on other sites More sharing options...
