Montoya Posted January 23, 2022 Share Posted January 23, 2022 Question for everyone. Can you cast temporal surge and then still charge? I can't find anything that says you cannot, but GW generally has clamped down on that for most strategems and psychic powers. I just wanted to make sure i'm not cheating if there is something i'm just missing that would preclude it Link to comment https://bolterandchainsword.com/topic/373041-temporal-surge/ Share on other sites More sharing options...
Brother Kraskor Posted January 24, 2022 Share Posted January 24, 2022 I would have thought so, provided you didn't Advance or Fall back in your Movement phase. Link to comment https://bolterandchainsword.com/topic/373041-temporal-surge/#findComment-5787851 Share on other sites More sharing options...
Xenith Posted January 24, 2022 Share Posted January 24, 2022 Yep, this is fine - the unit just makes a normal move, which does not prevent them from charging. They only cannot charge if some other rule, like advancing or falling back, would prevent them from doing so. Note that you also can't do things like cast temporal surge after relocating through the Duplicity spell or crystal to get a short charge. Lucky_Lee 1 Back to top Link to comment https://bolterandchainsword.com/topic/373041-temporal-surge/#findComment-5787871 Share on other sites More sharing options...
Brother Kraskor Posted January 24, 2022 Share Posted January 24, 2022 Note that you also can't do things like cast temporal surge after relocating through the Duplicity spell or crystal to get a short charge. Ah! Where's this laid down please? Link to comment https://bolterandchainsword.com/topic/373041-temporal-surge/#findComment-5787883 Share on other sites More sharing options...
Xenith Posted January 24, 2022 Share Posted January 24, 2022 (edited) Note that you also can't do things like cast temporal surge after relocating through the Duplicity spell or crystal to get a short charge. Ah! Where's this laid down please? I think it's in the main rulebook, repositioned and replacement units: The unit cannot make a Normal Move, Advance, Fall Back or Remain Stationary that turn for any reason. Emphasis mine. Edited January 24, 2022 by Xenith WarriorFish, Brother Kraskor and Dr_Ruminahui 3 Back to top Link to comment https://bolterandchainsword.com/topic/373041-temporal-surge/#findComment-5788116 Share on other sites More sharing options...
Montoya Posted January 26, 2022 Author Share Posted January 26, 2022 Ah. That's what i was looking for. Thanks Xenith Link to comment https://bolterandchainsword.com/topic/373041-temporal-surge/#findComment-5789184 Share on other sites More sharing options...
jgascoine011 Posted January 30, 2022 Share Posted January 30, 2022 One question Can you use temporal surge to get out of combat and then shoot and charge. I am guessing no but just wondering Link to comment https://bolterandchainsword.com/topic/373041-temporal-surge/#findComment-5791176 Share on other sites More sharing options...
Naryn Posted January 30, 2022 Share Posted January 30, 2022 No, because temporal surge just lets you make a normal move, and you can't normal move out of combat. However, we CAN use the duplicity cult spell to teleport out of combat, shoot, then charge, if that helps! Xenith and Paladin777 2 Back to top Link to comment https://bolterandchainsword.com/topic/373041-temporal-surge/#findComment-5791177 Share on other sites More sharing options...
Xenith Posted January 30, 2022 Share Posted January 30, 2022 As above - Tempral surge is a 'normal' move - the different kinds of moves you can make in the movement phase are detailed in the rulebook. Link to comment https://bolterandchainsword.com/topic/373041-temporal-surge/#findComment-5791337 Share on other sites More sharing options...
Brother Kraskor Posted January 31, 2022 Share Posted January 31, 2022 So I understand why you can't Temporal Surge after using the Crystal, or after deep striking. Because the Crystal/deep strike says they are set up in the Reinforcements step of the movement phase, and that is where the rule which says no Normal Move is contained. But Duplicity spell does not act this way. It's after the Reinforcements step, it's in the Psychic phase. It just says set them up, not set them up following the rules for the Reinforcements step. So why no Duplicity spell & Temporal Surge? Link to comment https://bolterandchainsword.com/topic/373041-temporal-surge/#findComment-5791640 Share on other sites More sharing options...
Xenith Posted January 31, 2022 Share Posted January 31, 2022 So I understand why you can't Temporal Surge after using the Crystal, or after deep striking. Because the Crystal/deep strike says they are set up in the Reinforcements step of the movement phase, and that is where the rule which says no Normal Move is contained. But Duplicity spell does not act this way. It's after the Reinforcements step, it's in the Psychic phase. It just says set them up, not set them up following the rules for the Reinforcements step. So why no Duplicity spell & Temporal Surge? You're right in that Duplicity spell doesn't set up units according to the reinforcement units rules, however once you reposition them they are subject to the 'repositioned and replaced units" rule, which also forbids making a normal move. Brother Kraskor 1 Back to top Link to comment https://bolterandchainsword.com/topic/373041-temporal-surge/#findComment-5791692 Share on other sites More sharing options...
Brother Kraskor Posted January 31, 2022 Share Posted January 31, 2022 Ah right at the bottom. I was looking in the wrong place, thank you. Link to comment https://bolterandchainsword.com/topic/373041-temporal-surge/#findComment-5791764 Share on other sites More sharing options...
