Captain Idaho Posted January 29, 2022 Share Posted January 29, 2022 As GW does, they discontinued a product I need for my armies to make them at least look uniform. Does anyone know if there's any alternative tufts that look like this one for GW? Link to comment https://bolterandchainsword.com/topic/373121-citadel-middenland-tuft-alternative/ Share on other sites More sharing options...
Lord_Ikka Posted January 29, 2022 Share Posted January 29, 2022 Maybe the Army Painter Winter tufts? https://shop.thearmypainter.com/us/bf4223p WrathOfTheLion 1 Back to top Link to comment https://bolterandchainsword.com/topic/373121-citadel-middenland-tuft-alternative/#findComment-5790626 Share on other sites More sharing options...
Slave to Darkness Posted January 29, 2022 Share Posted January 29, 2022 (edited) Theres a few sellers on ebay that sell tufts that I stumbled across before xmas, reasonable prices as well if memory serves, could be worth looking there. Just found this one, got some interesting stuff, I never thought of using lavender grass tufts before, may compliment my Eldar... https://www.ebay.co.uk/usr/serious-play?_trksid=p2047675.m3561.l2559 Edited January 29, 2022 by Slave to Darkness WrathOfTheLion 1 Back to top Link to comment https://bolterandchainsword.com/topic/373121-citadel-middenland-tuft-alternative/#findComment-5790629 Share on other sites More sharing options...
WrathOfTheLion Posted January 29, 2022 Share Posted January 29, 2022 (edited) I've got an unopened one sitting on my desk here, didn't even know they'd discontinued it. I have some greenstuff world and some army painter ones, I can see about comparing the two to see if any of what I have is close. I guess I'll need to categorize a matching one anyways. I'll do that this weekend and get back to you if I think any are close. I can at least rule a various assortment of tufts out if I don't find a match. Edited January 29, 2022 by WrathOfTheLion Captain Idaho 1 Back to top Link to comment https://bolterandchainsword.com/topic/373121-citadel-middenland-tuft-alternative/#findComment-5790640 Share on other sites More sharing options...
Captain Idaho Posted January 29, 2022 Author Share Posted January 29, 2022 Yeah a matching one is crucial really. Army Painter has some good tufts but can't tell if Swamp Tufts is the right colour or not. Link to comment https://bolterandchainsword.com/topic/373121-citadel-middenland-tuft-alternative/#findComment-5790730 Share on other sites More sharing options...
WrathOfTheLion Posted January 30, 2022 Share Posted January 30, 2022 Swamp or winter seem the most likely match from army painter. Greenstuff world beige looks like it might match as well. None of the ones I have seem to match all that well. Middenland tufts look to combine a green component with kind of a dry grass component, whereas all the tufts I looked at only do one of the two. As the dry grass component is stronger, I would try to match that. Captain Idaho 1 Back to top Link to comment https://bolterandchainsword.com/topic/373121-citadel-middenland-tuft-alternative/#findComment-5790977 Share on other sites More sharing options...
Closet Skeleton Posted January 30, 2022 Share Posted January 30, 2022 I have some spare Middenland Tuft (somewhere) and use Army Painter Swamp on my Primaris army and they don't match. Winter is even paler. I think Middenland Tuft might match with an older Army Painter Swamp from 10 years ago I used on my Angels Encarmine but that's not available any more. Captain Idaho 1 Back to top Link to comment https://bolterandchainsword.com/topic/373121-citadel-middenland-tuft-alternative/#findComment-5791098 Share on other sites More sharing options...
Arkhanist Posted January 31, 2022 Share Posted January 31, 2022 (edited) I think the closest match I have would be mininatur (also known as silflor) "late fall", a german railway grass maker. I've seen them branded various ways; calcareous tufts, karst tufts, buffalo grass (us) and two colour grass depending upon seller, but the best bet is to go by the number. You can also usually find them in model railway shops if you want to compare options in person - they do a TON of different colours. Here's 737-34s (top) late fall and 737-33s (bottom) early fall. I tend to do a mix of both types for arid/dry bases e.g. They do shorter tuft versions as 737-24s and 737-23s (more suited for 15mm gaming). The 's' indicates 'sample' strips (mine above are single 15cmx4cm sheets doubled over); they're also available in much larger bulk sheets which are more cost effective if you're doing a model railway or scenery piece. For what it's worth, army painter used to be silflor grass rebranded, but I don't know if it is any more. Edited January 31, 2022 by Arkhanist Captain Idaho and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/373121-citadel-middenland-tuft-alternative/#findComment-5791474 Share on other sites More sharing options...
