Brother Clavero Posted March 7, 2022 Share Posted March 7, 2022 So I decided to venture out a bit from my regular acrylic paints and try some streaking grime. I had wanted to use AK interactive but have been reading that they changed their original colour to something darker. Could anyone recommend an alternative or even how to mix up my own batch ? Link to comment https://bolterandchainsword.com/topic/373512-streaking-grime-which-one/ Share on other sites More sharing options...
Firedrake Cordova Posted March 7, 2022 Share Posted March 7, 2022 (edited) I've not used any of the enamel- or oil-based grimes, but I would imagine that you could make your own using artist's oil paint in the colour of your choice (probably one of the umbers, sienna, or sepia), and diluting it down to a wash. [Historical modellers seem to suggest this works] In case you missed it, the Vallejo streaking grime is acrylic unlike the others, so will obviously behave differently (not that you get a surprise!), although you can still manipulate it in a similar manner if you use Airbrush Thinner. Edited March 7, 2022 by Firedrake Cordova Link to comment https://bolterandchainsword.com/topic/373512-streaking-grime-which-one/#findComment-5802584 Share on other sites More sharing options...
Brother Clavero Posted March 7, 2022 Author Share Posted March 7, 2022 Thanks for the response! I wasn't aware Vallejo made this. I will definitely be giving it a try ! Link to comment https://bolterandchainsword.com/topic/373512-streaking-grime-which-one/#findComment-5802585 Share on other sites More sharing options...
Tallarn Commander Posted March 15, 2022 Share Posted March 15, 2022 As Firedrake Cordova mentions, I use a wash of oil painted mixed with white spirits. Here I used burnt umber over a Zamesi Desert basecoat. And here I just used black oil paint mixed with white spirits for my Renegades and Heretics Russ Brother Clavero and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/373512-streaking-grime-which-one/#findComment-5804801 Share on other sites More sharing options...
Solution sarabando Posted March 15, 2022 Solution Share Posted March 15, 2022 I find using standard artists oils burnt umber is one of the best all around grimes. Just mix it thin with mineral spirits and away you go, super cheap and easy to use. Tallarn Commander and Brother Clavero 2 Back to top Link to comment https://bolterandchainsword.com/topic/373512-streaking-grime-which-one/#findComment-5804876 Share on other sites More sharing options...
Bung Posted March 16, 2022 Share Posted March 16, 2022 Here is a list of oil paints and their uses http://www.bolterandchainsword.com/topic/372745-oil-paints-which-and-how-to-use/?do=findComment&comment=5776607 Brother Clavero 1 Back to top Link to comment https://bolterandchainsword.com/topic/373512-streaking-grime-which-one/#findComment-5804986 Share on other sites More sharing options...
