Commander Nicky Posted April 15, 2022 Share Posted April 15, 2022 (edited) Dear All I am in the process of creating a samurai themed SM army, and would like to have some heads with a samurai look-alike. I have however a hard time finding a supplier who produces them. I have tryed Puppetwar but they are sligtly to small in dimension. Anyone who know a producer who makes them? Kind Regard Edited May 8, 2022 by Commander Nicky Link to comment https://bolterandchainsword.com/topic/373862-resin-samurai-helmet-heads-where-to-buy/ Share on other sites More sharing options...
Bung Posted April 15, 2022 Share Posted April 15, 2022 Kromlech has some Cyber Samurai Heads. Commander Nicky 1 Back to top Link to comment https://bolterandchainsword.com/topic/373862-resin-samurai-helmet-heads-where-to-buy/#findComment-5816171 Share on other sites More sharing options...
Brother Tyler Posted April 15, 2022 Share Posted April 15, 2022 A more economical option might be to simply incorporate the datemono/tatemono (decorations), especially the maedate (front crest), rather than purchasing an army's worth of full [space] kabuto. Simple maedate might be made from plasticard, and you could get quite a few from a single sheet (probably enough for a full company). You might then incorporate menpō (alternately mengu or men-yoroi)(facial armor) for officers/characters. A simple source of menpō might be from the Blood Angels kits, though you would have to do some cutting to get the faces under regular helmets. Alternately, you could look at the heads/faces of other suitable models (especially daemons and monsters since menpō were sometimes crafted to resemble such). You could reserve the most distinctive (i.e., those you purchase) for the highest ranking officers (Chapter Master, Captains, etc.). Depending on where you play, conversions using only GW parts and scratch-built components might be beneficial (i.e., if you plan on playing at a GW store or in a GW event). Such considerations are irrelevant if you're not playing in a setting where conversion parts are restricted in some way. Commander Nicky 1 Back to top Link to comment https://bolterandchainsword.com/topic/373862-resin-samurai-helmet-heads-where-to-buy/#findComment-5816202 Share on other sites More sharing options...
Rik Lightstar Posted April 16, 2022 Share Posted April 16, 2022 The Puppetswar ones are available as an STL too, so if you like them and know someone with a 3d printer then you can scale them up a bit. Rik Commander Nicky 1 Back to top Link to comment https://bolterandchainsword.com/topic/373862-resin-samurai-helmet-heads-where-to-buy/#findComment-5816679 Share on other sites More sharing options...
ranulf the revenant Posted April 22, 2022 Share Posted April 22, 2022 https://thecustombit.com/categoria-producto/physical/army-faction-p/portector-of-humanity-p/samurai/ Another option. I guess they're 3d-printed though... Commander Nicky 1 Back to top Link to comment https://bolterandchainsword.com/topic/373862-resin-samurai-helmet-heads-where-to-buy/#findComment-5818414 Share on other sites More sharing options...
