Montuhotep Posted April 19, 2022 Share Posted April 19, 2022 Not sure if these even exist anywhere, but I thought I'd throw the question out and see. Does anyone know of any water-slide decals of Ancient Egyptian Hieroglyphs? I don't mean the horrendous Thousand Sons knock-off that GW thinks is Ancient Egypt, but proper Nile Valley stuff. I've looked at Fallout Hobbies and not seen anything to float my boat whilst people like Scibor have stuff that's about as Egyptian as the Great Wall of China! Anyone? T'would be marvellous if so.... Link to comment https://bolterandchainsword.com/topic/373907-egyptian-hieroglyph-transfers-where-from/ Share on other sites More sharing options...
Guest Posted April 20, 2022 Share Posted April 20, 2022 Scumb4g I got my campaign badges from. Link to comment https://bolterandchainsword.com/topic/373907-egyptian-hieroglyph-transfers-where-from/#findComment-5817539 Share on other sites More sharing options...
Brother Tyler Posted April 20, 2022 Share Posted April 20, 2022 The best answer I have is to check some makers of historical models (generally outside the remit of the B&C). If there aren't any, you can always make your own... https://www.youtube.com/results?search_query=making+waterslide+decals+tutorial Simply find good digital versions of the hieroglyphs that you want to use (vector are best). Montuhotep 1 Back to top Link to comment https://bolterandchainsword.com/topic/373907-egyptian-hieroglyph-transfers-where-from/#findComment-5817541 Share on other sites More sharing options...
Magos Takatus Posted April 20, 2022 Share Posted April 20, 2022 I agree with Wolf Guard Einar. If you cannot find The hieroglyphics you require then Scumb4g Kustoms are a good supplier. I've tried both Fallout Hobbies and Scumb4g Kustoms and while both produced good results I've found Scumb4g Kustoms to be considerably more reliable over several orders. I agreed to an order for my Imperial Knight's custom decals through Fallout and never received my decals, though they produced my custom Forge World decals so they can produce good quality work when it suits them. Would https://ginfritter.com/egyptian-hieroglyph-waterslide-decal-transfers/ be of any use? Montuhotep 1 Back to top Link to comment https://bolterandchainsword.com/topic/373907-egyptian-hieroglyph-transfers-where-from/#findComment-5817576 Share on other sites More sharing options...
Montuhotep Posted April 20, 2022 Author Share Posted April 20, 2022 Would https://ginfritter.com/egyptian-hieroglyph-waterslide-decal-transfers/ be of any use? Gaaah! I completely bloody forgot that Grinfritter still exist! Thank'ee. Magos Takatus 1 Back to top Link to comment https://bolterandchainsword.com/topic/373907-egyptian-hieroglyph-transfers-where-from/#findComment-5817622 Share on other sites More sharing options...
