Valkyrion Posted April 24, 2022 Share Posted April 24, 2022 Silly question sunday! At what point do you halve incoming damage? e.g, a model is hit twice a weapon which causes 3 damage, totalling 6. Do I halve the 6 to three, or do I halve the 3 rounding up twice, totalling 4? Daimyo-Phaeron Lenoch 1 Back to top Link to comment https://bolterandchainsword.com/topic/373942-halving-incoming-damage/ Share on other sites More sharing options...
Daimyo-Phaeron Lenoch Posted April 24, 2022 Share Posted April 24, 2022 I think you halve each individual hit. For example, rules that reduce damage, like the Necron Warlord Trait 'Enduring Will', specify "Each time an attack is allocated to this Warlord, subtract 1 from the damage characteristic of that attack (to a minimum of one)." So, for instance, if a squad of Hellblasters fires overcharged plasma at a Catacomb Command Barge with this Warlord trait, and after his invulerable save he takes three wounding hits at Damage 2 each, each wounding hit would have its damage reduced by one, so he would take 3 one-damage hits instead of three two-damage hits. If he was then subsequently hit by a lascannon, which rolled high on its damage roll for 5 wounds, his Warlord Trait would reduce it to four wounds. I would reason that the same logic applies to whatever rule is halving the damage--you'd halve each individual wounding hit, rounding as the rule directs. Dr_Ruminahui, TrawlingCleaner and Karhedron 3 Back to top Link to comment https://bolterandchainsword.com/topic/373942-halving-incoming-damage/#findComment-5819039 Share on other sites More sharing options...
TrawlingCleaner Posted April 25, 2022 Share Posted April 25, 2022 Brother Lenoch has it, the idea is that the game is supposed to be rolling each dice one at a time but is "fast rolled" ie you roll multiple dice together. As each wound is a seperate entity, you apply the half damage to each successful wound Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/373942-halving-incoming-damage/#findComment-5819256 Share on other sites More sharing options...
