Cpt_Reaper Posted August 4, 2022 Share Posted August 4, 2022 1 minute ago, Inquisitor_Lensoven said: Put every strat into datasheets? No. butnmost strats could either be an army wide rule, or a rule specifically in a unit’s data sheet. you keep harping on not looking back, and that’s really stupid. Previous editions got some things right, and it is absolutely valid to hold those things up as examples If it was gotten right, and it fits with the design philosophy of the current editions mechanics, it was brought forward. If it worked before but wasn't going to work now, it was left behind. If a stratagem could be an army wide rule, or a rule on a datasheet, why can't they remain a single use ability with a cost of a finite resource? You'd raise unit costs for an ability you might use rather than a stratagem that you pay a cost for when you need it. Stratagems have their place in 9th. They will have their place in 10th. They don't have their place when you compare the current edition to anything before 8th, because those ditions weren't written with Stratagems in mind as a core mechanic. Schlitzaf 1 Back to top Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5853287 Share on other sites More sharing options...
Slave to Darkness Posted August 4, 2022 Share Posted August 4, 2022 But even GW are looking at older editions, they have reintroduced the movement stat, instead of deathstar units they now have characters give off aura bubbles just like in 2nd edition, theres only so much GW can do with a ruleset over many editions without dipping back into their own rules or something similar to other companies. If they do a fresh reset again for the love of god GW raise some stats to above ten, and break away from a D6 system then at least we can have accurate representation of something without having to layer on bandaid rulesand buffs/nerfs to make it a bit better than a guardsman but not quite as good as an assassin, if it isnt working on the next balance update pop up the stat in question by a point or two. Khornestar and phandaal 2 Back to top Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5853298 Share on other sites More sharing options...
Cpt_Reaper Posted August 4, 2022 Share Posted August 4, 2022 I've been pondering that myself. GW have made D10's in the form of wound markers, and the apocalypse dice set has, in addition to a boatload of D6, D12s. Perhaps a combination of all 3 would work better than just have every system tied to D6? Characteristic Tests would all use D10. To Wound could require one of either D6, 10 or 12, with maybe the idea that top end toughness simply can't be harmed with a D6? Say a Lasgun is a straight D6, a Bolter is D6+1. Wounding a Guardsman might need a result of 4+, Wounding a Space Marine might need a 6+, Wounding a Carnifex might need a 8? Re-Rolls are tied to Character Aura's only. Stratagems cannot grant a re-roll under any circumstances, but might give +1 to a wound roll for a certain weapon? Taking a little inspiration from previous editions in that some small arms just can't harm tougher targets, and improving stratagems by giving a small arm a chance to harm the next tier but still unable to harm the tier above that. Slave to Darkness 1 Back to top Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5853311 Share on other sites More sharing options...
FormelyKnownAsSmashyPants Posted August 4, 2022 Share Posted August 4, 2022 (edited) On 8/1/2022 at 7:33 PM, Remain_Indoors said: 100% agree with this and its my biggest hope for the next edition. Strategems have become the new Formations of 40k. What started as an interesting, cool idea, has gotten completely out of hand. I don’t disagree with the concept having Strategems in some form, but current system does seem borked. I say get rid of command points and have them work as they did in some of the earlier iterations of the game like Cities of Death did in fourth Ed. Have a list of generic strats, some faction specific and some for sub factions that you can choose from at list creation and limit the number of strats each army can use dependant on the size of the game, plus one to start with. Some strats you’d keep a secret until you use it, others like ‘Tunnel Rats’, Otflank and Mine Field or Booby Traps you’d declare before the game. You could trim the fat by making things like Hellfire Shells or Lucifer Pattern Engines something you buy at list creation. Edit: things like Relics and Warlord Traits could be bought at army list creation too. I do hope they keep Crusade a thing, even if it is different to what it is now, I just like the concept of personalised campaign progression. Edit 2: I’d like flamer type weapons to get a torrent type rule. Torrent 1 would mean a weapon would hit every model within x inches, once and only once, Torrent 2, which would reflect things like a twin linked heavy flamer, would hit each model twice. Would make flamers and the like devastating to hordes, if there are twelve enemy models in range twelve get hit, if you fire you flamer at a single model you hit it once. I mean seriously the way things work ATM don’t make sense thematically, how do you set fire to something more than once? Also Blast weapons should work in reverse to the way they do now. Thematically speaking you should roll to hit, then roll to see the number of models that get caught by the blast. Would speed things up too because you’d roll two dice instead of potentially seven. Edit 3: I do find the use of d10 and d12 intriguing. Edited August 4, 2022 by Captain Smashy Pants JaM_TW 1 Back to top Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5853336 Share on other sites More sharing options...
Captain Idaho Posted August 4, 2022 Share Posted August 4, 2022 Yeah I dislike the roll dice mechanism for how many shots. Clumsy and swingy, slows the game down too. If we absolutely don't want any blast markers again, there are many ways to add the weapon systems in without such rules. FormelyKnownAsSmashyPants, Aarik, Khornestar and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5853345 Share on other sites More sharing options...
The Yncarne Posted August 4, 2022 Share Posted August 4, 2022 While I would welcome a change from D6 I think there are some core concepts 40k will never move from and these include D6 and IGO/UGO. I think those of us that prefer to move on need to look at alternatives. Inquisitor_Lensoven and Aarik 2 Back to top Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5853413 Share on other sites More sharing options...
Medjugorje Posted August 4, 2022 Share Posted August 4, 2022 I hope that Marines are not rely on their characters. Their characters should be melee monsters instead of buff characters... like drukhari ones. Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5853476 Share on other sites More sharing options...
Noserenda Posted August 4, 2022 Share Posted August 4, 2022 6 minutes ago, Medjugorje said: I hope that Marines are not rely on their characters. Their characters should be melee monsters instead of buff characters... like drukhari ones. Eh, i occasionally like to pretend my marine officers are competent leaders too Inquisitor_Lensoven, UnkyHamHam, Dumah and 1 other 2 2 Back to top Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5853479 Share on other sites More sharing options...
Inquisitor_Lensoven Posted August 4, 2022 Share Posted August 4, 2022 5 hours ago, Medjugorje said: I hope that Marines are not rely on their characters. Their characters should be melee monsters instead of buff characters... like drukhari ones. I mean gravis captain isn’t bad. 7 fist attacks hitting on 3+ is pretty nice, or 9 attacks between chainsword and fist is pretty nice as well. personally good in melee, with rules showing them as good leaders is fluffy and something I think they can do rules wise without it being OP. Even if that leadership representation is just a massive leadership aura. a smash captain that has no ability to buff is not what I want marine characters to turn into outside of a few exceptions (Seth…) Brother Borgia and Khornestar 2 Back to top Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5853671 Share on other sites More sharing options...
Inquisitor_Lensoven Posted August 4, 2022 Share Posted August 4, 2022 7 hours ago, The Blood Raven said: While I would welcome a change from D6 I think there are some core concepts 40k will never move from and these include D6 and IGO/UGO. I think those of us that prefer to move on need to look at alternatives. Yep that’s why I suggested just adding a casualty phase at the end of the turn, it maintains GW’s standard turn layout, but without the negative side effects we’re experiencing now. The Yncarne 1 Back to top Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5853674 Share on other sites More sharing options...
The Yncarne Posted August 4, 2022 Share Posted August 4, 2022 (edited) I haven’t tried apocalypse in it’s current incarnation but my understanding is that it does something similar Lensoven. Edited August 5, 2022 by The Blood Raven Inquisitor_Lensoven 1 Back to top Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5853713 Share on other sites More sharing options...
Medjugorje Posted August 5, 2022 Share Posted August 5, 2022 the main problem is that GW makes the balance on buffed marines. And I think they are an elite army and should not need a buffing character. Like Drukhari - they can buff but mainly work independent. Thats how Marines should work. But at the moment normal units are worthless without any buff. Slave to Darkness 1 Back to top Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5853824 Share on other sites More sharing options...
Cpt_Reaper Posted August 5, 2022 Share Posted August 5, 2022 Astartes characters aren't just beatsticks though. They make their warriors better, whether by command, oratory or psychic might. In the past units could use the Captain's Leadership as their own, but now leadership on it's own doesn't do anything. To reduce them to just killers is to be less than half of what they should be. UnkyHamHam, Inquisitor_Lensoven and Noserenda 3 Back to top Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5853829 Share on other sites More sharing options...
Captain Idaho Posted August 5, 2022 Share Posted August 5, 2022 I don't think it's too much bloat for some limited numbers of models to have benefits to their underlings. Doesn't have to be rerolls, like +1 to hit, +1AP to represent more accurate fire hitting weakpoints etc. Then we don't need mountains of rerolls. Chaplains are good too, as they lead and inspire. None of those things are inherently bad I believe. Karhedron, Inquisitor_Lensoven and FormelyKnownAsSmashyPants 3 Back to top Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5853854 Share on other sites More sharing options...
Cpt_Reaper Posted August 5, 2022 Share Posted August 5, 2022 6 hours ago, Captain Idaho said: I don't think it's too much bloat for some limited numbers of models to have benefits to their underlings. Doesn't have to be rerolls, like +1 to hit, +1AP to represent more accurate fire hitting weakpoints etc. Then we don't need mountains of rerolls. Chaplains are good too, as they lead and inspire. None of those things are inherently bad I believe. If Captains granted +1 To Hit, and LTs gave +1 to wound, how much difference would that make to potential outcomes? I'm bad at math-hammer so I couldn't work out how that swings things. Would exchanging every re-roll, outside of select units like Abaddon or Guilliman, with a flat +1 be as good as a re-roll or significantly better? Then in other armies is a re-roll or a +1 modifier better? 16 hours ago, The Blood Raven said: I haven’t tried apocalypse in it’s current incarnation but my understanding is that it does something similar Lensoven. I own the current Apocalypse and I can tell you nobody has tried it*...It's been on my shelf since I got it, and now you can't buy it at all. *outside of one person I saw review it on youtube just after it came out Khornestar 1 Back to top Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5854013 Share on other sites More sharing options...
Inquisitor_Lensoven Posted August 5, 2022 Share Posted August 5, 2022 (edited) 1 hour ago, Cpt_Reaper said: If Captains granted +1 To Hit, and LTs gave +1 to wound, how much difference would that make to potential outcomes? I'm bad at math-hammer so I couldn't work out how that swings things. Would exchanging every re-roll, outside of select units like Abaddon or Guilliman, with a flat +1 be as good as a re-roll or significantly better? Then in other armies is a re-roll or a +1 modifier better? I own the current Apocalypse and I can tell you nobody has tried it*...It's been on my shelf since I got it, and now you can't buy it at all. *outside of one person I saw review it on youtube just after it came out I know +1 means an extra 16% to hit or wound. so BS3+ would normally be like 68% chance to hit, +1 makes that like 84% chance to hit. but anything that’s BS2+ it would be wasted on. Edited August 5, 2022 by Inquisitor_Lensoven Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5854051 Share on other sites More sharing options...
Captain Idaho Posted August 5, 2022 Share Posted August 5, 2022 Oh you're catching me out with maths now. I have no idea really but points can reflect the changes I guess. phandaal 1 Back to top Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5854052 Share on other sites More sharing options...
Evil Eye Posted August 6, 2022 Author Share Posted August 6, 2022 As has been mentioned- stratagems for strategic assets like, say, artillery strikes, laying minefields pre-game etc, that makes perfect sense and I'd be interested in seeing more of. Making melta bombs on a Tactical Squad or the Lictor's feeder tendrils a stratagem is absolutely stupid. Captain Idaho, WrathOfTheLion, Shagah and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5854208 Share on other sites More sharing options...
Schlitzaf Posted August 6, 2022 Share Posted August 6, 2022 39 minutes ago, Evil Eye said: As has been mentioned- stratagems for strategic assets like, say, artillery strikes, laying minefields pre-game etc, that makes perfect sense and I'd be interested in seeing more of. Making melta bombs on a Tactical Squad or the Lictor's feeder tendrils a stratagem is absolutely stupid. Think about it this way: Its a STRATEGIC asset to deploy a melta bomb for tactical squad accesibility. Also otherwise stuff like melta bombs are never taken/used. Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5854215 Share on other sites More sharing options...
phandaal Posted August 6, 2022 Share Posted August 6, 2022 11 hours ago, Schlitzaf said: Think about it this way: Its a STRATEGIC asset to deploy a melta bomb for tactical squad accesibility. Also otherwise stuff like melta bombs are never taken/used. This is a Mr. Fantastic level of stretch. UnkyHamHam, Shagah and Brother Borgia 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5854284 Share on other sites More sharing options...
WrathOfTheLion Posted August 6, 2022 Share Posted August 6, 2022 (edited) It's also then a strategic asset to buy a heavy bolter in your heavy intercessor squad. A loadout option is not a strategic decision... This is one of my biggest problems with 9E codex design as far consistent themes since the very beginning of the edition, moving what are obviously wargear options to be strategems is ridiculous. For space marines, meltabombs and smoke launchers are the most obvious examples. The little incursor mine is also pretty funny on that, given they even put a model for it in the kit back for when it was a deployable thing. Edited August 6, 2022 by WrathOfTheLion Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5854288 Share on other sites More sharing options...
Schlitzaf Posted August 6, 2022 Share Posted August 6, 2022 Wrath I was mostly making a joke. I don’t meltabombs being a strat mostly cause they’ll never be used otherwise but I was also joking because “look strategry!” Slave to Darkness and phandaal 2 Back to top Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5854292 Share on other sites More sharing options...
Noserenda Posted August 6, 2022 Share Posted August 6, 2022 Not really, melta bombs are one of those bits of kit that really should be fairly standard issue, at least to marines, (Though probably not ideally carried by the sergeants and officers...) but that are often dropped depending on your army building meta. Paying for them with CP rather than points is just shifting the game design a little. Also a neat Space crusade call back :P It wouldnt be my first choice ideally, id rather keep unit CP costs to something snazzy the unit does rather than widely available wargear as you can only do it once per turn. Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5854294 Share on other sites More sharing options...
WrathOfTheLion Posted August 6, 2022 Share Posted August 6, 2022 (edited) Got it, the joke got a little lost then :) I'm not a fan of wargear being moved that way, as I think it'll be the other way around now. When command points are plentiful, you might use it over paying points, but when they're in a squeeze you'll cut these out and spend them only on the strats that go the farthest. Better to just have clean design, wargear is wargear that you pay points for, instead of shifting to a different resource to pay for them with. Edited August 6, 2022 by WrathOfTheLion added last statement phandaal 1 Back to top Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5854295 Share on other sites More sharing options...
Valkyrion Posted August 6, 2022 Share Posted August 6, 2022 The Apocalypse/Epic 40k blast marker system is fine, but like a lot of GW things, the whole pie just tastes a little off. In Apocalypse, you put a small blast marker next to your unit the first time it is hit, and replace it with a large blast marker if it is hit again, then another small if hit a third time, replaced by a large if hit a fourth time, and so on. In the damage phase, your units took a save on a D12 for every small blast marker, and a D6 for every large. Off the top of my head, space marines had a 6+ save, meaning they could save either type, from a 58% chance to a 16% chance. Imperial Guard and Orks had a 9+ save, so they couldn't save at all if hit twice. Some weapons skipped the small blast marker step to just putting 1, 2, or even 4 large blast markers. Why this works, or at least the thought behind it, is that your 10 marines weren't 10 marines, they were one unit, so you were doing unit on unit action, not man on man, so in order to translate this to 40k you'd need enough blast markers to make your table look like its covered in confetti. There's no casualties in Apocalypse, your unit is there or it isn't. I know we're having a hard reset, but I can't imagine 40k losing units in their entirety rather than model by model. It's not a bad system, and I'd actually quite like it for hero level characters and vehicles, but it's not very practical for how we imagine 40k to be. Link to comment https://bolterandchainsword.com/topic/374097-10th-edition-wishlistinghow-do-we-fix-this-mess-thread/page/9/#findComment-5854298 Share on other sites More sharing options...
