Dusktiger Posted May 7, 2022 Share Posted May 7, 2022 (edited) so my pledge for the event, is to complete a force of the Szarekhan Dynasty for the painting event, containing the following: Overlord [6 PL]Skorpekh Lord [7 PL]5 Immortals with Gauss Blasters [4 PL]5 Immortals with Gauss Blasters [4 PL]10 Necron Warriors with Gauss Reapers [6 PL]3 Skorpekh Destroyers [4 PL] + 1 Plasmacyte [1 PL]3 Canoptek Scarab Swarms [2 PL]3 Ophydian Destroyers [4 PL]+ 1 Plasmacyte [1 PL]3 Tomb Blades [4 PL]Doom Scythe [9 PL] ++ Total: [52 PL] ++ and to finish off 10 Necron Warriors with Gauss Flayers [6 PL] and 1 of 2 Cryptothralls [1of2 PL] neither of which, i am counting, since they are partly completed units already. the initial photo at the time of the pledge: And as of writing this, my progress is thus: Edited July 10, 2022 by Dusktiger Mithrilforge and Prot 2 Back to top Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/ Share on other sites More sharing options...
Dusktiger Posted May 14, 2022 Author Share Posted May 14, 2022 So while i await the painting event to kick off proper, i started fiddling with list ideas on what i want to play with to start learning the army, using what i got so far. Which quickly lead me to realize i will want to buy another box of destroyers of some variety to fill out Incursion sized games. I'm thinking probably the skorpekhs, since that seems to be the go-to unit people choose from what i've read so far. but in the mean time, this is what i'm thinking of using. the local meta uses a fair bit of terrain, as we hold to the old 5th edition concept that you completely cover a table quarter with terrain, and then that's what you spread across the entire board. As for the armies i'd face, i havent had a chance to play anyone since covid started, so im out of touch on that front. ++ Battalion Detachment [47 PL, 6CP, 993pts] ++Dynasty Choice: Szarekhan Dynasty+ HQ +Overlord [6 PL, 110pts]: Relic: Sempiternal Weave, Voidscythe, Warlord, Warlord Trait (Szarekhan): The Triarch's WillRoyal Warden [4 PL, 75pts]Skorpekh Lord [7 PL, 130pts]+ Troops +Immortals [4 PL, 85pts]: Gauss Blaster, 5x ImmortalImmortals [4 PL, 85pts]: Gauss Blaster, 5x ImmortalNecron Warriors [6 PL, 130pts]: Gauss Reaper, 10x Necron Warrior+ Elites +Skorpekh Destroyers [4 PL, 90pts]: 3x Skorpekh Destroyer+ Fast Attack +Canoptek Scarab Swarms [4 PL, 90pts]: Feeder Mandibles, 6x Canoptek Scarab Swarm Ophydian Destroyers [4 PL, 90pts]: 3x Ophydian DestroyerTomb Blades [4 PL, 108pts]: 3x Tomb Blade: Nebuloscope, Shieldvanes, Twin Gauss Blaster Now, i'm not set on the Szarekhan Dynasty, it's just the overall paint scheme i picked cause i liked the box art. Though planning out how i'm gonna paint them, i'm thinking i'm going to alter the scheme somewhat and paint shoulders metallic green, with the skorpekh 'feet' the same green. Maybe all the heads as well, haven't decided that part yet. This way, i can have an area on the model all those fancy decals they came with can be used and actually show up on the paint. So with that in mind, i might change to using custom dynasty rules, as im not so sure a 5+ for MW is even gonna be necessary in the local meta. Mithrilforge 1 Back to top Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5827686 Share on other sites More sharing options...
Dusktiger Posted May 23, 2022 Author Share Posted May 23, 2022 (edited) since the event's painting portion starts today, here's what i managed today after playing with scheme ideas: Edited June 23, 2022 by Dusktiger Mithrilforge, Daimyo-Phaeron Lenoch and Dread 3 Back to top Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5831332 Share on other sites More sharing options...
Mithrilforge Posted May 24, 2022 Share Posted May 24, 2022 (edited) I like that metallic green you used there and the placement is pretty nifty ! , is that Runelord brass spray undercoat that your using there ?.I’ve not played necrons with any of the new units yet so cannot give a critique on your army selection …just yet But from the looks of what you have I’d use that force or something similar as well .Good luck with the painting event !! I hope to get a lot done this event as well !!Cheers Mithril Edited May 25, 2022 by mithrilforge Dusktiger 1 Back to top Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5831717 Share on other sites More sharing options...
Dusktiger Posted May 25, 2022 Author Share Posted May 25, 2022 thanks! yep, it's the runelord brass spray paint. its kind of expensive here (i paid $35 local for the stuff, compared to the usual $25 for other citadel colored sprays) but i think the results with the metallic sprays are worth it for how nice it turns out. the color scheme came to me cause i was feeling nostalgic and decided to play command & Conquer tiberian sun while i waited for the painting event to start, and i recalled how much i enjoyed playing green as my team color for the GDI faction cause it went so well with all the gold. When i tested it out over the default color scheme for Szarekhan Dynasty, i was quite happy with the results. The green is done by undercoating those spots with Iron Hands Steel, and then coating that with Warp Lightning Contrast. One coat of each was enough to get the effect i wanted. Mithrilforge 1 Back to top Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5831792 Share on other sites More sharing options...
Mithrilforge Posted May 25, 2022 Share Posted May 25, 2022 thanks! yep, it's the runelord brass spray paint. its kind of expensive here (i paid $35 local for the stuff, compared to the usual $25 for other citadel colored sprays) but i think the results with the metallic sprays are worth it for how nice it turns out. the color scheme came to me cause i was feeling nostalgic and decided to play command & Conquer tiberian sun while i waited for the painting event to start, and i recalled how much i enjoyed playing green as my team color for the GDI faction cause it went so well with all the gold. When i tested it out over the default color scheme for Szarekhan Dynasty, i was quite happy with the results. The green is done by undercoating those spots with Iron Hands Steel, and then coating that with Warp Lightning Contrast. One coat of each was enough to get the effect i wanted. Yeah the Runelord brass and Retributor armour Spray paints here (OZ) are like $50 compared to $28 for the standard colours... Yesterday i managed to find a Retributor Armour spray for $27 from an online shop here!! so it looks like my Necrons are getting a basecoat of Gold first !! that may speed up completing my Vow too My Army is Novokh... I may steal your Green idea but use my Blood Angels Red Contrast instead .... Iron Hands Steel is a really nice metal colour! Good ol C&C ...gee i had a lot of fun playing that game...and Red Alert etc etc.... Mithril Daimyo-Phaeron Lenoch and Dusktiger 2 Back to top Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5831816 Share on other sites More sharing options...
Dusktiger Posted May 28, 2022 Author Share Posted May 28, 2022 (edited) here's my week 1 progress so far: Edited June 23, 2022 by Dusktiger Mithrilforge 1 Back to top Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5833120 Share on other sites More sharing options...
Dusktiger Posted May 29, 2022 Author Share Posted May 29, 2022 (edited) a small update, got one immortal done to finalize the color palette. i'm planning to wash the leadbelcher, and the green cabling, but only when all 10 are done to this stage. Edited June 23, 2022 by Dusktiger Mithrilforge 1 Back to top Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5833783 Share on other sites More sharing options...
Mithrilforge Posted May 30, 2022 Share Posted May 30, 2022 Good work (great idea on the washes, Production line washing will be way more time efficient . I love the Chest/Ribs Glow effect! , I gather that's just Tesseract Glow technical paint right?... Mithril Dusktiger 1 Back to top Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5833891 Share on other sites More sharing options...
Dusktiger Posted May 30, 2022 Author Share Posted May 30, 2022 yes, with an undercoat of ulthuan grey to make it pop better. Mithrilforge 1 Back to top Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5833972 Share on other sites More sharing options...
JaM_TW Posted May 30, 2022 Share Posted May 30, 2022 Good stuff Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5833991 Share on other sites More sharing options...
Dusktiger Posted June 24, 2022 Author Share Posted June 24, 2022 So here's an update on what i did while the site was down for upgrades: Mithrilforge and sitnam 2 Back to top Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5836378 Share on other sites More sharing options...
Dusktiger Posted July 8, 2022 Author Share Posted July 8, 2022 (edited) So I haven't had time to paint much, but so far I've finished all the immortals, the skorpekh Lord, the Skorpekh Destroyers, and I'm working on the scarab and ophydian destroyers right now, and the overlord is half done. Below is what was left on weds minus the flyer and the little drug bugs. Edited July 8, 2022 by Dusktiger Daimyo-Phaeron Lenoch and Mithrilforge 2 Back to top Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5843539 Share on other sites More sharing options...
Dusktiger Posted July 10, 2022 Author Share Posted July 10, 2022 (edited) This is a bit potato cam, but the clear coat is still too tacky to put in the light box for better shots. So, below i have my pledge, colored green on the parts that are finished: Overlord [6 PL]Skorpekh Lord [7 PL]5 Immortals with Gauss Blasters [4 PL]5 Immortals with Gauss Blasters [4 PL]10 Necron Warriors with Gauss Reapers [6 PL]3 Skorpekh Destroyers [4 PL]+ 1 Plasmacyte [1 PL]3 Canoptek Scarab Swarms [2 PL]3 Ophydian Destroyers [4 PL]+ 1 Plasmacyte [1 PL]3 Tomb Blades [4 PL]Doom Scythe [9 PL] ++ Total: [52 PL] ++ Edited July 10, 2022 by Dusktiger Kurgan the Lurker, Metzombie and Mithrilforge 3 Back to top Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5844495 Share on other sites More sharing options...
Mithrilforge Posted July 10, 2022 Share Posted July 10, 2022 Great work, Keep it up and you'll smash that vow ! looks like you're over half way !! Everything is awesome But I really love your Plasmacytes! Cheers, Mithril Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5844610 Share on other sites More sharing options...
Dusktiger Posted July 12, 2022 Author Share Posted July 12, 2022 Thanks mithril! I had time today to take some better pics, including the now completed Overlord; NTaW, StormbolterAndChainfist, Khulu and 5 others 8 Back to top Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5845066 Share on other sites More sharing options...
Mithrilforge Posted July 12, 2022 Share Posted July 12, 2022 Seeing this makes me want to go home and Paint my Necrons tonight thanks for the Motivation Mithril Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5845101 Share on other sites More sharing options...
Anticontrarian Posted July 12, 2022 Share Posted July 12, 2022 Oooh, now these are looking really nice! The bold green elements really add a certain "pop" to the otherwise-boring Szarekhan scheme, well frickin' done on that decision! Dusktiger 1 Back to top Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5845139 Share on other sites More sharing options...
JaM_TW Posted July 12, 2022 Share Posted July 12, 2022 Nice to see the conversions on the plasmacyte. Really never thought of that even if I have 3... While I did try to mix-and-match the warriors. Good stuff! Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5845142 Share on other sites More sharing options...
Bjorn Firewalker Posted July 12, 2022 Share Posted July 12, 2022 Excellent works. Dusktiger 1 Back to top Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5845270 Share on other sites More sharing options...
Dusktiger Posted July 12, 2022 Author Share Posted July 12, 2022 11 hours ago, JaM_naf#6121 said: Nice to see the conversions on the plasmacyte. Really never thought of that even if I have 3... While I did try to mix-and-match the warriors. Good stuff! That different one's actually not a conversion, the plasmacyte you get with the Ophydian Destroyers is a different pose with it climbing on different rubble. Was a pleasant surprise to find out its not the same so I have a different one in case both destroyers attack the same target. JaM_TW and Mithrilforge 2 Back to top Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5845338 Share on other sites More sharing options...
Mithrilforge Posted July 12, 2022 Share Posted July 12, 2022 I'm going to try and get the Destroyers with the Hachette subscription ( I'm not subbing but getting the first 4 from the newsagents) hoping issue 4 has that newer Plasmacyte with the 3 Skorpekh destroyers. It's always fun to have a different one Not sure if i asked already but the energy effect is just Tesseract Glow right?... Cheers, Mithril Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5845357 Share on other sites More sharing options...
Dusktiger Posted July 13, 2022 Author Share Posted July 13, 2022 1 hour ago, mithrilforge said: I'm going to try and get the Destroyers with the Hachette subscription ( I'm not subbing but getting the first 4 from the newsagents) hoping issue 4 has that newer Plasmacyte with the 3 Skorpekh destroyers. It's always fun to have a different one Not sure if i asked already but the energy effect is just Tesseract Glow right?... Cheers, Mithril yep, as as it so happens, i just received my issue 2 sub from hachette; lemmi check the sprue...ok, the one you get with that kit is the one pictured on the right. So the same one that's in the box on the site. the one on the left is the one you get with the wraith-body destroyers. Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5845396 Share on other sites More sharing options...
Mithrilforge Posted July 13, 2022 Share Posted July 13, 2022 Thanks for checking Bud , Looks like I'll have to get me some Ophidian destroyers some time in the future, they look like an Updated Version of the Old school wraiths! . Mithril Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5845408 Share on other sites More sharing options...
Dusktiger Posted July 13, 2022 Author Share Posted July 13, 2022 Here's a wip weds shot of what's left Mithrilforge, Daimyo-Phaeron Lenoch and Khulu 3 Back to top Link to comment https://bolterandchainsword.com/topic/374111-dusktigers-ra-2022-blog/#findComment-5845510 Share on other sites More sharing options...
