Machine God Posted April 15, 2020 Share Posted April 15, 2020 Hello All. I'm writing some fluff for a space battle but I'm not sure on speeds and such, so I'm after some help. I think that starships exit from the warp at the edge of solar systems because of less gravity etc. So how long would it take a starship to travel from the system edge to a planet within the life zone? Link to comment https://bolterandchainsword.com/topic/374199-starship-travel-time-in-system/ Share on other sites More sharing options...
Brother Lunkhead Posted April 16, 2020 Share Posted April 16, 2020 (edited) Greetings Machine God, Ah, there's nothing I enjoy more than the flimflammery of sci fi physics... so let's get started. Here we're talking about the Mandeville Point, which is the sweet spot where a starship enters or exits from warp space. This isn't necessarily on a system's edge. It's just a clear area between gravity fields in system so as not to mess with cogitator calculations, damage/destroy the ship, and far enough from populated areas so that they are safe from contamination by warp juice from the warp hole. Now time to target is going to be based on a number of factors, including mass of the ship, momentum coming out of the warp rift, time to fussion engine start. Thrust power and ratio of the engines, how long it takes to accelerate to maximum speed (let's say 1/4 light speed), how long it maintains max speed, deceleration time to target, etc....... still with me on this. Once you've got your engines started, you figure it will take maybe a day to accelerate to max speed ( you don't want to be going accelerating so fast as to blowout the gravity dampeners and turn the crew into people paste). So depending on distance to target, could be as short as a day or a week or more. So those are some things to keep in mind. For an example, Dan Abnett has a good description in ' Know No Fear'. The ship doesn't bother with the deceleration part as it's there to misbehave. It will give you a good idea of the time involved though. Hope that was of some help. Edited April 16, 2020 by Brother Lunkhead Machine God, Messor and Berzul 3 Back to top Link to comment https://bolterandchainsword.com/topic/374199-starship-travel-time-in-system/#findComment-5507224 Share on other sites More sharing options...
Brother Lunkhead Posted April 16, 2020 Share Posted April 16, 2020 (edited) Pardon for the double post. As relates to Brother Machine God's query, there's a great Horus Heresy story that puts all the space physics together nicely and naturally in depicting a space battle. 'Veritas Ferrum' by David Annandale. It's only $2.99 from audible, and eleven minutes well spent. Edited April 16, 2020 by Brother Lunkhead Link to comment https://bolterandchainsword.com/topic/374199-starship-travel-time-in-system/#findComment-5507406 Share on other sites More sharing options...
