Maerlen Posted May 16, 2022 Share Posted May 16, 2022 Greeting fellow Astartes, Recently I've bought a Combat Patrol box to start playing again after 5 years absence. I would like to paint them as Raptors so my questions is, How do you play them? Do i use Raven Guard rules? I have the Codex Astartes. Should i get Supplement Raven Guard? I understand they're great marksmen, recon units and great specialists, like modern SF. I also belive they would work together greatly with my future Imperial Guard. What pulled me is is the dry-cut, no fancy pants approach to combat. Getting the job done is priority. I intend to exclusively use Primaris Marines as I like the look of them. Thanks in advance! Jaipii and duz_ 2 Back to top Link to comment https://bolterandchainsword.com/topic/374227-advice-on-beginning-with-raptors/ Share on other sites More sharing options...
Halandaar Posted May 16, 2022 Share Posted May 16, 2022 How do you play them? Do i use Raven Guard rules? I have the Codex Astartes. Should i get Supplement Raven Guard? You use the Successor Chapter Tactics rules, so you can either pick any two traits you want that best work with your vision of how the army works, or take the Inheritors of the Primarch successor trait which then lets you use the Raven Guard chapter tactics. Regarding the supplement, you will be able to use stuff from it, but just be aware there is a lot of rumour/speculation that the supplements are going to be replaced before much longer (potentially even before the end of the year). duz_, Maerlen and Helias_Tancred 3 Back to top Link to comment https://bolterandchainsword.com/topic/374227-advice-on-beginning-with-raptors/#findComment-5828249 Share on other sites More sharing options...
Jaipii Posted May 16, 2022 Share Posted May 16, 2022 I haven't played with Raptors,but if I would I would play them as Raven Guard successors with successor traits: - Whirlwind of Rage (6s to hit in close combat generate extra hits) - and either Hungry for Battle (+1 to advance and charge rolls) or Stealthy (gain light cover [+1 to saves] if shot from > 18") The Raven Guard supplement as it is provides you with some great pre-game movement tricks for ambushes/infiltration and movement during the game (for ex. giving you advance+charge for some units). The Raven Guard super doctrine gives you +1 to hit AND to wound rolls against Character units when you are in the Tactical doctrine, so Snipers and other things that ignore the "Look out sir" rule are cool. duz_, Helias_Tancred and Maerlen 3 Back to top Link to comment https://bolterandchainsword.com/topic/374227-advice-on-beginning-with-raptors/#findComment-5828325 Share on other sites More sharing options...
Dracos Posted May 18, 2022 Share Posted May 18, 2022 Raptor lore would tend to lean toward Bolter Fusillade and Stealthy imo duz_, Helias_Tancred, Maerlen and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/374227-advice-on-beginning-with-raptors/#findComment-5829348 Share on other sites More sharing options...
Maerlen Posted May 19, 2022 Author Share Posted May 19, 2022 Raptor lore would tend to lean toward Bolter Fusillade and Stealthy imo I'm also leaning towards that. XeonDragon and duz_ 2 Back to top Link to comment https://bolterandchainsword.com/topic/374227-advice-on-beginning-with-raptors/#findComment-5829419 Share on other sites More sharing options...
Gamiel Posted May 19, 2022 Share Posted May 19, 2022 Using your allies as live bait also seems be a thing they do. I don't know how to represent that. XeonDragon 1 Back to top Link to comment https://bolterandchainsword.com/topic/374227-advice-on-beginning-with-raptors/#findComment-5829455 Share on other sites More sharing options...
Jaipii Posted May 19, 2022 Share Posted May 19, 2022 I would trust Dracos's advice on everything Raptors-related! My advice on the successor traits was more about how I would like to play them Dracos and XeonDragon 2 Back to top Link to comment https://bolterandchainsword.com/topic/374227-advice-on-beginning-with-raptors/#findComment-5829612 Share on other sites More sharing options...
duz_ Posted May 20, 2022 Share Posted May 20, 2022 Yes where's the pics :yes: Link to comment https://bolterandchainsword.com/topic/374227-advice-on-beginning-with-raptors/#findComment-5829784 Share on other sites More sharing options...
Maerlen Posted May 24, 2022 Author Share Posted May 24, 2022 At the moment I'm moving. After the 15th I will start the works and post pics. Also thinking about Vanguard Sprearhead... Any thoughts about that? Dracos and duz_ 2 Back to top Link to comment https://bolterandchainsword.com/topic/374227-advice-on-beginning-with-raptors/#findComment-5831532 Share on other sites More sharing options...
War of the Eagle Posted May 30, 2022 Share Posted May 30, 2022 Im a bit of an odd ball for not staying true to my genefather, I run mine as Dark Angels green-wing to represent the Raptors Marksmenship and grim determination. Link to comment https://bolterandchainsword.com/topic/374227-advice-on-beginning-with-raptors/#findComment-5834144 Share on other sites More sharing options...
