General Strike Posted May 27, 2022 Share Posted May 27, 2022 I figured I would start a thread with my questions before the box comes out. I was planning to convert the 40 tacticals from the box into Grey Slayers, and the terminators into Varagyr. Do you think this is the best option for the box for Space Wolves? I was also thinking I might actually convert 10 tacticals into Deathsworn. Link to comment https://bolterandchainsword.com/topic/374417-advice-thread-starting-a-heresy/ Share on other sites More sharing options...
WrathOfTheLion Posted May 27, 2022 Share Posted May 27, 2022 I figured I would start a thread with my questions before the box comes out. I was planning to convert the 40 tacticals from the box into Grey Slayers, and the terminators into Varagyr. Do you think this is the best option for the box for Space Wolves? I was also thinking I might actually convert 10 tacticals into Deathsworn. You'll need to check what kind of loadout you want, but they've split out Grey Slayers into two datasheets, Grey Slayers and Grey Stalkers. If you're thinking bolter/bolt pistol/chainsword loadout, that'll be the Grey Stalkers now, the Grey Slayers base loadout is the axe and combat shield. N1SB and Megalodon 2 Back to top Link to comment https://bolterandchainsword.com/topic/374417-advice-thread-starting-a-heresy/#findComment-5832688 Share on other sites More sharing options...
bushman101 Posted May 27, 2022 Share Posted May 27, 2022 Always check what Rites of War you have and look at the Restricions. It's a bummer to build a bunch of stuff, just to see you can't use them. Pacific81 1 Back to top Link to comment https://bolterandchainsword.com/topic/374417-advice-thread-starting-a-heresy/#findComment-5832719 Share on other sites More sharing options...
General Strike Posted May 27, 2022 Author Share Posted May 27, 2022 Always check what Rites of War you have and look at the Restricions. It's a bummer to build a bunch of stuff, just to see you can't use them. Ah so I should wait for the new ones then. I was looking at the old Pale Hunters or Pride of the Legion. But I should wait. Link to comment https://bolterandchainsword.com/topic/374417-advice-thread-starting-a-heresy/#findComment-5832803 Share on other sites More sharing options...
General Strike Posted May 27, 2022 Author Share Posted May 27, 2022 I figured I would start a thread with my questions before the box comes out. I was planning to convert the 40 tacticals from the box into Grey Slayers, and the terminators into Varagyr. Do you think this is the best option for the box for Space Wolves? I was also thinking I might actually convert 10 tacticals into Deathsworn. You'll need to check what kind of loadout you want, but they've split out Grey Slayers into two datasheets, Grey Slayers and Grey Stalkers. If you're thinking bolter/bolt pistol/chainsword loadout, that'll be the Grey Stalkers now, the Grey Slayers base loadout is the axe and combat shield. Ah, thank you for the heads up on that! Grey Stalkers it is then. Link to comment https://bolterandchainsword.com/topic/374417-advice-thread-starting-a-heresy/#findComment-5832867 Share on other sites More sharing options...
