Actual MDF sealer (as well as watered down PVA) tends to be moderately gloopy stuff; you could try it, but I don't think a normal airbrush is going to have the pressure to pull it off without drastically watering it down, you'd want something like a wall sprayer with a much heftier nozzle.
Sealing MDF properly before priming will definitely make it easier to get a good finish, and is recommended.
One alternative is a oil-based enamel or lacquer varnish - that also does a good job of sealing mdf for painting. Do several thin coats. Enamel varnish is easily available in rattle cans or you can thin it to use in an airbrush; I've heard good things about Mr hobby GX100 thinned (substantially) with Mr Levelling thinner for airbrush sealing gundam models, so it should work similar for MDF terrain. If you have any dullcote spray, that is also lacquer based and will give a matt finish.
As an oil-based product, similar to enamel paints, it's strongly advisable to have good ventilation and PPE such as gloves and a organic vapour rated respirator, especially if spraying indoors.
Thank you very much for this response! This was exactly what i feared the sealer would be. So i will have to use a brush or find a lacquer varnish.
Register a new account
Sign in
