I've been looking online for an RGB color code for Grey Seer, to find a good replacement, and I could not.
Does anyone have such handy?  Or otherwise, could someone do a solid coat spray over white paper and take a photo of it?  Preferrably white balanced, but if you do it on white paper I can do it myself and hope for the best :)
When Grey Seer was first released I saw a recommendation that Vallejo Mecha Color Grey Primer was pretty close.  It is not a 100% match as I did some tests, but it is very close.  I use it all the time now as my primer through my airbrush.  I leave it overnight to dry because it shrinks (I think they recommend 24 hours) which means you end up with very crisp detail on your mini even if you are a little heavy handed with the application.
My paint equivalence app (paintrack) who supposedly get RGB values from the manufacturer have grey seer spray as 198:198:198 RGB
Vallejo Mecha grey primer is listed as 185: 188:192 RGB
Visually they are very close. RAL 7035 should be damn near spot on.
Register a new account
Sign in
