Inquisitor_Lensoven Posted June 28, 2022 Share Posted June 28, 2022 Thinking about creating my own medium tank, based on the A7V. main hull mounted gun will probably be played as a tuarox battle cannon, then 4 hvy stubbers for armament, but i'm also considering throwing a hvy bolter on the small observation superstructure at the top, sort of like a mini-malcador defender, just 1 HB instead of like 5. with T9 as a cap, it's difficult for me to decide what statline to give it to make it feel like a medium tank. so here's what i'm thinking so far T7 Sv2+ W15 or T7 Sv3+ W15 AoC and i kinda want to name it the Vulkan Medium Tank, but without flamers or meltas that seems disrespectful. not fast enough of a vehicle to be named after the khan, not fly-y enough to name it after sanguinius, so maybe the Ferrus Manus Medium Tank? what primarch should it be named after? Link to comment https://bolterandchainsword.com/topic/374669-custom-medium-tank/ Share on other sites More sharing options...
Slave to Darkness Posted June 28, 2022 Share Posted June 28, 2022 6 hours ago, Inquisitor_Lensoven said: and i kinda want to name it the Vulkan Medium Tank, but without flamers or meltas that seems disrespectful. not fast enough of a vehicle to be named after the khan, not fly-y enough to name it after sanguinius, so maybe the Ferrus Manus Medium Tank? what primarch should it be named after? I wouldnt worry about that, the Leman Russ doesnt really share anything with its namesake. The Vulkan does sound cool though. Link to comment https://bolterandchainsword.com/topic/374669-custom-medium-tank/#findComment-5838166 Share on other sites More sharing options...
Inquisitor_Lensoven Posted June 28, 2022 Author Share Posted June 28, 2022 39 minutes ago, Slave to Darkness said: I wouldnt worry about that, the Leman Russ doesnt really share anything with its namesake. The Vulkan does sound cool though. Yeah but how much of russ’ personality/backstory was fleshed out when the LR was first named? Link to comment https://bolterandchainsword.com/topic/374669-custom-medium-tank/#findComment-5838191 Share on other sites More sharing options...
Inquisitor_Lensoven Posted June 28, 2022 Author Share Posted June 28, 2022 Full statline I’m thinking of M8 WS6+ BS2+ S7 T7 W15 Ld7 Sv3+(AoC) or M8 WS6+ BS2+ S7 T7 W15 Ld7 Sv2+ Link to comment https://bolterandchainsword.com/topic/374669-custom-medium-tank/#findComment-5838204 Share on other sites More sharing options...
Inquisitor_Lensoven Posted June 28, 2022 Author Share Posted June 28, 2022 On second thought I might just use the A7V as a counts as taurox prime Bjorn Firewalker 1 Back to top Link to comment https://bolterandchainsword.com/topic/374669-custom-medium-tank/#findComment-5838441 Share on other sites More sharing options...
Bjorn Firewalker Posted June 28, 2022 Share Posted June 28, 2022 (edited) 2 hours ago, Inquisitor_Lensoven said: On second thought I might just use the A7V as a counts as taurox prime Yes. A simple set of rules is best, to make the resulting vehicle easy to model and play with- increasing the chance others will use it, and give you credit for its creation, in turn. Though with the A7V as its inspiration, you might as well make the hull-mounted gun a Leman Russ battle cannon, with Strength 8 instead of the Taurox battle cannon's Strength 7. Edited June 28, 2022 by Bjorn Firewalker Link to comment https://bolterandchainsword.com/topic/374669-custom-medium-tank/#findComment-5838514 Share on other sites More sharing options...
Slave to Darkness Posted June 28, 2022 Share Posted June 28, 2022 Just realised the A7V is the tank I fondly call 'the brick' (slowly learning tank names, but Im reading so many historical books a lot of info is taking its time to settle in the old noggin), now I have a bit more context regarding what your on about Im very interested in what you come up with. Link to comment https://bolterandchainsword.com/topic/374669-custom-medium-tank/#findComment-5838532 Share on other sites More sharing options...
Inquisitor_Lensoven Posted June 28, 2022 Author Share Posted June 28, 2022 34 minutes ago, Bjorn Firewalker said: Yes. A simple set of rules is best, to make the resulting vehicle easy to model and play with- increasing the chance others will use it, and give you credit for its creation, in turn. Though with the A7V as its inspiration, you might as well make the hull-mounted gun a Leman Russ battle cannon, with Strength 8 instead of the Taurox battle cannon's Strength 7. The A7V’s gun looks a bit too small for me to in good conscious play it the same as a normal battle cannon, and a battle cannon seems a little bit too big and strong for a medium tank. the TBC fits in nicely between the BC and the multi-laser or autocannon, so just sounds and feels thematic for a medium tank. Slave to Darkness 1 Back to top Link to comment https://bolterandchainsword.com/topic/374669-custom-medium-tank/#findComment-5838533 Share on other sites More sharing options...
Inquisitor_Lensoven Posted June 28, 2022 Author Share Posted June 28, 2022 Well I slapped together a very simple version in tinkercad, in 4 hours I can start putting the bits together to build the hull and turret. found a chimera track STL so those will just get slapped onto the sides Slave to Darkness 1 Back to top Link to comment https://bolterandchainsword.com/topic/374669-custom-medium-tank/#findComment-5838558 Share on other sites More sharing options...
Bjorn Firewalker Posted June 29, 2022 Share Posted June 29, 2022 6 hours ago, Inquisitor_Lensoven said: The A7V’s gun looks a bit too small for me to in good conscious play it the same as a normal battle cannon, and a battle cannon seems a little bit too big and strong for a medium tank. the TBC fits in nicely between the BC and the multi-laser or autocannon, so just sounds and feels thematic for a medium tank. The M8 Armored Gun System and Centauro were both built with 105mm guns, but designed so a 120mm gun could be fitted if so desired. You might as well make the Strength 8 Leman Russ battle cannon an option with which to replace the Strength 7 Taurox battle cannon, if a player so desires. Link to comment https://bolterandchainsword.com/topic/374669-custom-medium-tank/#findComment-5838731 Share on other sites More sharing options...
Inquisitor_Lensoven Posted June 29, 2022 Author Share Posted June 29, 2022 for anyone interested, i just found this.https://www.thingiverse.com/thing:3762546 Link to comment https://bolterandchainsword.com/topic/374669-custom-medium-tank/#findComment-5838740 Share on other sites More sharing options...
Inquisitor_Lensoven Posted June 29, 2022 Author Share Posted June 29, 2022 made it too small, and not enough filament left to print an upscaled version :/ Link to comment https://bolterandchainsword.com/topic/374669-custom-medium-tank/#findComment-5839021 Share on other sites More sharing options...
