Sculder Posted June 29, 2022 Share Posted June 29, 2022 made some mistakes on a few testbases with the cracklepaint from gw, how can i safely remove the paint and keep the bases intact? Link to comment https://bolterandchainsword.com/topic/374710-how-to-remove-gw-cracklepaint/ Share on other sites More sharing options...
Bung Posted June 29, 2022 Share Posted June 29, 2022 Scrap carefully with a Hobby knife. Link to comment https://bolterandchainsword.com/topic/374710-how-to-remove-gw-cracklepaint/#findComment-5839075 Share on other sites More sharing options...
Grotsmasha Posted June 29, 2022 Share Posted June 29, 2022 As above, probably the quickest solution, otherwise you're looking at something like a Simple Green bath / Sonic Cleaning and a toothbrush scrub. Link to comment https://bolterandchainsword.com/topic/374710-how-to-remove-gw-cracklepaint/#findComment-5839130 Share on other sites More sharing options...
Khulu Posted June 30, 2022 Share Posted June 30, 2022 I found the GW crackle paints (like the Martian stuff, not the stuff like astrogranite) not to stick very well so scraping with a hobby knife worked well for me, even on bases with a model attached. If it's just a base with nothing else on it then soaking it in simple green or something like it would likely make it easier. Link to comment https://bolterandchainsword.com/topic/374710-how-to-remove-gw-cracklepaint/#findComment-5839373 Share on other sites More sharing options...
Sculder Posted July 3, 2022 Author Share Posted July 3, 2022 thx for the input all, worked like a charm. The bases are good as new Link to comment https://bolterandchainsword.com/topic/374710-how-to-remove-gw-cracklepaint/#findComment-5841035 Share on other sites More sharing options...
