our_baz Posted June 29, 2022 Share Posted June 29, 2022 One of main enjoyments in the hobby is Salamanders both 30K and 40k. I’ve had a 30K WIP for quite some time which I have neglected for some time. Main reason due to me being a bit of a butterfly and getting distracted. With the update here I see this as opportunity keep me focussed on my Sallies both 30K and 40K to get them completed so I can have a force I can use on the tabletop at some point. First up some heavy intercessors I’ve also wanted to try Army Painter speedpaints for while now especially on PA. So I thought I’d share my experience here. Hell blaster below, was primed with Halfords grey primer, then I did zenethial with grey seer. So a very subtle change in colour. Ive then applied magic blue on the plasma coil and grim black on the armour. You can see the black has covered really well especially on the flat areas. It has pulled at the edges but it’s not too pronounced. The finished is very matt. The blue has done what you would expect. next thing will be to tidy up some messy bits, this will give me a chance to see for myself the reactivation issues these paints have. Thanks for looking DaBoiKyknos and Dr_Ruminahui 2 Back to top Link to comment https://bolterandchainsword.com/topic/374716-our_baz-40k-salamanders-and-other-wips/ Share on other sites More sharing options...
our_baz Posted June 30, 2022 Author Share Posted June 30, 2022 I did some further playing around with the Army painter speed paints last night. I've watched a number of You Tube video's whihc discuss the issue of the Army painter speed paints reactivating when you paint over them, this was also mentioned to me by the owner of my FLGS that they also reactivate with drybrushing. So I've decided to see for myself. This work was done 24hrs after the speed paint was applied and allowed to dry. I performed a light(ish) dry brush using Russ Grey. I didn't notice any "reactivation" of the speed paint. The grey were applied hasn't darkened nor have I noticed any black residue on the brush. So dry brushing looks safe to me anyway. The next thing I wanted to tackle/test was reactivation when you paint over the speed paint. As I had applied speed paint into the ribbing on the power armour and on the vents on the backpack this needed touching up The touching up was fine I noticed no bleeding or reactivation issues. Couple of cavetas here. I was painting Skavenblight Dinge onto the ribbing so it is debatable whether you would see any bleeding there. But there was no bleeding on the vents and backpack when I touched up with leadblecher. Also no issues were I needed to touch up the blue near the plasma coil with grey seer. I will note that although I use a wet pallet, I didn't thin these paints. They were added directly from the bottle to the wet pallet without any thinning with water, so they were quite thick compared to what I normally use. Link to comment https://bolterandchainsword.com/topic/374716-our_baz-40k-salamanders-and-other-wips/#findComment-5839335 Share on other sites More sharing options...
our_baz Posted July 7, 2022 Author Share Posted July 7, 2022 Next cab off the rank. Made a start on some intersessors. Two thin coats of Nocture Green as the base followed by Vulkan green as the layer. Experiment with Army Painter Speedpaint is done, I'm really happy with the outcome and had no issue with reactivation. DaBoiKyknos, phandaal, Dr_Ruminahui and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/374716-our_baz-40k-salamanders-and-other-wips/#findComment-5842798 Share on other sites More sharing options...
our_baz Posted July 14, 2022 Author Share Posted July 14, 2022 Further Update, although the weather here in Blighty is making painting unpleasant in the evenings some progress has been made. Armour base and layer colours are done just needs a wash and highlight. Currently adding secondary colours. Rusted Boltgun and Kurgan the Lurker 2 Back to top Link to comment https://bolterandchainsword.com/topic/374716-our_baz-40k-salamanders-and-other-wips/#findComment-5845871 Share on other sites More sharing options...
our_baz Posted July 26, 2022 Author Share Posted July 26, 2022 Much further along now, just some highlighting on the armour and scales flamework to throw to them and then/ finished. I also picked up a centre piece for my 30K Sallies....but will also fill quite nicely with the 40K too. Zebulon 1 Back to top Link to comment https://bolterandchainsword.com/topic/374716-our_baz-40k-salamanders-and-other-wips/#findComment-5849968 Share on other sites More sharing options...
our_baz Posted July 31, 2022 Author Share Posted July 31, 2022 Nearly there now, 1-2 short evening sessions should be enough to polish these off. Main Highlighting and free hand scale work is complete, just flames and a final edge drybrush to go. Grotsmasha, Doghouse, DaBoiKyknos and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/374716-our_baz-40k-salamanders-and-other-wips/#findComment-5851886 Share on other sites More sharing options...
our_baz Posted September 21, 2022 Author Share Posted September 21, 2022 Update. Intersessor squad is finished finally and bases completed. I need a little palate cleanse after painting these so dived into painting some scenery by dry brushing and with contrast paints Thanks for looking. Grotsmasha, Dr_Ruminahui, Zebulon and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/374716-our_baz-40k-salamanders-and-other-wips/#findComment-5868278 Share on other sites More sharing options...
our_baz Posted October 28, 2022 Author Share Posted October 28, 2022 Deathwatch via zenithal basecoat and contrast paints (mostly). Very happy with the results, the black is nice and solid and pulls away subtly at the edges which can be emphasized further with a light dry brush. Spoiler Doghouse 1 Back to top Link to comment https://bolterandchainsword.com/topic/374716-our_baz-40k-salamanders-and-other-wips/#findComment-5879627 Share on other sites More sharing options...
Doghouse Posted October 29, 2022 Share Posted October 29, 2022 Only just seen this. Cracking job. I really like the wolf Death Watch guy and the flames and lava bases are really nice. our_baz 1 Back to top Link to comment https://bolterandchainsword.com/topic/374716-our_baz-40k-salamanders-and-other-wips/#findComment-5879823 Share on other sites More sharing options...
our_baz Posted November 1, 2022 Author Share Posted November 1, 2022 Thanks @Doghouse . I'm constantly evolving my methods for the lava bases, those one used contrast paints and heavy drybrushing I'm very happy with how they came out. Link to comment https://bolterandchainsword.com/topic/374716-our_baz-40k-salamanders-and-other-wips/#findComment-5880532 Share on other sites More sharing options...
our_baz Posted November 14, 2022 Author Share Posted November 14, 2022 Next two cabs off the rank. 30K Sallies vets. Spoiler Doghouse 1 Back to top Link to comment https://bolterandchainsword.com/topic/374716-our_baz-40k-salamanders-and-other-wips/#findComment-5883919 Share on other sites More sharing options...
our_baz Posted November 16, 2022 Author Share Posted November 16, 2022 Nearly done with these two. Can't have Sallies without some flame weapons. Heavy flamers to go with these two are done. Just lava base to go, although the rock may need another coat of Grim Black speed paint as looks too "grey" when a little wet. First time using speed paint over cork so that could be an issue. Spoiler Link to comment https://bolterandchainsword.com/topic/374716-our_baz-40k-salamanders-and-other-wips/#findComment-5884365 Share on other sites More sharing options...
our_baz Posted November 24, 2022 Author Share Posted November 24, 2022 (edited) Time to bring the heat...Heavy Flamers and volcanic bases. Nothing says Salamanders than that. Spoiler Edited November 24, 2022 by our_baz Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/374716-our_baz-40k-salamanders-and-other-wips/#findComment-5886654 Share on other sites More sharing options...
