TheNewman Posted June 30, 2022 Share Posted June 30, 2022 99% unrelated to the rules: I built my Kratos with the top pin/targeting array bit on the sponsons loose so I could swap the guns out, but I've snapped the mounts twice just in the process of scraping the basecoat paint out so they're not too tight to put the pins in place. Has anyone else run into issues with the Kratos plastic being more fragile than normal for a GW kit? Link to comment https://bolterandchainsword.com/topic/374737-issues-building-the-kratos-kit/ Share on other sites More sharing options...
Captain Idaho Posted June 30, 2022 Share Posted June 30, 2022 =][= I've sent this on to where people can better assist you with your question. =][= Link to comment https://bolterandchainsword.com/topic/374737-issues-building-the-kratos-kit/#findComment-5839574 Share on other sites More sharing options...
Khulu Posted June 30, 2022 Share Posted June 30, 2022 I have not had any problems (yet). I have had kits in the past where the plastic seemed worse than normal in vague ways, though. Can you share a picture of what broke? That might help. Link to comment https://bolterandchainsword.com/topic/374737-issues-building-the-kratos-kit/#findComment-5839622 Share on other sites More sharing options...
Cyrox Posted July 1, 2022 Share Posted July 1, 2022 Not had any issues with the plastic, but I have noticed the sponsons are quite loose, even more so on the Spartan. Hoping that painting it will alleviate it, Even if you lift the top targeting pin out (S5 i think) how are you swapping the weapons, does the bottom pin not hold it in, especially after adding the power cable, or have you left that loose too? Link to comment https://bolterandchainsword.com/topic/374737-issues-building-the-kratos-kit/#findComment-5839942 Share on other sites More sharing options...
Xenith Posted July 1, 2022 Share Posted July 1, 2022 Those seem pretty fragile, though I haven't checked my kit yet. I think they're pretty easy to magnetise also - just a magnet in the top of the mount, and one in the top of the weapon - might be less prone to breaking in the long run? Link to comment https://bolterandchainsword.com/topic/374737-issues-building-the-kratos-kit/#findComment-5839972 Share on other sites More sharing options...
