WolfLogic Posted July 12, 2022 Share Posted July 12, 2022 So I'm very new to actually building models, I've only made a 20 man MkIV box, a Contemptor, and 10 Cataphractii, now I'm trying to build my first Rhino before moving on to the Spartan that comes in Age of Darkness. The problem is that I can't get the floor to slot in, I line it up and push but it just doesn't want to go in, am I doing something wrong? Any help here would be appreciated. Sorry if this isn't the appropriate place to post this. Thanks for the help Link to comment https://bolterandchainsword.com/topic/374962-deimos-pattern-rhino-build-help/ Share on other sites More sharing options...
WrathOfTheLion Posted July 12, 2022 Share Posted July 12, 2022 If you take a knife and shave down the back side tabs on the floor piece to be flat with the top of it, it'll go easier. Link to comment https://bolterandchainsword.com/topic/374962-deimos-pattern-rhino-build-help/#findComment-5845282 Share on other sites More sharing options...
MARK0SIAN Posted July 12, 2022 Share Posted July 12, 2022 The guys at Goonhammer did an article on it, mainly because they ran into the same problem you have. WoL is right, this just adds some pics for you. Hope it helps :) https://www.goonhammer.com/how-to-build-everything-horus-heresy-deimos-rhino/ WrathOfTheLion and WolfLogic 2 Back to top Link to comment https://bolterandchainsword.com/topic/374962-deimos-pattern-rhino-build-help/#findComment-5845308 Share on other sites More sharing options...
WrathOfTheLion Posted July 12, 2022 Share Posted July 12, 2022 Ah, yeah that's where I saw that from. Honestly, I just brute forced the first couple I built and it worked well enough. MARK0SIAN 1 Back to top Link to comment https://bolterandchainsword.com/topic/374962-deimos-pattern-rhino-build-help/#findComment-5845324 Share on other sites More sharing options...
MARK0SIAN Posted July 12, 2022 Share Posted July 12, 2022 Yeah I’m generally of the brute force approach with stuff, too much Forgeworld resin :) Ayatollah_of_Rock_n_Rolla and WrathOfTheLion 2 Back to top Link to comment https://bolterandchainsword.com/topic/374962-deimos-pattern-rhino-build-help/#findComment-5845339 Share on other sites More sharing options...
Orange Knight Posted July 13, 2022 Share Posted July 13, 2022 This applies to all kits, but doubly so for vehicles. Make sure you shave off or sand down the areas where you clip the pieces off from the sprue. If you do this consistently, you'll find that the models fit together very nicely without trouble. WrathOfTheLion 1 Back to top Link to comment https://bolterandchainsword.com/topic/374962-deimos-pattern-rhino-build-help/#findComment-5845475 Share on other sites More sharing options...
Bat33.1 Posted July 15, 2022 Share Posted July 15, 2022 On 7/13/2022 at 10:07 AM, Orange Knight said: This applies to all kits, but doubly so for vehicles. Make sure you shave off or sand down the areas where you clip the pieces off from the sprue. If you do this consistently, you'll find that the models fit together very nicely without trouble. Good advice Orange Knight but that's not the issue here with the floor on the Deimos, I've built 2 and it's an issue in the design of the parts fit in the area WolfLogic is asking about. The front slots in fine but the rears do not line up correctly and require material removed or pure brute force which risks breaking something. wildweasel 1 Back to top Link to comment https://bolterandchainsword.com/topic/374962-deimos-pattern-rhino-build-help/#findComment-5846384 Share on other sites More sharing options...
Khulu Posted July 16, 2022 Share Posted July 16, 2022 Yeah the Rhinos I built were both crazy tight on the floors. I had to shave both down to make them work. Kind of a strange problem for a brand new kit. Bat33.1 1 Back to top Link to comment https://bolterandchainsword.com/topic/374962-deimos-pattern-rhino-build-help/#findComment-5846473 Share on other sites More sharing options...
bushman101 Posted July 16, 2022 Share Posted July 16, 2022 I have to ask. Is the new Rhino kit radically different from the old plastic/resin hybrid kit? Will the legion specific doors work with them? Other 'reverse compatibility ' issues? Link to comment https://bolterandchainsword.com/topic/374962-deimos-pattern-rhino-build-help/#findComment-5846502 Share on other sites More sharing options...
Arkhanist Posted July 16, 2022 Share Posted July 16, 2022 The forgeworld deimos doors work with the new rhino, as will any 3rd party ones of the same size. GodEmperorOfMankind, bushman101 and Bat33.1 3 Back to top Link to comment https://bolterandchainsword.com/topic/374962-deimos-pattern-rhino-build-help/#findComment-5846523 Share on other sites More sharing options...
