Valkyrion Posted August 6, 2022 Share Posted August 6, 2022 The Command Phase scoring is cumulative, yes? So each objective is worth up to 5 points (four valid command phases plus the end of battle). I know you only max out at 15, but have I read that right? Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/375381-raise-the-banners-high-secondary/ Share on other sites More sharing options...
Solution Karhedron Posted August 6, 2022 Solution Share Posted August 6, 2022 Yes, that is correct. The "Raise Banners" action can be performed any number of times per turn which is handy. Unlike some of the other secondaries such as RND, your opponent can knock your banners down but if you get 2 or even 3 banners up on your first turn, you can bet your opponent will need to focus on those Objectives which in turn can help you dictate the flow of the battle. Montford, BLACK BLŒ FLY, Emperor Ming and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/375381-raise-the-banners-high-secondary/#findComment-5854402 Share on other sites More sharing options...
