Inquisitor_Lensoven Posted August 18, 2022 Share Posted August 18, 2022 Does it count as kitbashing if the ‘kitbash’ in question is done in a digital format and 3d printed? Link to comment https://bolterandchainsword.com/topic/375558-philosophical-modeling-question/ Share on other sites More sharing options...
Grotsmasha Posted August 18, 2022 Share Posted August 18, 2022 Yes, I think so. If you're taking pieces (digital or physical) from multiple kits and putting them together to create something new that couldn't be created wholly from one source of the other, I'd call it (and have) "digital kitbashing". Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/375558-philosophical-modeling-question/#findComment-5858147 Share on other sites More sharing options...
Rik Lightstar Posted August 18, 2022 Share Posted August 18, 2022 Absolutely, I like to grab bits from a few different digital designers/sculptors and mix them up, either in the slicing software so they print as one piece or more often as separate components and then assemble them. That's about the limit of my skills with digital modelling to be honest. Rik Inquisitor_Lensoven 1 Back to top Link to comment https://bolterandchainsword.com/topic/375558-philosophical-modeling-question/#findComment-5858257 Share on other sites More sharing options...
Inquisitor_Lensoven Posted August 18, 2022 Author Share Posted August 18, 2022 11 hours ago, Rik Lightstar said: Absolutely, I like to grab bits from a few different digital designers/sculptors and mix them up, either in the slicing software so they print as one piece or more often as separate components and then assemble them. That's about the limit of my skills with digital modelling to be honest. Rik Yeah I’ve tried it on tinkercad and I suck lol Rik Lightstar 1 Back to top Link to comment https://bolterandchainsword.com/topic/375558-philosophical-modeling-question/#findComment-5858453 Share on other sites More sharing options...
Arkhanist Posted August 19, 2022 Share Posted August 19, 2022 (edited) 10 hours ago, Inquisitor_Lensoven said: Yeah I’ve tried it on tinkercad and I suck lol Easiest tool I've found to stl kitbash is microsoft's 3d builder. My default to stick multiple parts together, as it has 'snap' on by default so objects auto align. You can also overlap them to get a stronger joint. Has some basic scaling too, so you can easily make things e.g. 5% bigger or smaller if they're slightly out of scale. I probably do about 50% this, and 50% just print them as separate parts and glue em - depends on the pieces and how much tweaking I want to do (plus I mostly add 3d parts to plastic models, rather than whole-cloth them) Even when I'm planning on printing pre-supported parts, I'll often just chuck the (unsupported) bits together roughly in 3d builder to get a feel for posing. It's how I did this gravis terminator mockup from about 4 different sources a little while back (bodies, arms, head, shoulderpads) Edited August 19, 2022 by Arkhanist Rik Lightstar, Halandaar, apologist and 5 others 8 Back to top Link to comment https://bolterandchainsword.com/topic/375558-philosophical-modeling-question/#findComment-5858516 Share on other sites More sharing options...
