strongbow Posted August 19, 2022 Share Posted August 19, 2022 Was wondering about these things for priming with standard spray can paints. Does anyone have any recommendations/thoughts? Do they even work or is outside/inside with a window wide open for hours better? Thanks in advance! Link to comment https://bolterandchainsword.com/topic/375573-spray-booths-question/ Share on other sites More sharing options...
Bryan Blaire Posted August 19, 2022 Share Posted August 19, 2022 Are you talking about a spray booth for an airbrush, or a different type of device? If so, I would say “No”, they are unlikely to work for priming with rattle cans - those use different chemicals and aren’t as fine a mist as what comes out of an airbrush. Priming with rattle cans is better done outside/in a garage with the door open. strongbow 1 Back to top Link to comment https://bolterandchainsword.com/topic/375573-spray-booths-question/#findComment-5858573 Share on other sites More sharing options...
strongbow Posted August 19, 2022 Author Share Posted August 19, 2022 Understood, thanks for that :). Link to comment https://bolterandchainsword.com/topic/375573-spray-booths-question/#findComment-5858575 Share on other sites More sharing options...
Rik Lightstar Posted August 19, 2022 Share Posted August 19, 2022 I wouldn't use spray cans indoors unless: It was a garage or industrial unit with a large enough door to get suitable airflow and there wasn't anything that would be damaged by overspray The space had a genuine industrial extractor set up Outside is the way forwards I'd say. Rik strongbow 1 Back to top Link to comment https://bolterandchainsword.com/topic/375573-spray-booths-question/#findComment-5858576 Share on other sites More sharing options...
Arkhanist Posted August 19, 2022 Share Posted August 19, 2022 (edited) The small vented spray booths for airbrushing aren't suitable for use with rattle cans. With an airbrush, you've got a small amount of pressure, and you're mainly worried about the paint - either dry particles, or enamel outgassing, so a relatively small extraction airflow is enough (though the really cheap chinese models can't even do that). The propellent of course being just compressed air. With a rattle can the organic propellant itself is the main problem, there's a lot more of it, and it comes out a much higher rate. It is entirely possible to build/buy a spray booth for rattle cans - they're not uncommon in the cosplay community - but they are WAY bigger, with a much larger extractor, and also commonly used for car body shops etc. e.g. this bad boy for £2500 The 16A extractor on this can do 4300m3/h. A reasonable small airbrush booth will do 540m3/h... Personally, I just use a large cardboard box to contain overspray, and do it outdoors or in the garage with the big door open when it's raining. Edited August 19, 2022 by Arkhanist andes and strongbow 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/375573-spray-booths-question/#findComment-5858603 Share on other sites More sharing options...
strongbow Posted August 22, 2022 Author Share Posted August 22, 2022 Wowser, £2.5k. Muchos expensive. Good to know, thank you :). Link to comment https://bolterandchainsword.com/topic/375573-spray-booths-question/#findComment-5859260 Share on other sites More sharing options...
