Volth Posted August 19, 2022 Share Posted August 19, 2022 I remember that, super heavy vehicles once were able to transport multiple units at once. However this seems to be gone in HH 2.0 right? :( Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/ Share on other sites More sharing options...
Eternal Despair Posted August 19, 2022 Share Posted August 19, 2022 Yes they still can transport multiple units, page 215 of the main rulebook under the super-heavy transports sub-heading "if a super-heavy transport has a transport capacity, then it may transport any number of infantry units...." Volth 1 Back to top Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/#findComment-5858565 Share on other sites More sharing options...
Marshal Mittens Posted August 23, 2022 Share Posted August 23, 2022 They nerfed the Stormlord pretty hard, transport amount wise. It should be 300 pts cheaper and be able to transport 40 models. RoadRunna, Brofist and TheNineteenth 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/#findComment-5860019 Share on other sites More sharing options...
Inquisitor Verhek Posted August 24, 2022 Share Posted August 24, 2022 Ok, how about this, and I may have missed something, but.... Sokar has a transport capacity of 52. It also has the rules 'transport bay' and 'auxiliary vehicle bay'. 'Transport Bay' states it can carry dreadnaughts and other such non-infantry units. It specifies each dreadnaught takes up 10 infantry spots. Whereas 'Auxiliary Vehicle Bay' only states that it can carry vehicles of 4starting hull points or less. There is no specification of the vehicle takes up any of the infantry space. It seems to imply that it's a separate space, ie Auxiliary vehicle bay... A rhino fits 10 models, and there is no rule saying you can't transport models in a model that itself is being transported. So, does it now have an effective transport capacity of 64? 52 for the Sokar and 12 for the rhino?! Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/#findComment-5860066 Share on other sites More sharing options...
SkimaskMohawk Posted August 24, 2022 Share Posted August 24, 2022 Why not cram a whole storm eagle in it with its capacity of 22? I'd argue that auxiliary vehicle bay modifies the unit type that can go in, but leaves the rest of the standard transport capacity rules intact. So that vehicle counts as 1 (even though that dread counts as 10, or the javelin counts as 8). Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/#findComment-5860067 Share on other sites More sharing options...
Inquisitor Verhek Posted August 24, 2022 Share Posted August 24, 2022 4 minutes ago, SkimaskMohawk said: Why not cram a whole storm eagle in it with its capacity of 22? I'd argue that auxiliary vehicle bay modifies the unit type that can go in, but leaves the rest of the standard transport capacity rules intact. So that vehicle counts as 1 (even though that dread counts as 10, or the javelin counts as 8). Holy cow, I didn't even realize the storm eagle had 4 hull points and could therefore be transported! Not sure I fully understand what you mean by it modifying the unit type that can go in. Modify the type of vehicle that could go in? And sadly, the javelin couldn't go in as it has the anti-grav type applied to it. Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/#findComment-5860069 Share on other sites More sharing options...
SkimaskMohawk Posted August 24, 2022 Share Posted August 24, 2022 (edited) Okay, so the normal rules for transport capacity say that only infantry can go in, and each model takes up a slot of transport capacity. Aux vehicle bay gives you permission to have a different unit type embark (vehicles), but doesn't change the amount of transport capacity, meaning they stay at the default 1. Edited August 24, 2022 by SkimaskMohawk Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/#findComment-5860202 Share on other sites More sharing options...
Hfran Morkai Posted August 24, 2022 Share Posted August 24, 2022 10 hours ago, SkimaskMohawk said: Why not cram a whole storm eagle in it with its capacity of 22? I'd argue that auxiliary vehicle bay modifies the unit type that can go in, but leaves the rest of the standard transport capacity rules intact. So that vehicle counts as 1 (even though that dread counts as 10, or the javelin counts as 8). Thunderhawk Transporter carrying two Storm Eagles? MADNESS! Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/#findComment-5860217 Share on other sites More sharing options...
Inquisitor Verhek Posted August 24, 2022 Share Posted August 24, 2022 (edited) 1 hour ago, SkimaskMohawk said: Okay, so the normal rules for transport capacity say that only infantry can go in, and each model takes up a slot of transport capacity. Aux vehicle bay gives you permission to have a different unit type embark (vehicles), but doesn't change the amount of transport capacity, meaning they stay at the default 1. Having read all this on detail for the first time (I don't generally use transports), it's kind of sadly funny that nothing can transport a primarch. Primarchs are generally bulky4 which, I believe dictates what they can fit inside for transport. How are you seeing them as unable to be transported? *edit* Ah, infantry transport... no bulky permitted. But then, hiw can terminators go into anything? They're bulky2. *edit 2* The problem seems to be the rule for infantry transport. This is what doesn't allow bulky to be transported at all. Transport vehicle rules specifically state primarch eligibility and bulky models. Super heavy transport rules actually state they may be able to carry other unit types IN ADDITION to infantry. Thus, the vehicle in the sokar would be in addition to the 52 infantry troop transport! Thus, with a storm Raven, actually allowing it to carry 74 infantry models!!! Incidentally, I can't find the rules for the reinforced vehicle subtype, as the land raider spartan has it. Anyone else know where to look for that? Edited August 24, 2022 by Inquisitor Verhek Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/#findComment-5860224 Share on other sites More sharing options...
SkimaskMohawk Posted August 24, 2022 Share Posted August 24, 2022 17 minutes ago, Inquisitor Verhek said: Primarchs are generally bulky4 which, I believe dictates what they can fit inside for transport. How are you seeing them as unable to be transported? *edit* Ah, infantry transport... no bulky permitted. But then, hiw can terminators go into anything? They're bulky2. K so I definitely fumbled reading the transport rules, so I'll try and clarify lol. The core rules say one infantry unit and/or any amount of independant characters with infantry/primarch can be carried. Further down it says only infantry can embark. So RAW, you can start a primarch in a transport (has permission to be carried), but once they're out, they're out (does not have permission to embark on it). The infantry transport special rule is separate, and only on rhinos iirc. The larger transports allow bulky models. Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/#findComment-5860232 Share on other sites More sharing options...
Inquisitor Verhek Posted August 24, 2022 Share Posted August 24, 2022 You're right. For some reason I was adding that rule in for some stupid reason whenever I read another transport vehicle. You are right about embarking. Annoyingly stupid. On the plus side, a sokar can carry nearly an entire company! 74 models worth, plus a storm Raven! I find it amusing that it can use any access point to disembark. Or any part of the hull, since it's coming from a non-based model. What is a reinforced vehicle type? Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/#findComment-5860267 Share on other sites More sharing options...
Cactus Posted August 24, 2022 Share Posted August 24, 2022 Reinforced is a vehicle sub-type. Land raiders and spartans have it but I can't recall if it's in the core rules or the Liber. Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/#findComment-5860326 Share on other sites More sharing options...
Inquisitor Verhek Posted August 24, 2022 Share Posted August 24, 2022 2 hours ago, Cactus said: Reinforced is a vehicle sub-type. Land raiders and spartans have it but I can't recall if it's in the core rules or the Liber. That's just it, I couldn't find anything on it at all. Neither of the books had it that I could find. Only that vehicles like the spartan had it in it's sub-type. Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/#findComment-5860358 Share on other sites More sharing options...
Cactus Posted August 25, 2022 Share Posted August 25, 2022 Liber Hereticus page 95. It's that page we all skip over to get to the Rites of War. Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/#findComment-5860380 Share on other sites More sharing options...
Inquisitor Verhek Posted August 25, 2022 Share Posted August 25, 2022 2 hours ago, Cactus said: Liber Hereticus page 95. It's that page we all skip over to get to the Rites of War. Wait.... there a page before the rights of war?! Ha! Thanks for that, I was going crazy trying to find it! I KNEW there was a page I was missing! Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/#findComment-5860402 Share on other sites More sharing options...
TheTrans Posted August 25, 2022 Share Posted August 25, 2022 Does anyone else just wish they put all the sub types in the main rulebook. Its not like they weren't available or already written... SkimaskMohawk 1 Back to top Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/#findComment-5860406 Share on other sites More sharing options...
SkimaskMohawk Posted August 25, 2022 Share Posted August 25, 2022 11 hours ago, TheTrans said: Does anyone else just wish they put all the sub types in the main rulebook. Its not like they weren't available or already written... And all the one-off rules in the datasheet if it could fit. The javelin entry certainly has the room to tell you what a javelin does. General Zodd 1 Back to top Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/#findComment-5860604 Share on other sites More sharing options...
TheNineteenth Posted September 7, 2022 Share Posted September 7, 2022 On 8/24/2022 at 12:11 AM, SkimaskMohawk said: Why not cram a whole storm eagle in it with its capacity of 22? I'd argue that auxiliary vehicle bay modifies the unit type that can go in, but leaves the rest of the standard transport capacity rules intact. So that vehicle counts as 1 (even though that dread counts as 10, or the javelin counts as 8). These new transport rules are totally half-baked. They could have easily copy-pasted the 6th edition Apocalypse Super-heavy transport rules and had none of these problems. This is pure incompetence. Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/#findComment-5864575 Share on other sites More sharing options...
SkimaskMohawk Posted September 7, 2022 Share Posted September 7, 2022 6 hours ago, TheNineteenth said: These new transport rules are totally half-baked. They could have easily copy-pasted the 6th edition Apocalypse Super-heavy transport rules and had none of these problems. This is pure incompetence. Lol they could have easily copy-paste a lot of older editions rules and came out with a better game. But they made a bunch of brand-new stuff and didn't iron it out properly, like the spicula rockets all over again. TheNineteenth 1 Back to top Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/#findComment-5864644 Share on other sites More sharing options...
Bloody Legionnaire Posted September 12, 2022 Share Posted September 12, 2022 Somewhat related/somewhat unrelated to the topic, I’ve looked up the Phobos Land Raider in the “classic” units updated list GW/FW put out and noticed it does not give any indications to which types of units it can transport. I think it’d be silly if a Proteus could be a DT for terminators but not the Phobos. Anyone know if we’ve received any clarifications for the Phobos? Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/#findComment-5865900 Share on other sites More sharing options...
General Zodd Posted September 12, 2022 Share Posted September 12, 2022 3 hours ago, Bloody Legionnaire said: Somewhat related/somewhat unrelated to the topic, I’ve looked up the Phobos Land Raider in the “classic” units updated list GW/FW put out and noticed it does not give any indications to which types of units it can transport. I think it’d be silly if a Proteus could be a DT for terminators but not the Phobos. Anyone know if we’ve received any clarifications for the Phobos? Your observation is accurate, they’ve decided to make an unnecessary distinction between the two, because one of them is current HH range, and the other is 40k range… I doubt anyone you play against is likely to object if you take a Phobos as a DT. At least, I’d hope not…! Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/#findComment-5865945 Share on other sites More sharing options...
Bloody Legionnaire Posted September 12, 2022 Share Posted September 12, 2022 1 minute ago, General Zodd said: Your observation is accurate, they’ve decided to make an unnecessary distinction between the two, because one of them is current HH range, and the other is 40k range… I doubt anyone you play against is likely to object if you take a Phobos as a DT. At least, I’d hope not…! But FW still offers the Land Raider MkIIB.. so it isn’t strictly a model in the 40k range, which makes even more frustrating that they somehow dropped the ball with this. Link to comment https://bolterandchainsword.com/topic/375579-transport-ability-of-super-heavies/#findComment-5865946 Share on other sites More sharing options...
