Vostroi Posted August 19, 2022 Share Posted August 19, 2022 The Explorator can scout which allows it to arrive in reserve using Outflank. Can I put any unit in it and give the unit outflank? Also how does the explorator's Explorator Augury Web work if it is itself in reserve? Link to comment https://bolterandchainsword.com/topic/375587-proteus-explorator-and-outflank/ Share on other sites More sharing options...
Solution Brofist Posted August 20, 2022 Solution Share Posted August 20, 2022 Unlike the older edition you would get to use the agug web while its in reserves. I base this on the rules for the other reserve manipulators having explicit language that require them to be on the table. The Scorpion, TheNineteenth and Spagunk 3 Back to top Link to comment https://bolterandchainsword.com/topic/375587-proteus-explorator-and-outflank/#findComment-5858840 Share on other sites More sharing options...
TheTrans Posted August 22, 2022 Share Posted August 22, 2022 On 8/21/2022 at 12:56 AM, Brofist said: Unlike the older edition you would get to use the agug web while its in reserves. I base this on the rules for the other reserve manipulators having explicit language that require them to be on the table. We've hit another "NFI" point of RAI vs RAW with 2.0 (got its really just falling apart worse and worse haha). Geo-Locator Beacon and the MoS Strategic Comms specifically states the model must be on the board, where as the Exploratory Augur array doesn't which technically, to me anyway, is allowing it to assist while off the board. Xenith, TheNineteenth and Brofist 3 Back to top Link to comment https://bolterandchainsword.com/topic/375587-proteus-explorator-and-outflank/#findComment-5859218 Share on other sites More sharing options...
Brofist Posted August 22, 2022 Share Posted August 22, 2022 Yep, that's my interpretation as well. Spagunk, TheNineteenth and TheTrans 3 Back to top Link to comment https://bolterandchainsword.com/topic/375587-proteus-explorator-and-outflank/#findComment-5859394 Share on other sites More sharing options...
