Laughingman Posted August 24, 2022 Share Posted August 24, 2022 Looking for inspiration for a pathfinder or Legion scouts. Has anyone converted or kitbashed their own? Link to comment https://bolterandchainsword.com/topic/375640-legion-scoutspathfinder-conversion-ideas/ Share on other sites More sharing options...
Hfran Morkai Posted August 24, 2022 Share Posted August 24, 2022 I know some folks have taken Rogue Trader erametal Scouts and given them plastic HH weapons such as Bolt Pistols. I'll see if I can dig some photos out to help inspire. I've got about 20 metal (non RT era) Scouts including SW ones for my Sixth and to be honest I'm not planning too much conversion work for them (though I may kitbash some as there's about two metal Bolter Scouts across the range and I can't say I'm a fan of the plastics, although the Redwarden Scout heads may rectify that). Link to comment https://bolterandchainsword.com/topic/375640-legion-scoutspathfinder-conversion-ideas/#findComment-5860059 Share on other sites More sharing options...
Iron Hands Fanatic Posted August 24, 2022 Share Posted August 24, 2022 (edited) they're a bit hard to parse due to being mid painting but here are mine, converted from normal 40k scouts - one benefit of the re-scaling of Mk6 is that the smaller bare heads now work pretty well with the scout scale, hence me using all 8 masked heads from the main Mk6 sprues in the AoD box (with some hair transplants) Edited August 24, 2022 by Iron Hands Fanatic lansalt, Noserenda, Hfran Morkai and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/375640-legion-scoutspathfinder-conversion-ideas/#findComment-5860060 Share on other sites More sharing options...
Mandragola Posted August 24, 2022 Share Posted August 24, 2022 This was my attempt. I made these a few years ago, mainly using bodies from the land speeder storm kit that I modified a lot. There’s a fair bit of green stuff involved in changing the poses, but luckily the baggy fatigues scouts wear make that fairly straightforward. I also scraped off the eagles from the chests, which gives a more Spartan heresy-eta feel, I think. brother_b 1 Back to top Link to comment https://bolterandchainsword.com/topic/375640-legion-scoutspathfinder-conversion-ideas/#findComment-5860093 Share on other sites More sharing options...
Xenith Posted August 24, 2022 Share Posted August 24, 2022 As above, actual scout models are fine. I've also seen a lot of great conversions using the NM enforcer kit. Link to comment https://bolterandchainsword.com/topic/375640-legion-scoutspathfinder-conversion-ideas/#findComment-5860095 Share on other sites More sharing options...
Cadmus Tyro Posted August 24, 2022 Share Posted August 24, 2022 Here’s my pathfinder, built some time ago so contemplating whether to give him a shotgun. One thing to note is that the landspeeder storm kit has a number of more interesting poses and parts you can mix in with the more standard scout kits. Check my blog for WIP/painted images of the scouts. Cadmus LameBeard, Noserenda and brother_b 3 Back to top Link to comment https://bolterandchainsword.com/topic/375640-legion-scoutspathfinder-conversion-ideas/#findComment-5860113 Share on other sites More sharing options...
Marshal Mittens Posted August 24, 2022 Share Posted August 24, 2022 (edited) Primaris Black Templar Neophytes with the Templar stuff scraped off + Primaris Eliminators sniper rifles, they do not look glaringly primaris in anyway, especially if you give them normal shoulder pads. Just my opinion. The Primaris Black Templar Neophytes also have shotguns already sized for them, if you want to go that route. There is a couple great Data Pad / 3D map bits in the Spartan bit for the commander that look good for the leader or another scout to be holding. Edited August 24, 2022 by Marshall Mittens Beerhammer and Doghouse 2 Back to top Link to comment https://bolterandchainsword.com/topic/375640-legion-scoutspathfinder-conversion-ideas/#findComment-5860137 Share on other sites More sharing options...
sarabando Posted August 24, 2022 Share Posted August 24, 2022 my 1k sons in this thread use goliath parts. Inspired by thetrapistfunk on IG. LameBeard and Fire Golem 2 Back to top Link to comment https://bolterandchainsword.com/topic/375640-legion-scoutspathfinder-conversion-ideas/#findComment-5860214 Share on other sites More sharing options...
LameBeard Posted August 24, 2022 Share Posted August 24, 2022 I haven’t made any yet, but if I did it would be: GW plastic scout arms and legs (and shotguns) Spellcrow torsos Mix in Tigrus bolt weapons, heresy sergeant weapons from bits box. I also have a nice Anvil Industry sniper rifle, plus extra scopes that could work. Rebreather heads - maybe GW or puppetswar. But that’s a very high GBP/points ratio for an infantry squad! Link to comment https://bolterandchainsword.com/topic/375640-legion-scoutspathfinder-conversion-ideas/#findComment-5860356 Share on other sites More sharing options...
Laughingman Posted August 25, 2022 Author Share Posted August 25, 2022 2 hours ago, LameBeard said: I haven’t made any yet, but if I did it would be: GW plastic scout arms and legs (and shotguns) Spellcrow torsos Mix in Tigrus bolt weapons, heresy sergeant weapons from bits box. I also have a nice Anvil Industry sniper rifle, plus extra scopes that could work. Rebreather heads - maybe GW or puppetswar. But that’s a very high GBP/points ratio for an infantry squad! Was actually looking at those spellcrow torsos, but couldn't find any pictures of any kitbashes using them. So I have no idea about scale/compatibility. LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/375640-legion-scoutspathfinder-conversion-ideas/#findComment-5860379 Share on other sites More sharing options...
LameBeard Posted August 25, 2022 Share Posted August 25, 2022 Yeah I haven’t managed to find any online - would be great if any frater had pictures they could post. Link to comment https://bolterandchainsword.com/topic/375640-legion-scoutspathfinder-conversion-ideas/#findComment-5860419 Share on other sites More sharing options...
W.A.Rorie Posted August 27, 2022 Share Posted August 27, 2022 (edited) here’s my RG pathfinder: scout torso (eagle carved off), Recon marine head and mc Astartes Shotgun, various pouches and grenades, and Mk Iv bolt pistol holster Edited August 27, 2022 by war009 LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/375640-legion-scoutspathfinder-conversion-ideas/#findComment-5861164 Share on other sites More sharing options...
