hd3 Posted August 31, 2022 Share Posted August 31, 2022 (edited) So someone suggested I do a prohect log of starting my 40k collection. Rate my setup etc. Im using the 40k paints and tools set. The mold scraper has been good for getting mold lines off but as you can see below, im having trouble getting the sprur nubs off clearly. Especially on the necron gaiss flayer. These are push assembly rather thab glue too and I accidentally clipped the necrons foot pin. So Ive fixed it with some deluxe material plastoc cement Edited August 31, 2022 by hd3 Castellan Wulfrik and Mithrilforge 2 Back to top Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/ Share on other sites More sharing options...
hd3 Posted August 31, 2022 Author Share Posted August 31, 2022 (edited) Undercoat time! Its raining today so im using the empty room! Edited August 31, 2022 by hd3 Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862119 Share on other sites More sharing options...
hd3 Posted August 31, 2022 Author Share Posted August 31, 2022 (edited) Im applying a base cost of warplock bronze to the necron but I think I've thinned it too much. Any tips on the right amount of water for the metallic paints? Edited August 31, 2022 by hd3 Mithrilforge and DaBoiKyknos 2 Back to top Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862140 Share on other sites More sharing options...
hd3 Posted August 31, 2022 Author Share Posted August 31, 2022 (edited) The mcragge blue for the primaris marine is going on much easier . I had to go pick up new brushes for base and dry because the ones i bought originally were way too hard for any control. I think that might be why the first coat of warplock came out so poorly Edited August 31, 2022 by hd3 Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862142 Share on other sites More sharing options...
Pearson73 Posted August 31, 2022 Share Posted August 31, 2022 Off to a nice start! Documenting your progress is a nice way to motivate yourself and find advice too. I actually think the Necron is looking really cool with the metallic effect so far. That said, if you want to go back with more metals, less is more when it comes to adding water, it's definitely easy to over dilute! Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862143 Share on other sites More sharing options...
Grotsmasha Posted August 31, 2022 Share Posted August 31, 2022 Coming along nicely I typically thin metallics less than traditional paints. However, if you do over thin it, spread it out a bit, then wait a couple of mins (~5 or so), and will usually dry out enough to be a usable consistency. Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862146 Share on other sites More sharing options...
hd3 Posted August 31, 2022 Author Share Posted August 31, 2022 1 hour ago, Pearson73 said: Off to a nice start! Documenting your progress is a nice way to motivate yourself and find advice too. I actually think the Necron is looking really cool with the metallic effect so far. That said, if you want to go back with more metals, less is more when it comes to adding water, it's definitely easy to over dilute! Thanks! I'll add a bit less water next time! 1 hour ago, Grotsmasha said: Coming along nicely I typically thin metallics less than traditional paints. However, if you do over thin it, spread it out a bit, then wait a couple of mins (~5 or so), and will usually dry out enough to be a usable consistency. I'll do that! How many dtops of water should I add to drops of paint? Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862158 Share on other sites More sharing options...
hd3 Posted August 31, 2022 Author Share Posted August 31, 2022 (edited) I had a lot of difficulty gettibg the paint to stick to the underside of the necrons right hand. I don't like the lack of control with the base brush. Edited September 1, 2022 by hd3 Doghouse 1 Back to top Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862160 Share on other sites More sharing options...
hd3 Posted August 31, 2022 Author Share Posted August 31, 2022 Finally finished the base coats! Mithrilforge and Urauloth 2 Back to top Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862173 Share on other sites More sharing options...
Doghouse Posted August 31, 2022 Share Posted August 31, 2022 These coming along nicely, I really like the Necron espeically. Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862190 Share on other sites More sharing options...
Xenith Posted August 31, 2022 Share Posted August 31, 2022 Good start so far, the necron is looking great. You can carefully use a modelling knife/scalpel to shave off the remaining sprue nubs on the models. You've built up that colour nicely on the ultramarine, however it might get time consuming over the black undercoat - consider maybe a grey or even blue undercoat to speed things up! Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862192 Share on other sites More sharing options...
hd3 Posted August 31, 2022 Author Share Posted August 31, 2022 (edited) 30 minutes ago, Doghouse said: These coming along nicely, I really like the Necron espeically. Thank you! I found a really good alternative colour guide for the szarekahn which im trying. https://taleofpainters.com/2021/08/tutorial-how-to-speedpaint-necron-szarekhan-dynasty-armour/ Edited August 31, 2022 by hd3 Doghouse 1 Back to top Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862193 Share on other sites More sharing options...
hd3 Posted August 31, 2022 Author Share Posted August 31, 2022 (edited) 21 minutes ago, Xenith said: Good start so far, the necron is looking great. You can carefully use a modelling knife/scalpel to shave off the remaining sprue nubs on the models. You've built up that colour nicely on the ultramarine, however it might get time consuming over the black undercoat - consider maybe a grey or even blue undercoat to speed things up! I actually just ordered the command set and was debating what chapter to make them. If I went ultras or blood angels, what shade should I use for undercoat? Edited August 31, 2022 by hd3 Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862194 Share on other sites More sharing options...
Majkhel Posted August 31, 2022 Share Posted August 31, 2022 For the metallics, it's often better not to thin with water. I've found glazing medium (I'm using the one from Vallejo) to work much better and safer in terms of pigment distribution inside the mix. Alternative is to use another brand of paints as GW colors tend to be rather thick (it's not a bad thing on its own, it's just a characteristic). Good luck with your painting journey! Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862195 Share on other sites More sharing options...
Khulu Posted August 31, 2022 Share Posted August 31, 2022 Off to a great start! Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862196 Share on other sites More sharing options...
hd3 Posted August 31, 2022 Author Share Posted August 31, 2022 22 minutes ago, Majkhel said: For the metallics, it's often better not to thin with water. I've found glazing medium (I'm using the one from Vallejo) to work much better and safer in terms of pigment distribution inside the mix. Alternative is to use another brand of paints as GW colors tend to be rather thick (it's not a bad thing on its own, it's just a characteristic). Good luck with your painting journey! https://acrylicosvallejo.com/en/product/hobby/auxiliaries-model/glaze-medium-70596/ This stuff? Do you just mix it in with the paint like water? Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862202 Share on other sites More sharing options...
Majkhel Posted August 31, 2022 Share Posted August 31, 2022 1 hour ago, hd3 said: https://acrylicosvallejo.com/en/product/hobby/auxiliaries-model/glaze-medium-70596/ This stuff? Do you just mix it in with the paint like water? Yeah that's the stuff. And yes, like water. But only just a bit of it as it will also make the paint dry longer. So if you overdo it, it might actually take up to 2-3 hours for the paint dry :D. Also if you make the paint run too much, you can always touch the brush to a paper towel to remove the excess of moisture/medium before you apply the paint on mini. Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862217 Share on other sites More sharing options...
Grotsmasha Posted August 31, 2022 Share Posted August 31, 2022 (edited) Having just painted 120+ PL of Szarekhan for a commission, I can save you some steps in that paint job, 1- Spray Runelord Brass 2- Wash with either Riekland Fleshshade (lighter) or Agrax Earthshade (darker) 3- Black Legion Contrast for the black areas, basically everything that isn't armour, if doing edge highlights use Eshin Grey. 4- Canoptek Alloy on all the shoulders, this can also be used as an edge highlight on the armour panels. 5- Colour of your choice for the eyes, gun glow. On 8/18/2022 at 12:36 PM, Grotsmasha said: So here is my "1st" vow complete, Reveal hidden contents On 8/23/2022 at 11:53 PM, Grotsmasha said: What was I even worried about..... vow 2 Complete Hide contents Edited August 31, 2022 by Grotsmasha Majkhel 1 Back to top Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862265 Share on other sites More sharing options...
hd3 Posted September 1, 2022 Author Share Posted September 1, 2022 15 hours ago, Majkhel said: For the metallics, it's often better not to thin with water. I've found glazing medium (I'm using the one from Vallejo) to work much better and safer in terms of pigment distribution inside the mix. Alternative is to use another brand of paints as GW colors tend to be rather thick (it's not a bad thing on its own, it's just a characteristic). Good luck with your painting journey! Interesting! Do you just mix the glazing medium in with the paint likevwater? Ive tried overbrushing the necron with brass scorpion but I think I left too much paint on the brush . Ive also tried doing a recess shade with the ultramarine. Im not sure if the brish lacks control or my hands shake too much Mithrilforge 1 Back to top Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862545 Share on other sites More sharing options...
hd3 Posted September 1, 2022 Author Share Posted September 1, 2022 (edited) Here, I've tried dry brushing the necron warrior with runelord brass. Again, im worried I went overboard with the paint. I think im probably going to need to touch up the joints and recesses with maybe abaddon black or agrax earthshade. And then leadbelcher for the nuts and bolts. These aren't my final paint choices, just what came in the paint set. Im going to buy the ones grotsnasha suggested above when my command set gets here. Im noticing having to hold the model on the unconfortable box lid its taped to is difficult. Does anyone have any suggestion for holding the model? A stand or easel etc. which is good for height Ive added abaddon black to the armor seals, weapons and joints. As you can see I slipped in a few places so if anyone has any tips on greater brush control for tricky spots or touchibg up bades, please feel free to comment. Edited September 1, 2022 by hd3 Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862570 Share on other sites More sharing options...
hd3 Posted September 1, 2022 Author Share Posted September 1, 2022 14 hours ago, Grotsmasha said: Having just painted 120+ PL of Szarekhan for a commission, I can save you some steps in that paint job, 1- Spray Runelord Brass 2- Wash with either Riekland Fleshshade (lighter) or Agrax Earthshade (darker) 3- Black Legion Contrast for the black areas, basically everything that isn't armour, if doing edge highlights use Eshin Grey. 4- Canoptek Alloy on all the shoulders, this can also be used as an edge highlight on the armour panels. 5- Colour of your choice for the eyes, gun glow. Yeah, I was hoping to avoid it because one can of runelord brass is so expensive but I guess its inevitable. Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862586 Share on other sites More sharing options...
Grotsmasha Posted September 1, 2022 Share Posted September 1, 2022 Cans really are a convenience tax,... Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862590 Share on other sites More sharing options...
Pearson73 Posted September 1, 2022 Share Posted September 1, 2022 Unfortunately for brush control, all I can really offer is practice, practice, practice.... As for holdin the mini, I typically just use my hand, but I've also heard good things about the GW holder. If you have a GW nearby, perhaps you could try one before buying? I think a nice dark recess wash will really boost that Necron, looking forward to the next update! Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862625 Share on other sites More sharing options...
Majkhel Posted September 1, 2022 Share Posted September 1, 2022 (edited) 4 hours ago, hd3 said: Interesting! Do you just mix the glazing medium in with the paint like water? Yes. When you want a metallic paint to run more smoothly that is. There are brands like Vallejo Metal Color that don't need this kind of treatment. And brands like GW or Scale75, that really benefit from being a little diluted to run smoother from the brush. Just remember that glazing medium also extends the drying time a bit, so use it sparingly. For the overbrush - as with most drybrushing techniques, the idea is to have reaaaally little paint on the brush. Like seriously little. Dab the brush in paint, remove like 95% of it on a paper towel, then remove some more, test on a hand or some other surface (you should be getting a delicate powder-like result) and only then touch the mini. Edited September 1, 2022 by Majkhel Pearson73 1 Back to top Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862633 Share on other sites More sharing options...
hd3 Posted September 1, 2022 Author Share Posted September 1, 2022 2 hours ago, Pearson73 said: Unfortunately for brush control, all I can really offer is practice, practice, practice.... As for holdin the mini, I typically just use my hand, but I've also heard good things about the GW holder. If you have a GW nearby, perhaps you could try one before buying? I think a nice dark recess wash will really boost that Necron, looking forward to the next update! Yeah, I'm planning a wash with agrax and contrast med. Should I paint black on the joints before or after though? Link to comment https://bolterandchainsword.com/topic/375717-prohect-log-literally-my-first-ever-miniatures/#findComment-5862707 Share on other sites More sharing options...
