hd3 Posted September 2, 2022 Share Posted September 2, 2022 I was wondering if anyone knew an aesthetically pleasing way to put letters and numbers on the side of round model bases? To keep track of them during games etc. I was going to put a production number or names for fancy units on the side of the base but doing It with a label maker probably looks cheap and decals is too time consuming and expensive. Does anyone know a good alternative? Link to comment https://bolterandchainsword.com/topic/375747-is-there-an-easy-and-aesthetically-pleasing-way-to-put-letters-on-sides-of-bases/ Share on other sites More sharing options...
Xenith Posted September 2, 2022 Share Posted September 2, 2022 Paint it white and then use a micron pen, steady hand and fancy writing? Link to comment https://bolterandchainsword.com/topic/375747-is-there-an-easy-and-aesthetically-pleasing-way-to-put-letters-on-sides-of-bases/#findComment-5863236 Share on other sites More sharing options...
Rik Lightstar Posted September 15, 2022 Share Posted September 15, 2022 There are a few ways to do it that I've seen. @Xenith's solution works well Painting it on, again higher contrast is better so black and white is best for being legible, the key with this is spacing your lettering accurately Decals are definitely an option if you have a home printer you can buy decal paper for it and print your own You'll need to find the right cure for the text so it fits the base size correctly but I'm sure you can find a tutorial online where someone else has done it 3d printed plates that you can then stick on Commercially from somewhere like https://www.versatileterrain.co.uk/name-plates If you have access to a 3d printer (or a friend with one) then you may well be able to design and print them yourself With those suggestions made though, unless the text is very different between units or there's a very small number of models then it's not always that big of a help from across a table. Primary colour bands or stripes work better for this. An alternative that might look better is something like these really long Etsy link and they can be moved around between your armies as needed. Rik Link to comment https://bolterandchainsword.com/topic/375747-is-there-an-easy-and-aesthetically-pleasing-way-to-put-letters-on-sides-of-bases/#findComment-5866619 Share on other sites More sharing options...
LameBeard Posted September 16, 2022 Share Posted September 16, 2022 If it is *just* a number, I don’t see it being that expensive for decals - you could just use one of the sheets with many numbers? Say like a Blood Bowl sheet? Or use a different symbol for each unit: skull/winged skull/laurel skull/crowned skull/lightning bolt/eagle etc are probably easy to get. I have occasionally put a coloured sticker *under* the base as a way of checking in unusual situations - hang on is this guy tactical squad A or tactical squad B? That is dead quick although they sometimes fall off. With mk Iv I would distinguish 2 squads on the shoulder pad by (say) vertical arrows for A, horizontal arrows for B, rather than the base. Trickier for mk vi. Pacific81 1 Back to top Link to comment https://bolterandchainsword.com/topic/375747-is-there-an-easy-and-aesthetically-pleasing-way-to-put-letters-on-sides-of-bases/#findComment-5866978 Share on other sites More sharing options...
Tallarn Commander Posted October 27, 2022 Share Posted October 27, 2022 All my Imperial Guard, World Eaters, Night Lords, Renegades and Heretics Chaos Militia, and my homebrew "Warpborn" CSM troopers (600+ models) have names painted on their bases. I still need to add bases to my Death Guard/Nurgle CSM. I do it more for fun and fluff than to track squads though. I rather enjoy tracking the exploits of individual troopers. I just use a black background and red lettering for Chaos and yellow lettering for my Tallarn IG army. Tallarns with names Night Lords with names on bases LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/375747-is-there-an-easy-and-aesthetically-pleasing-way-to-put-letters-on-sides-of-bases/#findComment-5879482 Share on other sites More sharing options...
LameBeard Posted October 28, 2022 Share Posted October 28, 2022 I think Lyle or one of the White Dwarf team used “découpage” (ie sticking on paper) on an Ork base in a recent White Dwarf. I can’t seem to find it though … Link to comment https://bolterandchainsword.com/topic/375747-is-there-an-easy-and-aesthetically-pleasing-way-to-put-letters-on-sides-of-bases/#findComment-5879635 Share on other sites More sharing options...
andes Posted October 28, 2022 Share Posted October 28, 2022 Dry-transfer letters? LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/375747-is-there-an-easy-and-aesthetically-pleasing-way-to-put-letters-on-sides-of-bases/#findComment-5879642 Share on other sites More sharing options...
LameBeard Posted October 28, 2022 Share Posted October 28, 2022 You mean like Letraset? Now you are bringing back memories. Could be a bit fiddly on the side of a base though. Link to comment https://bolterandchainsword.com/topic/375747-is-there-an-easy-and-aesthetically-pleasing-way-to-put-letters-on-sides-of-bases/#findComment-5879646 Share on other sites More sharing options...
andes Posted October 28, 2022 Share Posted October 28, 2022 2 hours ago, LameBeard said: You mean like Letraset? Now you are bringing back memories. Could be a bit fiddly on the side of a base though. Yeah exactly, from back before the days of desktop publishing when the thunder lizards walked the Earth Would be fiddly, but I think would look pretty good when done. LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/375747-is-there-an-easy-and-aesthetically-pleasing-way-to-put-letters-on-sides-of-bases/#findComment-5879667 Share on other sites More sharing options...
Beaky Brigade Posted October 29, 2022 Share Posted October 29, 2022 (edited) Speaking of old school, what about Dymo labels / Embossing tape?https://en.wikipedia.org/wiki/Embossing_tape Ok the standard 9mm tape may be too wide but it's an idea :D Edited October 29, 2022 by Beaky Brigade Link to comment https://bolterandchainsword.com/topic/375747-is-there-an-easy-and-aesthetically-pleasing-way-to-put-letters-on-sides-of-bases/#findComment-5879867 Share on other sites More sharing options...
Noserenda Posted October 31, 2022 Share Posted October 31, 2022 You can always just write them on with a fineliner/micro pen? I assume they might be available in colours other than black but thats the ones i use for stuff :) An example :)68251686_10157404933400797_712391493649694720_n Link to comment https://bolterandchainsword.com/topic/375747-is-there-an-easy-and-aesthetically-pleasing-way-to-put-letters-on-sides-of-bases/#findComment-5880111 Share on other sites More sharing options...
