hd3 Posted September 7, 2022 Share Posted September 7, 2022 (edited) So the owner of my local hobby shop unexpectedly gifted me a stormxast eternal still in sprue. Im strictly 40k myself but it occurred to me, i could convert this guy into a broken statue for terrain! So, does anyone have sny paint, colour, technique vetc. suggestions for achieving a statuery look? or alternatively how to turn this guy into a knock off dante or sanguinior? Edited September 7, 2022 by hd3 Link to comment https://bolterandchainsword.com/topic/375804-making-terrain-out-of-troops/ Share on other sites More sharing options...
Solution Khornestar Posted September 7, 2022 Solution Share Posted September 7, 2022 Depends on the material, but for an aged bronze look I bet this will work great: https://tablestandard.com/2017/04/04/imperial-statue/ Link to comment https://bolterandchainsword.com/topic/375804-making-terrain-out-of-troops/#findComment-5864756 Share on other sites More sharing options...
Dr_Ruminahui Posted September 8, 2022 Share Posted September 8, 2022 (edited) I second Khornestar on the aged bronze look - it is very evocative. Another thing about heroic statutory is that is typically on a plinth - that's the stone base on these statutes: I would consider swapping its head for a space marine head to make it fit better into the setting. If you are going for a broken statute, I would still build a plint for it and cut the fallen statue off at the ankles and glue those onto the plinth - that would be the weak point where the statue would break when it toppled. You could also do it in marble, in which case the statue would likely also break when it hit the ground - take a hobby saw and the model horizontally in a couple of places (probably in the torso, as marble, unlike bronze, is more likely to break along natural cleavage points in the material itself. You also might want to google images of roman statues to see where they break - typically they lose their limbs and faces. I've limited experience painting marble, so I can't really give you any advice other than there are tutorials in the Tutorials and How Tos section of this forum and elsewhere online. As for converting it into a space marine model, my advice would be to swap the head and arms with space marine ones and add a power backpack, all of which should be fairly easy but might require a little sawing and/or greenstuffing. You could then add a holster or grenades to the belt to give the model a more modern look. Edited September 8, 2022 by Dr_Ruminahui apologist and Khornestar 2 Back to top Link to comment https://bolterandchainsword.com/topic/375804-making-terrain-out-of-troops/#findComment-5865055 Share on other sites More sharing options...
hd3 Posted September 13, 2022 Author Share Posted September 13, 2022 (edited) warplock bronze vindicator statue with oxide wash Edited September 13, 2022 by hd3 Link to comment https://bolterandchainsword.com/topic/375804-making-terrain-out-of-troops/#findComment-5866085 Share on other sites More sharing options...
hd3 Posted September 13, 2022 Author Share Posted September 13, 2022 warplock bronze vindicator statie with oxide wash Rockybaerboa, Dr_Ruminahui, space wolf and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/375804-making-terrain-out-of-troops/#findComment-5866101 Share on other sites More sharing options...
