Marshal Mittens Posted September 17, 2022 Share Posted September 17, 2022 I have been debating on how to build mine. On one hand, lascannons are very powerful, but they are expensive for the turret option. The grav gun and volkite look cool, and I will probably build some, but they are a bit niche and pricey for an easy to kill tank. I have been leaning heavily towards Autocannon turret and Lascannon sponsons for a tank that's cheap, but also hits most things decently hard. How are you all planning to kit out your first few Predators? Link to comment https://bolterandchainsword.com/topic/375924-how-are-you-going-to-build-your-plastic-predators/ Share on other sites More sharing options...
GodEmperorOfMankind Posted September 17, 2022 Share Posted September 17, 2022 With glue and clippers! I've just built an old FW pred with lascannons and lascannons, because I want my world eaters to have something that can take out armour, and that seemed the best load out to take. The 3 new plastic ones I've earmarked for the Iron IV, will have autocannon turret and lascannon sponsons, for nostalgia and cheapness, and means they can have a pop at most targets Marshal Mittens 1 Back to top Link to comment https://bolterandchainsword.com/topic/375924-how-are-you-going-to-build-your-plastic-predators/#findComment-5867284 Share on other sites More sharing options...
sarovian Posted September 17, 2022 Share Posted September 17, 2022 (edited) I already have a plasma + lascannon sponsons pred, so I'm thinking about how to expand that squadron considering the shooting limitations. Current thinking is maybe autocannon+volkite loadout? Autocannon shooting at the same things as plas+las (light vehicles/heavy infantry) and the volkite sponsons making the most of being defensive weapons. Edit: Given the option, I'd build them all with plasma, but I'm not spending £60 on that forge world kit - once was enough! Edited September 17, 2022 by sarovian Marshal Mittens 1 Back to top Link to comment https://bolterandchainsword.com/topic/375924-how-are-you-going-to-build-your-plastic-predators/#findComment-5867318 Share on other sites More sharing options...
No Foes Remain Posted September 17, 2022 Share Posted September 17, 2022 Magnet on the turret and I figured out that the sponsons can be swapped out without magnets. Though feeling the volkite and heavy conversion beamer mostly, volkite for getting rid of infantry and heavy conversion beamer for all targets (Ap1 5" blast at 42"+, yes please). Marshal Mittens 1 Back to top Link to comment https://bolterandchainsword.com/topic/375924-how-are-you-going-to-build-your-plastic-predators/#findComment-5867335 Share on other sites More sharing options...
Gorgoff Posted September 18, 2022 Share Posted September 18, 2022 (edited) Shrapnel Cannons in the Sponsons mand a magnetised turret. @No Foes Remain The sponsons are easy to swap without magnets? Edited September 18, 2022 by Gorgoff Link to comment https://bolterandchainsword.com/topic/375924-how-are-you-going-to-build-your-plastic-predators/#findComment-5867521 Share on other sites More sharing options...
Misterduch Posted September 18, 2022 Share Posted September 18, 2022 With as many magnets as possible Link to comment https://bolterandchainsword.com/topic/375924-how-are-you-going-to-build-your-plastic-predators/#findComment-5867527 Share on other sites More sharing options...
No Foes Remain Posted September 18, 2022 Share Posted September 18, 2022 1 hour ago, Gorgoff said: Shrapnel Cannons in the Sponsons mand a magnetised turret. @No Foes Remain The sponsons are easy to swap without magnets? Yes, leave the top peg loose but glue the bottom on in then snip it down. Gun fits in, pop the top peg in and job is done. Only thing is that on the lascannon, heavy bolter and flamer you have to trim the part where the cable connects to the bottom disc down so the gun can move and file the other half on the bottom disc down to allow that free movement but otherwise works fine. Reyner, GodEmperorOfMankind, WrathOfTheLion and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/375924-how-are-you-going-to-build-your-plastic-predators/#findComment-5867533 Share on other sites More sharing options...
