Marshal Mittens Posted September 22, 2022 Share Posted September 22, 2022 I use AK interactive streaking grime quite a bit and this last time the models are still shiney after about a day of drying. Has this happened to anyone before, and how do I go about fixing it? Thanks! Link to comment https://bolterandchainsword.com/topic/375966-ak-interactive-streaking-grime-came-out-shiny/ Share on other sites More sharing options...
Firedrake Cordova Posted September 22, 2022 Share Posted September 22, 2022 I've never used the product (so take what follows with a pinch of salt) but if it's normally not glossy and it has dried glossy, then I'm guessing it wasn't mixed properly. I seem to remember a similar thread here this year, but can't find it. In terms of fixing it, if you varnish the model at the end of your painting process, that should give a uniform finish across the model. Aarik, andes and Magos Takatus 3 Back to top Link to comment https://bolterandchainsword.com/topic/375966-ak-interactive-streaking-grime-came-out-shiny/#findComment-5868619 Share on other sites More sharing options...
Magos Takatus Posted September 22, 2022 Share Posted September 22, 2022 7 hours ago, Firedrake Cordova said: I've never used the product (so take what follows with a pinch of salt) but if it's normally not glossy and it has dried glossy, then I'm guessing it wasn't mixed properly. I seem to remember a similar thread here this year, but can't find it. In terms of fixing it, if you varnish the model at the end of your painting process, that should give a uniform finish across the model. I'm not surprised you couldn't find it, it was all the way back on page six! Here's the thread. I think I fixed the streaking grime by putting in a couple of metal agitators to stir up all the gunk in the bottom of the bottle. The advice provided by Firedrake Cordova should be reliable as well. :) Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/375966-ak-interactive-streaking-grime-came-out-shiny/#findComment-5868740 Share on other sites More sharing options...
Firedrake Cordova Posted September 23, 2022 Share Posted September 23, 2022 That's the one - thanks, Magos! Somewhat annoyingly, I did use the search function, and still managed to not see it. Magos Takatus 1 Back to top Link to comment https://bolterandchainsword.com/topic/375966-ak-interactive-streaking-grime-came-out-shiny/#findComment-5868872 Share on other sites More sharing options...
