2gud2bbad Posted October 2, 2022 Share Posted October 2, 2022 Hi Friends, RoW: Headhunter Leviathal HQ Dynat Master of Signal Elites 10 Fulmentarus w/ Power Axes Troops 10 Headhunter Kill Team w/ MM and Prime w/ AA 10 Headhunter Kill Team w/ MM and Prime w/ AA Fast Attack 5 Headhunter Kill Team w/ MM, Prime w/ AA and 4 Combi-Meltas Xiphon Interceptor Heavy Support Leviathan Dreadnought w/ Dreadnough Droppod and 1 siege drill. should be 2010 points. Probably just drop one terminator and get some more gear on the rest of units like a ramjet diffraction grid on the Xiphon or some power fists or some weapons for Dynat gives himself, the MoS and the Fulmentarus infiltrate. The gameplay is quite clear, with the infiltrating HKT going for Land Raiders in T1 and the Fulmentarus for Terminators that may pop out of destroyed transports. The bigger HKTs go for softer targets such as normal tactical squads, support squads etc. The MoS is there to ensure the second wave of armour penetration (Xiphon) and killiness (Leviathan) if the initial alpha strike did not work out. Dynat and the MoS will just sit with the Fulmentarus. What do you guys think? Link to comment https://bolterandchainsword.com/topic/376096-al-2k-headhunter-leviathal/ Share on other sites More sharing options...
Slips Posted October 4, 2022 Share Posted October 4, 2022 Main question is: what are you using as Line (Scoring) units for this? Link to comment https://bolterandchainsword.com/topic/376096-al-2k-headhunter-leviathal/#findComment-5871869 Share on other sites More sharing options...
Xenith Posted October 4, 2022 Share Posted October 4, 2022 Yea, I don't think you can actually score objectives with this, so you're relying on Leviathal warlord bonus and other in-game secondaries. Link to comment https://bolterandchainsword.com/topic/376096-al-2k-headhunter-leviathal/#findComment-5871909 Share on other sites More sharing options...
Vostroi Posted October 6, 2022 Share Posted October 6, 2022 You need to have more fast attack than heavy support in Leviathal Link to comment https://bolterandchainsword.com/topic/376096-al-2k-headhunter-leviathal/#findComment-5872616 Share on other sites More sharing options...
Xenith Posted October 10, 2022 Share Posted October 10, 2022 On 10/6/2022 at 7:19 PM, Vostroi said: You need to have more fast attack than heavy support in Leviathal I'm seeing 2 fast attack in headhunters and the Xiphon, and 1 heavy in the Leviathan. Link to comment https://bolterandchainsword.com/topic/376096-al-2k-headhunter-leviathal/#findComment-5874011 Share on other sites More sharing options...
Galron Posted October 27, 2022 Share Posted October 27, 2022 Thinking 10 man HHs are too much. They work better as 5 mans, infiltrating forward and nuking buff characters with their precision strikes, and then they die to whoever was supposedly guarding the characters. If you dont get first turn, you redeploy them back. Brother Sutek 1 Back to top Link to comment https://bolterandchainsword.com/topic/376096-al-2k-headhunter-leviathal/#findComment-5879353 Share on other sites More sharing options...
Imren Posted October 27, 2022 Share Posted October 27, 2022 12 hours ago, Galron said: Thinking 10 man HHs are too much. They work better as 5 mans, infiltrating forward and nuking buff characters with their precision strikes, and then they die to whoever was supposedly guarding the characters. If you dont get first turn, you redeploy them back. If you play missions were you get VP for killing enemy units, then this is a disadvantage, 5 man squads are easy kills in 30k and therefore easy VPs Link to comment https://bolterandchainsword.com/topic/376096-al-2k-headhunter-leviathal/#findComment-5879547 Share on other sites More sharing options...
