sibomots Posted October 13, 2022 Share Posted October 13, 2022 Recently, I tried making model rocks and terrain with a mold. I poured in a mixture of Hydrocal Plaster into rubber molds and the results were great. The shape and detail was exactly what I wanted. But the problem -- it was Hydrocal Plaster powder, mixed with water. When it dries/cures it's still plaster and therefore a bit chalky and fragile. I broke a couple in half trying to get them out of the rubber mold. I can only foresee a problem trying to use them (fragments of them) on bases. I can imagine the jostling around in the Army Box will chip away and break off corners. I'm looking for an alternative way to cast molds so that the product is stronger, not susceptible to chipping and cracking (something stronger and more durable than 'plaster') What materials are in the market that achieve that? What should I mix and pour instead of 'Hydrocal Plaster' ? Thanks for your help/ideas LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/376239-stronger-terrain-model-substance/ Share on other sites More sharing options...
Imren Posted October 15, 2022 Share Posted October 15, 2022 Have you tried running wet toilet paper in a blender and mix that in? The paper fibers will strengthen the plaster mixture. Another option is tho use acrylic resin powder instead of plaster. Green stuff world sells this one that I have tried with good results: https://www.greenstuffworld.com/en/mold-making/718-acrylic-resin.html sibomots 1 Back to top Link to comment https://bolterandchainsword.com/topic/376239-stronger-terrain-model-substance/#findComment-5875781 Share on other sites More sharing options...
Slave to Darkness Posted October 18, 2022 Share Posted October 18, 2022 (edited) Would it work if you mix a tiiiiiny bit of pva into the mix? Might not work its just an idea that popped into my head. Or a thin layer of superglue over the rocks, just to give it a tougher top layer. Edited October 18, 2022 by Slave to Darkness Link to comment https://bolterandchainsword.com/topic/376239-stronger-terrain-model-substance/#findComment-5876781 Share on other sites More sharing options...
StratoKhan Posted November 20, 2022 Share Posted November 20, 2022 What Slave said - you should try adding PVA glue to the mix, and it’ll help with durability. I don’t remember exact proportions. Paper fibres are also a good idea, although I think that if you pulp them, it might not be as useful to the structural integrity, ideally you want longer fibres in there. Maybe try looking for hemp fibres? you can also try adding medical gauze before pouring. a side effect of these additions is that is you might get fibres sticking out of the casting, but if they’re natural fibres you can burn them off. Also, add ink, paint or dye to the mixture, to turn it the rock colour you want. this way if your rock chips, it’ll be much less noticeable. A higher proportion of plaster vs water also yields a denser less crumbly end product. Slave to Darkness and Brother Carpenter 2 Back to top Link to comment https://bolterandchainsword.com/topic/376239-stronger-terrain-model-substance/#findComment-5885613 Share on other sites More sharing options...
JeffJedi Posted December 18, 2022 Share Posted December 18, 2022 Add in some sand as Flux, it will be as hard as rock. The plaster will grab onto the sand and become very strong. Link to comment https://bolterandchainsword.com/topic/376239-stronger-terrain-model-substance/#findComment-5893371 Share on other sites More sharing options...
Maschinenpriester Posted December 19, 2022 Share Posted December 19, 2022 I did some casting with Stewalin. I dont know what the difference to regular plaster is though. it feels tougher to me though. For terrain I had also good results regarding durability. Link to comment https://bolterandchainsword.com/topic/376239-stronger-terrain-model-substance/#findComment-5893431 Share on other sites More sharing options...
Slave to Darkness Posted January 7, 2023 Share Posted January 7, 2023 Do all of the above at the same time. Thats gotta work lol. Antarius 1 Back to top Link to comment https://bolterandchainsword.com/topic/376239-stronger-terrain-model-substance/#findComment-5898113 Share on other sites More sharing options...
FashaTheDog Posted October 28, 2023 Share Posted October 28, 2023 (edited) A word of warning before reading my advice, I dove into playing with molten metals with safety knowledge already ingrained and this is not for the skittish or clumsy. That said, read on if you are curious or dare I say... (dare, dare) ...interested. Sorry, Blazing Saddles reference after that last conjunction. As someone working on metal 40K projects right now, you can cast those in a firm wax or in a lower melting point plastic or resin, then using sand casting pour some pewter over it and now your terrain is probably the most durable 40K you will be adding from this point on. At a melting point of ~250C you can easily melt it at home, just wear a respirator, proper attire, and have excellent ventilation. Also, the pot you use will forever be unfit for cooking so try to not use that cast iron cookware the spouse/parent/etc just bought. For a more Warp flavored set use bismuth instead. A high purity will get you a wonderful iridescent set of rocks that scream Warp terrain, you just need to wait a few days for it to oxidize. Edit: Given my avatar, I have to add: You will have the strongest terrain in Gensokyo. Edited October 28, 2023 by FashaTheDog Firedrake Cordova and Maschinenpriester 2 Back to top Link to comment https://bolterandchainsword.com/topic/376239-stronger-terrain-model-substance/#findComment-5998041 Share on other sites More sharing options...
Nostromo Posted March 28, 2024 Share Posted March 28, 2024 On 12/19/2022 at 11:09 AM, Maschinenpriester said: I did some casting with Stewalin. I dont know what the difference to regular plaster is though. it feels tougher to me though. Stewalin is more ceramic as far as i understand it. However, i can recommend it. I used it for casting of architectual details after a dozen of failed attempts with plaster - and that really worked like a charm. MUCH harder and durable than plaster - and even in enclosed moulds, it hardens within hours. Link to comment https://bolterandchainsword.com/topic/376239-stronger-terrain-model-substance/#findComment-6030921 Share on other sites More sharing options...
