Galron Posted October 13, 2022 Share Posted October 13, 2022 As we know, GW discontinued Gloss Nuln Oil, anyone know of a good replacement? Link to comment https://bolterandchainsword.com/topic/376243-gloss-nuln-oil-replacement/ Share on other sites More sharing options...
sbarnby71 Posted October 14, 2022 Share Posted October 14, 2022 Never used the gloss versions of these, obviously they leave a gloss finish, but in what other ways are they different to the non-gloss? Link to comment https://bolterandchainsword.com/topic/376243-gloss-nuln-oil-replacement/#findComment-5875576 Share on other sites More sharing options...
Karhedron Posted October 14, 2022 Share Posted October 14, 2022 22 minutes ago, sbarnby71 said: Never used the gloss versions of these, obviously they leave a gloss finish, but in what other ways are they different to the non-gloss? They are slightly less heavily pigmented. They were designed for use with metallics as using the normal washes on these killed the metallic shine. It is a shame they have stopped doing them as I don't know what I will use instead for metallic shading. Maybe the new formula washes work well enough on metals that a special version is no longer needed. I went out and bought a couple of pots from my LGS so I should be OK for a while. Maybe worth doing the same before they all disappear. Link to comment https://bolterandchainsword.com/topic/376243-gloss-nuln-oil-replacement/#findComment-5875584 Share on other sites More sharing options...
sbarnby71 Posted October 14, 2022 Share Posted October 14, 2022 11 minutes ago, Karhedron said: They are slightly less heavily pigmented. They were designed for use with metallics as using the normal washes on these killed the metallic shine. It is a shame they have stopped doing them as I don't know what I will use instead for metallic shading. Maybe the new formula washes work well enough on metals that a special version is no longer needed. I went out and bought a couple of pots from my LGS so I should be OK for a while. Maybe worth doing the same before they all disappear. Gottcha. I had seen some videos stating that the new Shades worked more like contrast paints (less staining on flat surfaces), not used them yet, but a bit worried how they will work say Nuln Oil over Leadbelcher. Link to comment https://bolterandchainsword.com/topic/376243-gloss-nuln-oil-replacement/#findComment-5875589 Share on other sites More sharing options...
Firedrake Cordova Posted October 14, 2022 Share Posted October 14, 2022 42 minutes ago, sbarnby71 said: Never used the gloss versions of these, obviously they leave a gloss finish, but in what other ways are they different to the non-gloss? As well as leaving a shiny finish (the regular washes did dull metallic finishes), they were supposed to run in to the recesses more and leave less "staining" on the raised areas. The new (Contrast-based) washes are supposed to be similar in terms of running off the raised areas more. Obviously, if you want a gloss finish, you can simply paint over the areas with a gloss varnish afterwards ... Link to comment https://bolterandchainsword.com/topic/376243-gloss-nuln-oil-replacement/#findComment-5875590 Share on other sites More sharing options...
sarabando Posted October 19, 2022 Share Posted October 19, 2022 you can get a gloss medium from Va;llejo and a drop or two mixed on your pallet should sort you out. Firedrake Cordova and Nocturne Noble 2 Back to top Link to comment https://bolterandchainsword.com/topic/376243-gloss-nuln-oil-replacement/#findComment-5877056 Share on other sites More sharing options...
Slave to Darkness Posted October 19, 2022 Share Posted October 19, 2022 Ahh they finally got rid of it? At least I aint gonna get a mislabeled pot anymore making my guardsmen look like they are in rubber flashers greatcoats. Sucks for you guys that like it though. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/376243-gloss-nuln-oil-replacement/#findComment-5877135 Share on other sites More sharing options...
