I know Armoured Breakthrough isn't great, but hope this might be able to at least give a good account of itself:
+HQ+
Sicaran Commander (207) Warlord, Accelerator autocannon, lascannon sponsons, hull-mounted shrapnel cannon, hunter-killer missile
Cataphractii Warsmith (177) Thunder hammer, volkite charger, grenade harness
     - Cataphractii Retinue (278) 1 Banner bearer with thunder hammer, 4 chosen with thunder hammers and volkite chargers
     - Dedicated Land Raider Proteus (235) Hull-mounted lascannon
+Elites+
Iron Circle Maniple (285) 2 Domitar-ferrum
Techmarine Covenant (201) 3 techmarines with power axes, volkite chargers, nuncio-voxes
+Troops+
Tactical Squad (153) Sergeant with power fist and shrapnel bolter, 9 marines with shrapnel bolters
+Heavy Support+
Scorpius Squadron (225) 2 whirlwinds
2997pts
The hope is that the Scorpius squadrons can unseat the biggest threat to the list, lascannon heavies who can return fire at my battle tanks. Any of the tacticals can hop out their LR to give the re-roll to scatter as needed, but the plan is to keep all the infantry inside their vehicles for as long as I can get away with for the mission. Enemy small arms are effectively neutered provided I can keep the tanks running (and having a Battlemsith inside each transport should certainly help with that).
Enemy armour should be wrecked in short order with the sea of S10 lascannon. Next on the list will be terminators. Four line units is probably the minimum but I'm hoping the fact they are encased in AV14 should let them last long enough to score as needed.  Iron Circle troubleshoot as necessary. The list doesn't make much use of the IW advanced reaction (or indeed many reactions at all) but it does lean into the +1S vs vehicles/dreads.
Edited by Brother Kraskor
https://bolterandchainsword.com/topic/376473-iw-various-ideas/
I like the idea of using Scorpius(es?) to hit those lascannon squads. To be honest I'm not sure how common those squads will really be, but that aoe will still be useful regardless of what you meet. They'd be devastating to Solar Auxilia.
Lists all still very much at concept stage. Reducing to 2k as something more to work towards, this feels very Iron Warriors:
+HQ+
Cataphractii Warsmith (177) Warlord (Stoic Defender) Thunder hammer, volkite charger, grenade harness
     - Cataphractii Retinue (226) 1 banner bearer with thunder hammer, 3 chosen with thunder hammers and volkite chargers
Cataphractii Siege Breaker (147) Thunder hammer, volkite charger
+Elites+
Rapier Battery (195) 3x laser destroyers
Rapier Battery (160) 2x quad launchers with frag and phosphex
+Troops+
Tactical Squad (130) Sergeant with lightning claw and shrapnel bolter, 9 marines with shrapnel bolters
+Heavy Support+
Predator Squadron (245) 2 tanks with predator cannon and lascannon sponsons
Scorpius Squadron (225) 2 tanks
2000pts
Could run with either IW-specific RoW. Massed shrapnel bolters at close range, or more reliable barrage at close range, guess I can always experiment and see. Siege breaker will apply Sunder to the laser destroyers - they'll now be S10 AP1 Sunder Exoshock(6+), no tank is surviving that!
Now this feels nasty:
+Rite of War+
Pride of the Legion
+HQ+
     - Cataphractii Retinue (226) Banner bearer with thunder hammer, 3 chosen with thunder hammers and volkite chargers
     - Land Raider Proteus (235) Hull lascannon
Praevian (110) Cyber-familiar
     - Castellax Maniple (430) 4 castellax with darkfire cannon
Siege Breaker (105) Warlord, Tyrant of Lyssatra
+Elites+
Rapier Battery (240) 3 quad launchers with frag and phosphex
+Troops+
Tactical Squad (120) 10 marines with Shrapnel bolters
Cataphractii Squad (210) 5 terminators with lightning claws and combi-bolters, grenade harness
+Heavy Support+
Tyrant Siege Squad (575) 10 terminators
2998pts
You don't really want to be at any range from this army. Tyrants (3 shots each on the krak rocket thanks to Warlord), Proteus, Castellax (with S8 & Sunder vs vehicles/dreads/automata thanks to IW trait and the Siege Breaker) all have long range and nasty firepower. As you get closer, you are hit with a sea of pinning bolters and phosphex shells. Seven Line units so plenty of mission scoring. Definitely needs to tackle assault units before they reach their lines, but if they do then the terminators of various kinds are capable of a resilient counter-punch.
Or:
+Rite of War+
Hammer of Olympia
+HQ+
Cataphractii Warsmith (172) Warlord (Stoic Defender) Thunder hammer, volkite charger
     - Castellax Maniple (325) 3 castellax with darkfire cannon
Vigilator (95)
+Troops+
+Heavy Support+
Tyrant Siege Squad (300) 5 terminators
Predator Squadron (269) 2 tanks with predator cannon, lascannon sponsons, shrapnel cannon
Leviathan Talon (660) 2 dreadnoughts with double cyclonic melta lances and phosphex dischargers
2997pts
This list has a lot of pinning (Warsmith, Vigilator, 4x tac squads, Predators) to try and keep the enemy in place while they get pounded with shooting. A serious volume of high strength weapons and a lot of AP2/AP1.
Register a new account
Sign in
