Xenith Posted November 10, 2022 Share Posted November 10, 2022 (edited) Just to confirm, you do not need line of sight (LoS) to charge in HH, however as overwatch is treated as a normal shooting attack, you do need LoS from the charging units starting position to be able to shoot them - so I could charge through a LoS blocking wall with no issue, or from behind a rhino as long as I have rolled high enough to go round it. Edited November 10, 2022 by Xenith Link to comment https://bolterandchainsword.com/topic/376512-rules-check-charging-and-line-of-sight/ Share on other sites More sharing options...
Solution MichaelCarmine Posted November 10, 2022 Solution Share Posted November 10, 2022 (edited) Page 180 - Declare Charge "... A unit can never declare a Charge against a unit that is outside of its Maximum Charge Distance, nor can it declare a Charge against a unit it cannot draw a valid line of sight to,..." Edited November 10, 2022 by MichaelCarmine Gorgoff, LameBeard, Xenith and 2 others 2 3 Back to top Link to comment https://bolterandchainsword.com/topic/376512-rules-check-charging-and-line-of-sight/#findComment-5882823 Share on other sites More sharing options...
Xenith Posted November 11, 2022 Author Share Posted November 11, 2022 Thanks, somehow missed that line! Link to comment https://bolterandchainsword.com/topic/376512-rules-check-charging-and-line-of-sight/#findComment-5883232 Share on other sites More sharing options...
Dont-Be-Haten Posted November 13, 2022 Share Posted November 13, 2022 On 11/11/2022 at 12:20 PM, Xenith said: Thanks, somehow missed that line! I did too at first. It's because it's not until halfway into the next couple paragraphs over. Link to comment https://bolterandchainsword.com/topic/376512-rules-check-charging-and-line-of-sight/#findComment-5883542 Share on other sites More sharing options...
