Rince Posted November 13, 2022 Share Posted November 13, 2022 Hi, I am going mental over some 3D printed parts I got from pop goes the monkey and hope some of you can help out. In the past I have built resign models from forgeworld, this half-resign from GW, never a problem. I soak the parts in warm water with added Dawn and give them a good scrub. Now with the 3D printed parts, nothing sticks. I’ve tried Army Painter Super Glue, Gorilla Super Glue and Loctite Ultra gel. I have been successful glueing fingers together, myself to the wall, and everything in reach. So the glues are generally working. Is there some occult handling of printer resin I am missing? What is your go-to glue? Link to comment https://bolterandchainsword.com/topic/376547-resin-glue-for-3d-printed-parts/ Share on other sites More sharing options...
Doghouse Posted November 13, 2022 Share Posted November 13, 2022 That sounds odd, do you know what kind of resin they used because I just use Gorilla glue on my 3d printed stuff and it bonds stupidly well. Link to comment https://bolterandchainsword.com/topic/376547-resin-glue-for-3d-printed-parts/#findComment-5883688 Share on other sites More sharing options...
Rince Posted November 13, 2022 Author Share Posted November 13, 2022 It says “fine detail plastic that is acrylic material[…]” Link to comment https://bolterandchainsword.com/topic/376547-resin-glue-for-3d-printed-parts/#findComment-5883690 Share on other sites More sharing options...
NovemberIX Posted November 14, 2022 Share Posted November 14, 2022 Depending on the parts that need to mate up, you might be better served by sanding or scraping a slightly rougher surface for the adhesive to work into. Relatedly, did the glue leave a residue on the resin part? Firedrake Cordova and Doghouse 2 Back to top Link to comment https://bolterandchainsword.com/topic/376547-resin-glue-for-3d-printed-parts/#findComment-5883717 Share on other sites More sharing options...
Bung Posted November 14, 2022 Share Posted November 14, 2022 I used normal superglue for pgtm stuff. But i buy the cheapest in 20 ml bottles from eBay. Link to comment https://bolterandchainsword.com/topic/376547-resin-glue-for-3d-printed-parts/#findComment-5883746 Share on other sites More sharing options...
Arkhanist Posted November 14, 2022 Share Posted November 14, 2022 (edited) I've always used superglue for 3d printed parts, including shapeways and various UV resins I've printed myself without any issues. Mostly loctite gel, but works fine with others too. Popgoesthemonkey don't specify the resin they use, but they do say to just use superglue like other resins. So the first thing to try would be to rinse both parts again in just plain water, just in case (i.e. 3d part and what you're sticking it to) Then use fine grade sandpaper or a jewellers file to add some roughness to both surfaces and try again with superglue. If it's still not working, I'd probably go old school and try out some 2 part epoxy glue; that stuff sticks pretty much anything solid together. Edited November 14, 2022 by Arkhanist Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/376547-resin-glue-for-3d-printed-parts/#findComment-5883831 Share on other sites More sharing options...
Rince Posted November 14, 2022 Author Share Posted November 14, 2022 Thank you all for your replies! I’ll try epoxy to end this once and for all Link to comment https://bolterandchainsword.com/topic/376547-resin-glue-for-3d-printed-parts/#findComment-5883985 Share on other sites More sharing options...
Sky Potato Posted November 14, 2022 Share Posted November 14, 2022 Try drilling and pinning on top of the glue if just gluing fails Link to comment https://bolterandchainsword.com/topic/376547-resin-glue-for-3d-printed-parts/#findComment-5883997 Share on other sites More sharing options...
Imren Posted November 14, 2022 Share Posted November 14, 2022 I have been building with 3D-printed UV-resin, FW resin and other 3rd party resin and never had any issue, but this is what I do: Put the parts in a 1-2 liter bowl and squirt some dishwashing detergent in the bowl. Fill up with hot water and let it soak for a few hours. Take an old toothbrush and dip the head in a dishwashing detergent solution (keep it in a glass next to you on the kitchen bench) and give every part a good brushing. Rinse parts and let dry. Assemble the model(s). I also pin the feet and cork them up as a handle. Give them another light brush with the toothbrush soaked in dishwashing detergent solution and rinse so that skin oils from touching during assembly gets cleaned away. Let them dry and prime. Wait 24h for the primer to cure. This way the primer stucks really well and you can sand it. I use enamel primers (Alclad II primer and AK xtreme primer filler) for scenery (more robust) and acrylics such as Vallejo and stynylrez primers for models and never had any issue. Link to comment https://bolterandchainsword.com/topic/376547-resin-glue-for-3d-printed-parts/#findComment-5884002 Share on other sites More sharing options...
Grotsmasha Posted November 16, 2022 Share Posted November 16, 2022 (edited) On 11/15/2022 at 7:39 AM, Sky Potato said: Try drilling and pinning on top of the glue if just gluing fails From experience, I'd recommend NOT drilling into 3D printed resin, it is typically too brittle. Torso's might be fine, but arms/wrists/gun barrels are too small and they'll shatter. Edited November 16, 2022 by Grotsmasha Sky Potato 1 Back to top Link to comment https://bolterandchainsword.com/topic/376547-resin-glue-for-3d-printed-parts/#findComment-5884329 Share on other sites More sharing options...
Craig Posted November 16, 2022 Share Posted November 16, 2022 Maybe they didn't clean the resin properly or used something odd to clean it. I'd suggest giving them a bath in isopropyl alcohol to see if that helps. Link to comment https://bolterandchainsword.com/topic/376547-resin-glue-for-3d-printed-parts/#findComment-5884343 Share on other sites More sharing options...
Sky Potato Posted November 16, 2022 Share Posted November 16, 2022 1 hour ago, Grotsmasha said: From experience, I'd recommend NOT drilling into 3D printed resin, it is typically too brittle. Torso's might be fine, but arms/wrists/gun barrels are too small and they'll shatter. Completely fair point - I just had resin in my head, and not 3D printed resin. Thanks for the correction. Link to comment https://bolterandchainsword.com/topic/376547-resin-glue-for-3d-printed-parts/#findComment-5884346 Share on other sites More sharing options...
Khulu Posted November 16, 2022 Share Posted November 16, 2022 1 hour ago, Grotsmasha said: From experience, I'd recommend NOT drilling into 3D printed resin, it is typically too brittle. Torso's might be fine, but arms/wrists/gun barrels are too small and they'll shatter. Really depends on the quality of the resin too. Some is totally fine for drilling, some is more brittle. Hard to know which is which until you ruin your print, unfortunately. Link to comment https://bolterandchainsword.com/topic/376547-resin-glue-for-3d-printed-parts/#findComment-5884347 Share on other sites More sharing options...
