angrom Posted November 17, 2022 Share Posted November 17, 2022 Quick question, Would the mechanised infantry regiment trait allow a unit to embark at beginning of movement phase, move the vehicule and then disembark? Link to comment https://bolterandchainsword.com/topic/376570-mechanised-infantry/ Share on other sites More sharing options...
sairence Posted November 17, 2022 Share Posted November 17, 2022 I think there's something in the core rules that prevents units from embarking and disembarking in the same turn. Can't look it up right now though. Could also look for any FAQ about the Impulsor, since it also has a disembark after moving rule. Link to comment https://bolterandchainsword.com/topic/376570-mechanised-infantry/#findComment-5884579 Share on other sites More sharing options...
TechCaptain Posted November 17, 2022 Share Posted November 17, 2022 I believe you can but with an strat. Link to comment https://bolterandchainsword.com/topic/376570-mechanised-infantry/#findComment-5884650 Share on other sites More sharing options...
defl0 Posted November 17, 2022 Share Posted November 17, 2022 Another clever thing you should know... You can move move move a unit then a commisar can jump out of a chimera and switch their order to something like advance and still be able to use an order ;) Link to comment https://bolterandchainsword.com/topic/376570-mechanised-infantry/#findComment-5884664 Share on other sites More sharing options...
sairence Posted November 17, 2022 Share Posted November 17, 2022 Depends on how exactly the whole "a unit can only be affected by one order" is worded I guess. Link to comment https://bolterandchainsword.com/topic/376570-mechanised-infantry/#findComment-5884667 Share on other sites More sharing options...
mertbl Posted November 19, 2022 Share Posted November 19, 2022 The core rules don't let you embark/disembark or disembark/embark in the same PHASE. Pretty sure you can only be effected by 1 order per turn. Emperor Ming 1 Back to top Link to comment https://bolterandchainsword.com/topic/376570-mechanised-infantry/#findComment-5884959 Share on other sites More sharing options...
Inquisitor_Lensoven Posted November 28, 2022 Share Posted November 28, 2022 T.Prime no longer transports commissars :’( Link to comment https://bolterandchainsword.com/topic/376570-mechanised-infantry/#findComment-5887691 Share on other sites More sharing options...
mertbl Posted November 28, 2022 Share Posted November 28, 2022 Yes it does. Emperor Ming 1 Back to top Link to comment https://bolterandchainsword.com/topic/376570-mechanised-infantry/#findComment-5887785 Share on other sites More sharing options...
Inquisitor_Lensoven Posted November 28, 2022 Share Posted November 28, 2022 3 hours ago, mertbl said: Yes it does. My bad you are correct i missed the key word under the transport section. Link to comment https://bolterandchainsword.com/topic/376570-mechanised-infantry/#findComment-5887872 Share on other sites More sharing options...
Shamansky Posted November 30, 2022 Share Posted November 30, 2022 On 11/18/2022 at 12:07 AM, sairence said: Depends on how exactly the whole "a unit can only be affected by one order" is worded I guess. It sais that if a unit is affected by another order the new order replaces the old one. Link to comment https://bolterandchainsword.com/topic/376570-mechanised-infantry/#findComment-5888366 Share on other sites More sharing options...
Emperor Ming Posted November 30, 2022 Share Posted November 30, 2022 2 hours ago, Shamansky said: It sais that if a unit is affected by another order the new order replaces the old one. replaces, you dont even get a choice, that's terrible Link to comment https://bolterandchainsword.com/topic/376570-mechanised-infantry/#findComment-5888402 Share on other sites More sharing options...
