ems_goof Posted November 27, 2022 Share Posted November 27, 2022 While I’ve been playing AT for a few years now, I stopped playing 40K when 6th edition came out. With the release of the HH starter, I’m feeling the urge to build a small 30K force. Thoughts on this IF list to start? Praetor in Terminator Armour: Warlord (Architect of Devastation); Rite of War (Pride of the Legion); Cataphractii terminator armour; power weapon 15 Tactical Space Marines: Tactical Sergeant; 14 Tactical Space Marines 15 Tactical Space Marines: Tactical Sergeant; 14 Tactical Space Marines Contemptor Dreadnought Talon • Contemptor Dreadnought: kheres assault cannon; Gravis lascannon 10 Heavy Support Marines: Heavy Support Sergeant; 9 Heavy Support Marines; autocannons Predator Tank Squadron • Predator Tank: turret-mounted twin-linked Illiastus assault cannon; two sponson-mounted lascannon 1,000 points LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/376687-returning-to-gw/ Share on other sites More sharing options...
Noserenda Posted November 28, 2022 Share Posted November 28, 2022 Seems alright, though you might suffer against Spartans and the like, couple of broad tips: Dreadnoughts usually benefit from a fist, you dont need to take a Rite of war, yours isnt offering you any benefits here, id probably look at giving your tactical sergeants some gear too, a blob of 15 with nothing but bolters is not going to achieve much in most games, barebones you may as well just run squads of 10 and look at maybe an assault focused squad to run with your praetor? BadgersinHills 1 Back to top Link to comment https://bolterandchainsword.com/topic/376687-returning-to-gw/#findComment-5887644 Share on other sites More sharing options...
Xenith Posted November 28, 2022 Share Posted November 28, 2022 Hi Ems, great to see you getting into heresy! From your list, are you going to try and start with the AoD box? As noserenda says, you current gain nothing from that rite of war, so you can always switch to a cheaper Centurian at the 1k point mark until you need a specific rite - or you can use the rite that makes HSS's into Line units for scoring? That would be one immediate improvement. The tacticals could do with some gear - namely artificer armour on the serges, and maybe a vexilla, then a melee weapon of some kind if you want them in combat. You could possibly drop one tac unit to get 15 despoilers to run with your praetor, as noserenda says. LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/376687-returning-to-gw/#findComment-5887760 Share on other sites More sharing options...
