Glute Posted January 10, 2023 Share Posted January 10, 2023 Is there any method of issuing orders (mechanised) to titanic (LOW) vehicles with the 9th edition codex? Vaunted Praetorian doesn't work if you only have 1 LOW in your list because you can't order yourself since you gain the officer keyword. You could order other LOW in your list. I'm trying to find out what 'buffs' you can give a single LOW in a list. There a few stratagems you can use since titanic units gain REGIMENTAL keyword, etc. Link to comment https://bolterandchainsword.com/topic/377122-orders-to-baneblades/ Share on other sites More sharing options...
Hiroitchi Posted January 10, 2023 Share Posted January 10, 2023 (edited) Ummm you can order yourself because you have the keyword of a Super Heavy as a Astra Militarum Titanic unit. The other way to issue orders to a super heavy is through Lord Solar. The main thing about Ordering super heavies is that the orders for don’t bounce to other titanic units. Edited January 10, 2023 by Hiroitchi FollowerofDG, Jaipii and sairence 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/377122-orders-to-baneblades/#findComment-5898746 Share on other sites More sharing options...
sairence Posted January 10, 2023 Share Posted January 10, 2023 The officer keyword is irrelevant here, as it doesn't say anything about receiving orders. Generally mechanised orders can go to SQUADRON units and that's it. The reason TCs can't usually benefit from their own orders is because they lack this keyword. Same way it works with regimental/prefectus orders and the PLATOON keyword Vaunted Praetorian also allows orders to go to super heavies, which your Baneblade is, so it can order itself. I ran a Shadowsword at a local event before christmas with that, it was great. MrKoolPants, librisrouge and Hiroitchi 3 Back to top Link to comment https://bolterandchainsword.com/topic/377122-orders-to-baneblades/#findComment-5898781 Share on other sites More sharing options...
Diagramdude Posted January 10, 2023 Share Posted January 10, 2023 I also ran Vaunted Praetorian on a Banesword and had it order itself and let the order bounce to SQUADRON russ and chimera nearby, it was great sairence, Shamansky, MrKoolPants and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/377122-orders-to-baneblades/#findComment-5898786 Share on other sites More sharing options...
TCC Posted January 10, 2023 Share Posted January 10, 2023 I used it on a Banehammer last night with auto wounding on 5+ and it had a squad of Kasrkin on the shooting deck - it was a death machine with the 5++ from the engineer. Link to comment https://bolterandchainsword.com/topic/377122-orders-to-baneblades/#findComment-5898923 Share on other sites More sharing options...
Tokugawa Posted January 10, 2023 Share Posted January 10, 2023 Ingrained precision. You will love to use it every turn while you can. Even your tank was knock down to BS6+, RAW rules says 5 is still a wound. Link to comment https://bolterandchainsword.com/topic/377122-orders-to-baneblades/#findComment-5898981 Share on other sites More sharing options...
