Chevaliernoir Posted February 3, 2023 Share Posted February 3, 2023 Hi all! New Astra Militarum player here. I’m about to get a few models to bolster my armoured ranks and was wondering if the new rogal dorn is really worth the extra points cost over a russ? I have a Chimera, one Russ and a sentinel as it stands so any other recommendations are always welcome duz_ 1 Back to top Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/ Share on other sites More sharing options...
TCC Posted February 3, 2023 Share Posted February 3, 2023 It is if you put some tank ace on it (I use knight of pity 5++). Chances are it will last longer than a Russ and gives out more fire power + T9 makes a big difference! Meltas wounding on 5 often bounce. Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5906398 Share on other sites More sharing options...
Emperor Ming Posted February 3, 2023 Share Posted February 3, 2023 No is the short answer, its just too many points The heavy stubbers should be free really There's a few weird overcosted things in the guard dex Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5906404 Share on other sites More sharing options...
Santaclauswitz Posted February 3, 2023 Share Posted February 3, 2023 Dorn vs russ.... to be honest there probably isn't much in it point to point. I reckon the russ might just pip the dorn but it's so close as to be functionally meaningless. I've been toying with one list with two variants. The first has a dorn the second has a russ and hydra in it's place. I'll play both and see how it goes. Warden-Paints 1 Back to top Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5906408 Share on other sites More sharing options...
Tokugawa Posted February 3, 2023 Share Posted February 3, 2023 For a new player, a 55 pounds model which is ~300pts is a good and safe investment for you to got a 2000pts army earlier. Santaclauswitz, Warden-Paints, brother_b and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5906410 Share on other sites More sharing options...
Inquisitor_Lensoven Posted February 3, 2023 Share Posted February 3, 2023 Are you planning to go into the tournament scene? if yes, I think the mathhammer says no. if no, then it’s worth it if you like it. The rules for the tank will change fairly regularly Warhead01, Slave to Darkness, Chevaliernoir and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5906412 Share on other sites More sharing options...
Tokugawa Posted February 4, 2023 Share Posted February 4, 2023 10 hours ago, Inquisitor_Lensoven said: Are you planning to go into the tournament scene? if yes, I think the mathhammer says no. if no, then it’s worth it if you like it. The rules for the tank will change fairly regularly One reason of we haven't seen any tournament tops list taking a Dorn, is: no player received the model until last week. And it is not a model which could be converted. Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5906532 Share on other sites More sharing options...
Inquisitor_Lensoven Posted February 4, 2023 Share Posted February 4, 2023 19 minutes ago, Tokugawa said: One reason of we haven't seen any tournament tops list taking a Dorn, is: no player received the model until last week. And it is not a model which could be converted. I mean they’ve been getting 3D printed almost since the reveal, but i didn’t say anything about them being used in lists topping tournaments, I said the mathhammer suggests no. One or two lists using them and winning events doesn’t change that, it just means some people got some better than average rolls Slave to Darkness and Emperor Ming 2 Back to top Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5906537 Share on other sites More sharing options...
Sawtooth Posted February 6, 2023 Share Posted February 6, 2023 I have wondered this as I expand my army. One thing I notice is that the Leman Russ is really really good, which detracts from the value of the Dorn. There's also maneuvering around terrain to consider, and Dorn's can't take dozer blades and are extra large so positioning could be tough. Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5907214 Share on other sites More sharing options...
Shamansky Posted February 6, 2023 Share Posted February 6, 2023 Dorn is a new model. It will be made to outshine old models in future editions. So, if you're new player, I'd suggest not to bother with previous editions models at all. Just pick new releases. Slave to Darkness and Warden-Paints 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5907232 Share on other sites More sharing options...
dees Posted February 6, 2023 Share Posted February 6, 2023 Chevalienoir As a collector definitely get one. In games terms It is not tough enough to out last 2 LRBT IMO so you need to upgrade it (like the 5++) to get best use and most points back. I think it can be in a competitive list as long as you can apply heavy pressure on your opponent from other sources, like Kasrkin, other tanks and Sentinels. Shamansky as far a future editions that seems likely, but recently many armies have had older units like Wolf Guard Terminators get glow-ups, and the the LRBL box was upgraded to include all turret options so I think its not going anywhere. At least I really hope that's the case. Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5907490 Share on other sites More sharing options...
Shamansky Posted February 7, 2023 Share Posted February 7, 2023 (edited) 9 hours ago, dees said: Shamansky as far a future editions that seems likely, but recently many armies have had older units like Wolf Guard Terminators get glow-ups, and the the LRBL box was upgraded to include all turret options so I think its not going anywhere. At least I really hope that's the case. I have my doubts looking at my Elysian Drop Troops full force battallion with both kinds of Tauroses and 100+ of classic Black Templar marines with classic Grimaldus, EChamp, Bike Chaplain and Helbrecht. And plese save those 'you can still play them'. Dorn has almost twice as many guns as Russ, and all the buffs you can spare on a BATTLE TANK will have almost twice greater effect. Edited February 7, 2023 by Shamansky Galron 1 Back to top Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5907626 Share on other sites More sharing options...
OttoVonAwesome Posted February 7, 2023 Share Posted February 7, 2023 Yeah it's got more guns but alot of em are shorter ranged and you'll have to move the thing up to really get the most of it wich can put in harms way. Most Russ variants can happily sit back and just plunk away and make more use of cover. It's a cool tank but i'd never take more than one. Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5907640 Share on other sites More sharing options...
jarms48 Posted February 7, 2023 Share Posted February 7, 2023 5 hours ago, Shamansky said: I have my doubts looking at my Elysian Drop Troops full force battallion with both kinds of Tauroses and 100+ of classic Black Templar marines with classic Grimaldus, EChamp, Bike Chaplain and Helbrecht. And plese save those 'you can still play them'. Dorn has almost twice as many guns as Russ, and all the buffs you can spare on a BATTLE TANK will have almost twice greater effect. Dorn is dead-on-arrival at the moment. Russes are just far more efficient. The Vanquisher and Executioner need to go up 10 points and the Dorn needs to go down at least 10 points just to be viable. That's also only the oppressor cannon variant. The twin battle cannon variant is just terrible, far too swingy and it'd still be better to just take 2 Russes. Emperor Ming 1 Back to top Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5907715 Share on other sites More sharing options...
Emperor Ming Posted February 7, 2023 Share Posted February 7, 2023 More than a 10pts drop is needed really I don't like any of its weapons, If you roll low by the time you hit wound and saves, you may not even do any damage T9 vs some of the 9th stuff, wont even matter vs the s10-15 bracket Considering Gcults got free heavy stubbers, its something guard need really. A lot of upgrades that might have been worth 5pts in past editions, are worthless now Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5907746 Share on other sites More sharing options...
Warhead01 Posted February 7, 2023 Share Posted February 7, 2023 The contrarian in me almost wants to field these tanks. I'd look for a 3rd party model probably. It almost reminds me of the Gladiator tank which on it's onw has not been very good to me on the table. Probably need to field 2 to 3 Dorn tanks to be happy with them. At first glance I just want a lot of meltas on them. No plans to buy any, still not sure about how much energy I will put into my Guard now with the new codex. I'm sure the mathhammer crowd is probably right as far as competitive choices. Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5907812 Share on other sites More sharing options...
Inquisitor_Lensoven Posted February 8, 2023 Share Posted February 8, 2023 17 hours ago, OttoVonAwesome said: Yeah it's got more guns but alot of em are shorter ranged and you'll have to move the thing up to really get the most of it wich can put in harms way. Most Russ variants can happily sit back and just plunk away and make more use of cover. It's a cool tank but i'd never take more than one. ‘Shorter range’ 30” is plenty of range in the current rules and typical table sizes. Long range is pretty pointless unless it’s an indirect fire weapon Emperor Ming 1 Back to top Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5908048 Share on other sites More sharing options...
mertbl Posted February 8, 2023 Share Posted February 8, 2023 I think if you bring a Dorn, you bring 3. Total T9 overload. Warhead01 and Emperor Ming 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5908480 Share on other sites More sharing options...
jarms48 Posted February 9, 2023 Share Posted February 9, 2023 On 2/7/2023 at 10:52 PM, Emperor Ming said: More than a 10pts drop is needed really I don't like any of its weapons, If you roll low by the time you hit wound and saves, you may not even do any damage T9 vs some of the 9th stuff, wont even matter vs the s10-15 bracket Considering Gcults got free heavy stubbers, its something guard need really. A lot of upgrades that might have been worth 5pts in past editions, are worthless now They're not that bad, they just lose out to Executioners and Vanquishers (which all other Russes lose out to as well). 10 point hike on both of those variants makes the others more viable. 10 point hike also reduces the point difference between them and the Dorn. Then dropping the Dorn by 10 as well will be an effective 20 point difference from now. Still doesn't help the twin battle cannon, I don't know what GW were thinking when they left it as 2D6 (should have been cheaper or 6+2D3). The oppressor is pretty decent, basically a better long range demolisher cannon. The heavy stubbers definitely should have been free and leave the 5 points for the meltas, just like how knights are handled. Emperor Ming 1 Back to top Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5908575 Share on other sites More sharing options...
Malakithe Posted February 10, 2023 Share Posted February 10, 2023 If you like it then get it as least for the hobby side of painting. For me i opted to take a baneblade finally since the AoO detachment makes it so easy now. Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5908966 Share on other sites More sharing options...
TCC Posted February 10, 2023 Share Posted February 10, 2023 3 hours ago, Malakithe said: If you like it then get it as least for the hobby side of painting. For me i opted to take a baneblade finally since the AoO detachment makes it so easy now. I take both (Baneblade variant - the Baneblade IMO is not the best). Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5909040 Share on other sites More sharing options...
Malakithe Posted February 10, 2023 Share Posted February 10, 2023 55 minutes ago, TCC said: I take both (Baneblade variant - the Baneblade IMO is not the best). I like it as an all rounder Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5909061 Share on other sites More sharing options...
Warhead01 Posted February 10, 2023 Share Posted February 10, 2023 I think what I like about it is that it reminds me of the Bauhaus Grizzly from warzone back in very late 90's. It's really close in design to that picture and old armor cast or crystal cast vehicle. Maybe smaller but still very close. Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5909077 Share on other sites More sharing options...
Tokugawa Posted February 20, 2023 Share Posted February 20, 2023 https://listbot40k.herokuapp.com/event_list/BY4L6X0X0P this player won a 50 players GT last week. Emperor Ming 1 Back to top Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5912211 Share on other sites More sharing options...
sairence Posted February 20, 2023 Share Posted February 20, 2023 4 minutes ago, Tokugawa said: https://listbot40k.herokuapp.com/event_list/BY4L6X0X0P this player won a 50 players GT last week. That's a nice list for sure. I'm not super convinced that 2 Dorns is better than the 4 Russes you'd get for the same price...but then I haven't played with them yet and I haven't won any GTs. Link to comment https://bolterandchainsword.com/topic/377458-rogal-dorn-is-it-worth-it/#findComment-5912212 Share on other sites More sharing options...
