Vostroi Posted February 6, 2023 Share Posted February 6, 2023 Delegatus with the Tyrants and Saboteur in the Headhunters squad. Vigilator either with a tact squad or the recon to have access to their augury scanner. Primary Detachment Rite of war: Headhunter Leviathal HQ Warlord Trait: Hydra Excursior or Master of Lies Cataphractii Centurion Delegatus 85pts Delegatus 25pts Power Dagger 5pts 115pts Centurion Saboteur 60pts Saboteur upgrade 15pts Nemesis bolter 5pts Power dagger 5pts 85pts Centurion Vigilator 60pts Vigilator upgrade 35pts Power Dagger 5pts 100 pts Troops Tactical Squad (10) 100pts 100pts Tactical Squad (10) 100pts 100pts Reconnaissance Squad (5) 85pts Augury Scanner 10pts Nemesis Bolters 50pts 145pts Fast Attack Sky Hunter Squad (3) 105pts 3 multi melta 45pts 150pts Seeker Squad (5) 105pts Seeker Sergeant combi disintegrator 10pts 115pts Headhunter Kill Team (5) 125pts +5 Headhunders 100pts Multi Melta 20pts Artificier Armor 10pts 255pts Elite Contemptor Dreadnought (1) 175pts Gravis Power fist with built in graviton gun 15pts Gravis Melta Cannon 5pts 195pts Heavy Support Heavy Support Squad (5) 100pts +2 Legionaires 30pts 7 Lascannons 70pts Augury Scanner 10pts artificer armor 10pts 220pts Tyrant Siege Terminator Squad (5) 300pts +2 Tyrants 110pts Chainfist 5pts Power Dagger 5pts 420pts 2000 Agramar_The_Luna_Wolf 1 Back to top Link to comment https://bolterandchainsword.com/topic/377493-alpha-legion-headhunter-leviathal-with-tyrants/ Share on other sites More sharing options...
Xenith Posted February 6, 2023 Share Posted February 6, 2023 Personally I prefer meltas on the headhunters - I feel that scorpius rounds are superior to banestrike, and are 6ppm cheaper! Tyrants are already BS5 right, so don't benefit from Excursor, so the other trait might be better? Immediate tweaks I'd make would be find 30pts and split the HH's into 2x5 with MM's, and move one into troops, then upgrade the dagger on the sabateur - I'm a fan of TLLC's to threaten power armour units once the serges have been sniped. The delegatus doesn't seem to be doing much other than unlocking a RoW, so you can save points by swapping the cata armour to a boarding shield to retain heavy. If he's there to tank for the terms, then make the vigilator the warlord with excursor and stick him with the recons. Seekers have a high tax to take the unit, then get a big discount (drop from 21ppm to 15), so I'd be tempted to take more. I've had fun running 10 with the sabateur to give them shroud bombs. I personally believe that Effrit are far superior to non-melta headhunters at killing marines, and seekers are also better at sniping characters, and can do it from 24" away rather than 18". Link to comment https://bolterandchainsword.com/topic/377493-alpha-legion-headhunter-leviathal-with-tyrants/#findComment-5907281 Share on other sites More sharing options...
Vostroi Posted February 6, 2023 Author Share Posted February 6, 2023 Tyrants are BS4 only so the delegatus in there really pumps up the damage output. I have the cataohractii praetor model so I may as well use it since it's so nice. You're probably right about the headhunters being split in two and maybe cutting the saboteur since his main goal is to give the HH shroud bombs. Seekers can probably be replaces by something I just wanted to have a second unit use marked for death. Id like to make some minor tweeks and maybe combine the tactical squads into a fully loaded tactical squad. Link to comment https://bolterandchainsword.com/topic/377493-alpha-legion-headhunter-leviathal-with-tyrants/#findComment-5907363 Share on other sites More sharing options...
Xenith Posted February 6, 2023 Share Posted February 6, 2023 Oh, weird, I'd assumed they were BS5. Maybe consider swapping for Fulmentarus then? They're native BS5 with arguably better missiles, and can shoot without LOS with guided fire so they can't even be shot back. AP2 Brutal 2 is good for kiling terms and dreads, while AP3 on the kraks will just bounce off. Dropping the Heavy option then also gives you more freedom to play with FA slots. The delegatus can then go somewhere else - 20 tacs with a +1 to hit delegatus can put out some damage. Link to comment https://bolterandchainsword.com/topic/377493-alpha-legion-headhunter-leviathal-with-tyrants/#findComment-5907372 Share on other sites More sharing options...
Vostroi Posted February 6, 2023 Author Share Posted February 6, 2023 I'm intentionally not using any pdf units. I don't mind if others use them but I'm making my list from books only. Quote Fulmentarus don't belong in any friendly game. Link to comment https://bolterandchainsword.com/topic/377493-alpha-legion-headhunter-leviathal-with-tyrants/#findComment-5907376 Share on other sites More sharing options...
Agramar_The_Luna_Wolf Posted February 19, 2023 Share Posted February 19, 2023 On 2/6/2023 at 7:15 AM, Vostroi said: Delegatus with the Tyrants and Saboteur in the Headhunters squad. Vigilator either with a tact squad or the recon to have access to their augury scanner. Primary Detachment Rite of war: Headhunter Leviathal HQ Warlord Trait: Hydra Excursior or Master of Lies Cataphractii Centurion Delegatus 85pts Delegatus 25pts Power Dagger 5pts 115pts Centurion Saboteur 60pts Saboteur upgrade 15pts Nemesis bolter 5pts Power dagger 5pts 85pts Centurion Vigilator 60pts Vigilator upgrade 35pts Power Dagger 5pts 100 pts Troops Tactical Squad (10) 100pts 100pts Tactical Squad (10) 100pts 100pts Reconnaissance Squad (5) 85pts Augury Scanner 10pts Nemesis Bolters 50pts 145pts Fast Attack Sky Hunter Squad (3) 105pts 3 multi melta 45pts 150pts Seeker Squad (5) 105pts Seeker Sergeant combi disintegrator 10pts 115pts Headhunter Kill Team (5) 125pts +5 Headhunders 100pts Multi Melta 20pts Artificier Armor 10pts 255pts Elite Contemptor Dreadnought (1) 175pts Gravis Power fist with built in graviton gun 15pts Gravis Melta Cannon 5pts 195pts Heavy Support Heavy Support Squad (5) 100pts +2 Legionaires 30pts 7 Lascannons 70pts Augury Scanner 10pts artificer armor 10pts 220pts Tyrant Siege Terminator Squad (5) 300pts +2 Tyrants 110pts Chainfist 5pts Power Dagger 5pts 420pts 2000 Hello! I have a question about this list. How do you include Tyrant Siege terminator in an Alpha Legion list?? Thanks in advance! Link to comment https://bolterandchainsword.com/topic/377493-alpha-legion-headhunter-leviathal-with-tyrants/#findComment-5911970 Share on other sites More sharing options...
armarnis Posted February 22, 2023 Share Posted February 22, 2023 check up the alpha legion legion rules, its called reward for treason Agramar_The_Luna_Wolf, Brother Sutek and Xenith 3 Back to top Link to comment https://bolterandchainsword.com/topic/377493-alpha-legion-headhunter-leviathal-with-tyrants/#findComment-5912861 Share on other sites More sharing options...
Agramar_The_Luna_Wolf Posted February 22, 2023 Share Posted February 22, 2023 (edited) 3 hours ago, armarnis said: check up the alpha legion legion rules, its called reward for treason Thanks! What a cool rule... Edited February 22, 2023 by AGRAMAR Link to comment https://bolterandchainsword.com/topic/377493-alpha-legion-headhunter-leviathal-with-tyrants/#findComment-5912977 Share on other sites More sharing options...
Brother Sutek Posted March 4, 2023 Share Posted March 4, 2023 On 2/6/2023 at 10:07 AM, Vostroi said: I'm intentionally not using any pdf units. I don't mind if others use them but I'm making my list from books only. Fulmentarus don't belong in any friendly game. So you won't be trying the Effrit? Is that to keep down any complaints from opponents? I am converting some up and they look to be a solid unit for the Headhunter RoW. Link to comment https://bolterandchainsword.com/topic/377493-alpha-legion-headhunter-leviathal-with-tyrants/#findComment-5916513 Share on other sites More sharing options...
