Mr. Oddity Posted February 15, 2023 Share Posted February 15, 2023 Greetings frater, I was hoping someone could post a few pictures of the new field ordnance batteries next to the old heavy weapons team on 60mm base. I've got a potential conversion idea kicking around in my head but don't know if the scale difference will be an issue. Any help is appreciated! Link to comment https://bolterandchainsword.com/topic/377599-field-ordnance-battery-vs-heavy-weapon-team-size-comparison/ Share on other sites More sharing options...
FelipeFlops Posted February 16, 2023 Share Posted February 16, 2023 If no-one else replies, I'll send a picture in 6-7hours or so when I'm back from work. Link to comment https://bolterandchainsword.com/topic/377599-field-ordnance-battery-vs-heavy-weapon-team-size-comparison/#findComment-5910773 Share on other sites More sharing options...
Solution Focslain Posted February 16, 2023 Solution Share Posted February 16, 2023 Not the best pict, but I had the FOB next to a HW team in a group pict. Might give you a little something to go on until someone drops a better version. The FOB are on 100mm bases, basically the armigar base. Mithrilforge and Mr. Oddity 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/377599-field-ordnance-battery-vs-heavy-weapon-team-size-comparison/#findComment-5910814 Share on other sites More sharing options...
Mr. Oddity Posted February 16, 2023 Author Share Posted February 16, 2023 On 2/16/2023 at 1:18 PM, Focslain said: Not the best pict, but I had the FOB next to a HW team in a group pict. Might give you a little something to go on until someone drops a better version. The FOB are on 100mm bases, basically the armigar base. Expand That is very helpful, thank you! I knew they were on the larger base, but my mind was having issues scaling them together. Much appreciated! Focslain 1 Back to top Link to comment https://bolterandchainsword.com/topic/377599-field-ordnance-battery-vs-heavy-weapon-team-size-comparison/#findComment-5910856 Share on other sites More sharing options...
