domsto Posted February 18, 2023 Share Posted February 18, 2023 (edited) So after a long break of WH40K i startet looking to build a Guard List for a small local Tournament. and i stumbelt about the Artillery Question. Is Artillery in Guard now as dead as it is in every other Faction or does it still have some value? I mean with the "expert Bombadier" Regimental Trait you can negate the -1 to hit from Barrage, but is worth it sacrificing a Regimental Trait slot for that? The AP nerf still remains with the Manticore beeing only Ap-2, so still struggeling to remove some Objective holders in the enemy backfield if they benefit from cover. And the Basilisk only Damage 2 seems also like a small nerf. The Wyvern is.... yeah let`s not talk about it. leaving us with only the Field Ordinance Battery (i exlude the Deathstrike on porpose as it is a no brainer MW machine and so no real Artillery in my book) i had the thought experiment of using Creed with 3 Field Ordinance Batterys Bombast field guns. You can Orde them take aim so you get +1 to hit and -1 Ap so you can negate the Barrage nerf complety, in addition because Creed Orders them they get +1S and combinded with the "expert Bombadiers" regiment you get at the end 6d6 S8/-2/2 hitting on 3s Costing 470 Points that`s 3 Leman Russ Battletanks, and i think we all know who is making more Damage while also tanking more fire. And that`s my main problem while trying to include Artillery to my List, yes it could work if i build around it, but.......is it worth it? A list composed of almost exlusively Leman Russ and Cadian Shocktroops look soo much better. Edited February 18, 2023 by domsto Link to comment https://bolterandchainsword.com/topic/377624-artillery-or-no-artillery/ Share on other sites More sharing options...
Malakithe Posted February 18, 2023 Share Posted February 18, 2023 I think you will be sacrificing too much to run any of the Artillery. Those points are better spent going a different route. For me I dropped all indirect weapons in favor of more battle tanks Link to comment https://bolterandchainsword.com/topic/377624-artillery-or-no-artillery/#findComment-5911593 Share on other sites More sharing options...
duz_ Posted February 18, 2023 Share Posted February 18, 2023 Some threads that might also help: Link to comment https://bolterandchainsword.com/topic/377624-artillery-or-no-artillery/#findComment-5911594 Share on other sites More sharing options...
Solution Tokugawa Posted February 18, 2023 Solution Share Posted February 18, 2023 The only IG indirect artillery which favored by current version rules, is the very basic mortar. librisrouge, Slave to Darkness and Emperor Ming 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/377624-artillery-or-no-artillery/#findComment-5911627 Share on other sites More sharing options...
Hiroitchi Posted February 18, 2023 Share Posted February 18, 2023 I mean yes artillery is somewhat dead but given the FAQ for FW models, it kinda puts it back on the menu as an option. Like, you like basilisk earth shaker cannons, but don’t like how the buffs for it are meh, the. Step it up a notch and choose an Earthshaker carriage battery because they are units of 1-3 and get the platoon keyword. Link to comment https://bolterandchainsword.com/topic/377624-artillery-or-no-artillery/#findComment-5911633 Share on other sites More sharing options...
jarms48 Posted February 19, 2023 Share Posted February 19, 2023 8 hours ago, Hiroitchi said: I mean yes artillery is somewhat dead but given the FAQ for FW models, it kinda puts it back on the menu as an option. Like, you like basilisk earth shaker cannons, but don’t like how the buffs for it are meh, the. Step it up a notch and choose an Earthshaker carriage battery because they are units of 1-3 and get the platoon keyword. The biggest problem with the carriages is they still have the old earthshaker profile, so you're stuck with D3 damage. Link to comment https://bolterandchainsword.com/topic/377624-artillery-or-no-artillery/#findComment-5911757 Share on other sites More sharing options...
Hiroitchi Posted February 19, 2023 Share Posted February 19, 2023 2 hours ago, jarms48 said: The biggest problem with the carriages is they still have the old earthshaker profile, so you're stuck with D3 damage It’s been updated. It has Earthshaker, same weapon name as a basilisk. So yeah same weapon profile. Link to comment https://bolterandchainsword.com/topic/377624-artillery-or-no-artillery/#findComment-5911779 Share on other sites More sharing options...
jarms48 Posted February 19, 2023 Share Posted February 19, 2023 (edited) 1 hour ago, Hiroitchi said: It’s been updated. It has Earthshaker, same weapon name as a basilisk. So yeah same weapon profile. Where does it say that in the FW FAQ? I don't see it. Edited February 19, 2023 by jarms48 Link to comment https://bolterandchainsword.com/topic/377624-artillery-or-no-artillery/#findComment-5911790 Share on other sites More sharing options...
domsto Posted February 19, 2023 Author Share Posted February 19, 2023 14 hours ago, Tokugawa said: The only IG indirect artillery which favored by current version rules, is the very basic mortar. I quess you are right, everything considered if one want indirect fire only real option is the mortar. Now i have to find shelf space for my 9 Basilisk and Manticores Link to comment https://bolterandchainsword.com/topic/377624-artillery-or-no-artillery/#findComment-5911807 Share on other sites More sharing options...
Hiroitchi Posted February 19, 2023 Share Posted February 19, 2023 (edited) 12 hours ago, jarms48 said: Where does it say that in the FW FAQ? I don't see it. it’s hidden but if you look at the dataslate for the Armageddon pattern basilisk, the weapons Earthshaker cannon was updated. When that happened the weapon Earthshaker cannon was updated with the Earthshaker carriages since the weapon name of the Earthshaker carriage weapon is still Earthshaker cannon. It’s sneaky sneak. Lol also to quote sources: battlescribe, wahpedia, and even the Warhammer 40K app was updated to reflect this. Edited February 19, 2023 by Hiroitchi Quoting sources Link to comment https://bolterandchainsword.com/topic/377624-artillery-or-no-artillery/#findComment-5911923 Share on other sites More sharing options...
jarms48 Posted February 20, 2023 Share Posted February 20, 2023 14 hours ago, Hiroitchi said: also to quote sources: battlescribe, wahpedia, and even the Warhammer 40K app was updated to reflect this. If it's on the 40k app then it's definitely official. Such a strange way to do it. Actually makes the carriage worth considering. 120 points and the ability to take infantry orders makes it pretty decent. Link to comment https://bolterandchainsword.com/topic/377624-artillery-or-no-artillery/#findComment-5912087 Share on other sites More sharing options...
Hiroitchi Posted February 20, 2023 Share Posted February 20, 2023 6 hours ago, jarms48 said: 120 points and the ability to take infantry orders makes it pretty decent. don’t forget it has the artillery keyword too.. so there is a possibility to help with the +1/-1 stuff of shooting through dense/obscuring terrain in addition to the take aim order. Link to comment https://bolterandchainsword.com/topic/377624-artillery-or-no-artillery/#findComment-5912195 Share on other sites More sharing options...
